I use Ubuntu 20.04 host machine with the latest SDK manager. I’m trying to flash Jetpack 5.0.2 (Rev.1) on Jetson Xavier NX, J202 Seeed carrier board with NVMe. The log from the terminal window of error messages is below. What should I do?
Maybe related or not, earlier on SDK manager complained about APT repositories. I deleted files it was complaining about from /etc/apt/sources.list.d which seems to solve that issue.
16:29:02 SUMMARY: Drivers for Jetson - target_image: Install completed successfully.
16:30:45 ERROR: File System and OS - target_image: dpkg: error processing package puppetpc (–configure):
16:30:45 ERROR: File System and OS - target_image: E: Sub-process /usr/bin/dpkg returned an error code (1)
16:30:46 ERROR: File System and OS - target_image: dpkg: error processing package puppetpc (–configure):
16:30:47 ERROR: File System and OS - target_image: E: Sub-process /usr/bin/dpkg returned an error code (1)
16:30:47 ERROR: File System and OS - target_image: command terminated with error
16:30:47 SUMMARY: File System and OS - target_image: First Error: Installation failed.
16:30:47 SUMMARY: NVIDIA Container Runtime with Docker integration (Beta) - target: Depends on failed component
16:30:47 SUMMARY: BSP Patch - target: Depends on failed component
16:30:47 SUMMARY: Multimedia API - target: Depends on failed component
16:30:47 SUMMARY: TensorRT Runtime - target: Depends on failed component
16:30:47 SUMMARY: VPI Runtime - target: Depends on failed component
16:30:47 SUMMARY: CUDA Runtime - target: Depends on failed component
16:30:47 SUMMARY: CuDNN Runtime - target: Depends on failed component
16:30:47 SUMMARY: OpenCV Runtime - target: Depends on failed component
16:30:47 SUMMARY: DateTime Target Setup - target: Depends on failed component
16:30:47 SUMMARY: Flash Jetson Xavier NX - flash: Depends on failed component
