Failed to build TensorRT engine
I Failed to build TensorRT engine on the default model that is given after I open the software. I tried to just work on my own project but always ended up getting Failed to build TensorRT engine when I try to create a A2F pipeline.
Someone please help me fix this.
My spec are:
RTX 4070 Ti
AMD Ryzen 7 5700X
32GB RAM
1TB SSD
Windows 11 Home, Version: 22H2
kit_20230202_230204.log (628.0 KB)
You will need 2022.1.2 or greater for ADA card support. I would recommend using the latest version, 2022.2.0, though.
ah yes, it’s working. Thanks a lot
