I followed the steps to Install Jetson Software with SDK Manager, but none of the target component was installed successfully. It told me that the dependency has error.
Flash Jetson AGX Xavier shows:
15:09:43 SUMMARY: Flash Jetson AGX Xavier - flash: Depends on failed component
15:28:00 SUMMARY: Flash Jetson AGX Xavier - flash: Depends on failed component
15:35:49 SUMMARY: Flash Jetson AGX Xavier - flash: Depends on failed component
CUDA Toolkit for L4T shows:
15:05:45 INFO: CUDA Toolkit for L4T - target: verifying checksum of /home/kokoro/Downloads/nvidia/sdkm_downloads/cuda-repo-l4t-10-2-local_10.2.460-1_arm64.deb
15:05:47 INFO: CUDA Toolkit for L4T - target: Found file /home/kokoro/Downloads/nvidia/sdkm_downloads/cuda-repo-l4t-10-2-local_10.2.460-1_arm64.deb with correct checksum, skip downloading.
15:09:23 INFO: CUDA Toolkit for L4T - target: verifying checksum of /home/kokoro/Downloads/nvidia/sdkm_downloads/cuda-repo-l4t-10-2-local_10.2.460-1_arm64.deb
15:09:25 INFO: CUDA Toolkit for L4T - target: Found file /home/kokoro/Downloads/nvidia/sdkm_downloads/cuda-repo-l4t-10-2-local_10.2.460-1_arm64.deb with correct checksum, skip downloading.
15:09:41 INFO: CUDA Toolkit for L4T - target: verifying checksum of /home/kokoro/Downloads/nvidia/sdkm_downloads/cuda-repo-l4t-10-2-local_10.2.460-1_arm64.deb
15:09:43 SUMMARY: CUDA Toolkit for L4T - target: Depends on failed component
15:09:43 INFO: CUDA Toolkit for L4T - target: Found file /home/kokoro/Downloads/nvidia/sdkm_downloads/cuda-repo-l4t-10-2-local_10.2.460-1_arm64.deb with correct checksum, skip downloading.
15:21:06 INFO: CUDA Toolkit for L4T - target: verifying checksum of /home/kokoro/Downloads/nvidia/sdkm_downloads/cuda-repo-l4t-10-2-local_10.2.460-1_arm64.deb
15:21:08 INFO: CUDA Toolkit for L4T - target: Found file /home/kokoro/Downloads/nvidia/sdkm_downloads/cuda-repo-l4t-10-2-local_10.2.460-1_arm64.deb with correct checksum, skip downloading.
15:21:09 INFO: CUDA Toolkit for L4T - target: verifying checksum of /home/kokoro/Downloads/nvidia/sdkm_downloads/cuda-repo-l4t-10-2-local_10.2.460-1_arm64.deb
15:21:11 INFO: CUDA Toolkit for L4T - target: Found file /home/kokoro/Downloads/nvidia/sdkm_downloads/cuda-repo-l4t-10-2-local_10.2.460-1_arm64.deb with correct checksum, skip downloading.
15:28:00 SUMMARY: CUDA Toolkit for L4T - target: Depends on failed component
15:28:56 INFO: CUDA Toolkit for L4T - target: verifying checksum of /home/kokoro/Downloads/nvidia/sdkm_downloads/cuda-repo-l4t-10-2-local_10.2.460-1_arm64.deb
15:28:57 INFO: CUDA Toolkit for L4T - target: Found file /home/kokoro/Downloads/nvidia/sdkm_downloads/cuda-repo-l4t-10-2-local_10.2.460-1_arm64.deb with correct checksum, skip downloading.
15:29:01 INFO: CUDA Toolkit for L4T - target: verifying checksum of /home/kokoro/Downloads/nvidia/sdkm_downloads/cuda-repo-l4t-10-2-local_10.2.460-1_arm64.deb
15:29:04 INFO: CUDA Toolkit for L4T - target: Found file /home/kokoro/Downloads/nvidia/sdkm_downloads/cuda-repo-l4t-10-2-local_10.2.460-1_arm64.deb with correct checksum, skip downloading.
15:35:49 SUMMARY: CUDA Toolkit for L4T - target: Depends on failed component
