Failed to import a python module
Hi. When I launch an IsaacSim, I frequently face this kind of error. (maybe once per 2~3 months?)
Even I didn’t change any components or codes.
This is annoying, so I hope to know the general reasons and solutions.
Q1. I wonder if another user also gets similar problems.
Q2. What is the reason for this?
Q3. What is the best way to solve this?
"failed to import a Python module …
Hi @PARKBONG - The “Failed to import a python module” error typically occurs when Python cannot find the module you’re trying to import. This could be due to several reasons:
  1. Module is not installed: The module you’re trying to import is not installed in your Python environment. You can install it using pip or conda.
  2. Wrong Python environment: You might be running the script in a different Python environment from the one where the module is installed. Make sure you’re using the correct Python interpreter.
  3. Incorrect PYTHONPATH: Python uses the PYTHONPATH environment variable to determine where to look for modules to import. If PYTHONPATH doesn’t include the directory where your module is located, Python won’t be able to find it. You can add directories to PYTHONPATH in your shell configuration file or directly in your Python script using sys.path.append().
  4. Module name typo: Make sure the module name in the import statement is spelled correctly.
  5. Nested import issues: If the module you’re trying to import itself imports other modules, and those modules aren’t found, you can also get this error. Check the import statements in the module you’re trying to import.
To solve the issue, you can try the following:
  • Install the module using pip or conda.
  • Check your Python environment and make sure it’s the one where the module is installed.
  • Check your PYTHONPATH and make sure it includes the directory where the module is located.
  • Check the spelling of the module name in your import statement.
  • Check the import statements in the module you’re trying to import.
