Hi everyone,
I am trying to install jetpack for Jetson xavier on an internal nvme using sdk manager on Ubuntu 20. I keep getting this error. Could you please help me trying this installation done.
Thank for your time in advance. Find below the command line errors from sdk manager.
02:35:42 INFO: Flash Jetson Xavier NX - flash: [ 0.0475 ] RCM 0 is saved as rcm_0.rcm
02:35:42 INFO: Flash Jetson Xavier NX - flash: [ 0.0612 ] Assuming zero filled SBK key
02:35:42 INFO: Flash Jetson Xavier NX - flash: [ 0.0657 ] tegrarcm_v2 --chip 0x19 0 --updatesig rcm_list_signed.xml
02:35:42 INFO: Flash Jetson Xavier NX - flash: [ 0.0695 ] tegrarcm_v2 --chip 0x19 0 --rcm rcm_list_signed.xml --skipuid
02:35:42 INFO: Flash Jetson Xavier NX - flash: [ 0.0703 ] RCM version 0X190001
02:35:47 ERROR: Flash Jetson Xavier NX - flash: while count is not 0:
02:35:47 ERROR: Flash Jetson Xavier NX - flash: *** ERROR: Parsing boardid failed
02:35:47 ERROR: Flash Jetson Xavier NX - flash: command terminated with error
02:35:47 SUMMARY: DateTime Target Setup - target: Depends on failed component
