Failed to allocate required memory for USB cam in jetson nano
Just another suggestion in case the gst-launch-1.10 suggested command still not working. Maybe you should check if the power adapter could be the problem:
https://forums.developer.nvidia.com/t/power-supply-considerations-for-jetson-nano-developer-kit/71637
