Failed to run docker container in privileged mode on Jetson AGX Orin
Hi there @dusty_nv,
I’m currently trying to set up a docker container on my Jetson AGX Orin Developer Kit. The noetic-pytorch-l4t-r34.1.1 from Docker Hub suits my needs perfectly. However, I need to run the container in privileged mode (flag --privileged) since I want to access a camera from within the container, which can only be done if the container is privileged.
I’ve done this already on my older Jetson AGX Xavier and it worked (with the . However, now on the Orin I am getting an error, as soon as I try running with the --privileged flag.
Do you know any reason why this could happen and do you know a smart workaround? Is the problem coming from the specific container image I want to use or is it more related to the OS of the Orin and how docker is installed thereon?
Below I post the Error code I am getting:
docker: Error response from daemon: failed to create shim: OCI runtime create failed: runc create failed: unable to start container process: error during container init: error running hook #0: error running hook: exit status 1, stdout: src: /etc/vulkan/icd.d/nvidia_icd.json, src_lnk: /usr/lib/aarch64-linux-gnu/tegra/nvidia_icd.json, dst: /var/lib/docker/overlay2/fc468c827b67a9031d42aaec27e9a57dc46fb359b36da027221c8a016fab79b1/merged/etc/vulkan/icd.d/nvidia_icd.json, dst_lnk: /usr/lib/aarch64-linux-gnu/tegra/nvidia_icd.json
src: /usr/lib/aarch64-linux-gnu/libcuda.so, src_lnk: tegra/libcuda.so, dst: /var/lib/docker/overlay2/fc468c827b67a9031d42aaec27e9a57dc46fb359b36da027221c8a016fab79b1/merged/usr/lib/aarch64-linux-gnu/libcuda.so, dst_lnk: tegra/libcuda.so
src: /usr/lib/aarch64-linux-gnu/libnvcucompat.so, src_lnk: tegra/libnvcucompat.so, dst: /var/lib/docker/overlay2/fc468c827b67a9031d42aaec27e9a57dc46fb359b36da027221c8a016fab79b1/merged/usr/lib/aarch64-linux-gnu/libnvcucompat.so, dst_lnk: tegra/libnvcucompat.so
src: /usr/lib/aarch64-linux-gnu/libnvidia-nvvm.so, src_lnk: tegra/libnvidia-nvvm.so, dst: /var/lib/docker/overlay2/fc468c827b67a9031d42aaec27e9a57dc46fb359b36da027221c8a016fab79b1/merged/usr/lib/aarch64-linux-gnu/libnvidia-nvvm.so, dst_lnk: tegra/libnvidia-nvvm.so
src: /usr/lib/aarch64-linux-gnu/libv4l2.so.0.0.999999, src_lnk: tegra/libnvv4l2.so, dst: /var/lib/docker/overlay2/fc468c827b67a9031d42aaec27e9a57dc46fb359b36da027221c8a016fab79b1/merged/usr/lib/aarch64-linux-gnu/libv4l2.so.0.0.999999, dst_lnk: tegra/libnvv4l2.so
src: /usr/lib/aarch64-linux-gnu/libv4lconvert.so.0.0.999999, src_lnk: tegra/libnvv4lconvert.so, dst: /var/lib/docker/overlay2/fc468c827b67a9031d42aaec27e9a57dc46fb359b36da027221c8a016fab79b1/merged/usr/lib/aarch64-linux-gnu/libv4lconvert.so.0.0.999999, dst_lnk: tegra/libnvv4lconvert.so
src: /usr/lib/aarch64-linux-gnu/libv4l/plugins/nv/libv4l2_nvargus.so, src_lnk: ../../../tegra/libv4l2_nvargus.so, dst: /var/lib/docker/overlay2/fc468c827b67a9031d42aaec27e9a57dc46fb359b36da027221c8a016fab79b1/merged/usr/lib/aarch64-linux-gnu/libv4l/plugins/nv/libv4l2_nvargus.so, dst_lnk: ../../../tegra/libv4l2_nvargus.so
src: /usr/lib/aarch64-linux-gnu/libv4l/plugins/nv/libv4l2_nvcuvidvideocodec.so, src_lnk: ../../../tegra/libv4l2_nvcuvidvideocodec.so, dst: /var/lib/docker/overlay2/fc468c827b67a9031d42aaec27e9a57dc46fb359b36da027221c8a016fab79b1/merged/usr/lib/aarch64-linux-gnu/libv4l/plugins/nv/libv4l2_nvcuvidvideocodec.so, dst_lnk: ../../../tegra/libv4l2_nvcuvidvideocodec.so
src: /usr/lib/aarch64-linux-gnu/libv4l/plugins/nv/libv4l2_nvvideocodec.so, src_lnk: ../../../tegra/libv4l2_nvvideocodec.so, dst: /var/lib/docker/overlay2/fc468c827b67a9031d42aaec27e9a57dc46fb359b36da027221c8a016fab79b1/merged/usr/lib/aarch64-linux-gnu/libv4l/plugins/nv/libv4l2_nvvideocodec.so, dst_lnk: ../../../tegra/libv4l2_nvvideocodec.so
src: /usr/lib/aarch64-linux-gnu/libvulkan.so.1.3.203, src_lnk: tegra/libvulkan.so.1.3.203, dst: /var/lib/docker/overlay2/fc468c827b67a9031d42aaec27e9a57dc46fb359b36da027221c8a016fab79b1/merged/usr/lib/aarch64-linux-gnu/libvulkan.so.1.3.203, dst_lnk: tegra/libvulkan.so.1.3.203
src: /usr/lib/aarch64-linux-gnu/tegra/libcuda.so, src_lnk: libcuda.so.1.1, dst: /var/lib/docker/overlay2/fc468c827b67a9031d42aaec27e9a57dc46fb359b36da027221c8a016fab79b1/merged/usr/lib/aarch64-linux-gnu/tegra/libcuda.so, dst_lnk: libcuda.so.1.1
src: /usr/lib/aarch64-linux-gnu/tegra/libgstnvdsseimeta.so, src_lnk: libgstnvdsseimeta.so.1.0.0, dst: /var/lib/docker/overlay2/fc468c827b67a9031d42aaec27e9a57dc46fb359b36da027221c8a016fab79b1/merged/usr/lib/aarch64-linux-gnu/tegra/libgstnvdsseimeta.so, dst_lnk: libgstnvdsseimeta.so.1.0.0
src: /usr/lib/aarch64-linux-gnu/tegra/libnvbufsurface.so, src_lnk: libnvbufsurface.so.1.0.0, dst: /var/lib/docker/overlay2/fc468c827b67a9031d42aaec27e9a57dc46fb359b36da027221c8a016fab79b1/merged/usr/lib/aarch64-linux-gnu/tegra/libnvbufsurface.so, dst_lnk: libnvbufsurface.so.1.0.0
src: /usr/lib/aarch64-linux-gnu/tegra/libnvbufsurftransform.so, src_lnk: libnvbufsurftransform.so.1.0.0, dst: /var/lib/docker/overlay2/fc468c827b67a9031d42aaec27e9a57dc46fb359b36da027221c8a016fab79b1/merged/usr/lib/aarch64-linux-gnu/tegra/libnvbufsurftransform.so, dst_lnk: libnvbufsurftransform.so.1.0.0
src: /usr/lib/aarch64-linux-gnu/tegra/libnvbuf_utils.so, src_lnk: libnvbuf_utils.so.1.0.0, dst: /var/lib/docker/overlay2/fc468c827b67a9031d42aaec27e9a57dc46fb359b36da027221c8a016fab79b1/merged/usr/lib/aarch64-linux-gnu/tegra/libnvbuf_utils.so, dst_lnk: libnvbuf_utils.so.1.0.0
src: /usr/lib/aarch64-linux-gnu/tegra/libnvdsbufferpool.so, src_lnk: libnvdsbufferpool.so.1.0.0, dst: /var/lib/docker/overlay2/fc468c827b67a9031d42aaec27e9a57dc46fb359b36da027221c8a016fab79b1/merged/usr/lib/aarch64-linux-gnu/tegra/libnvdsbufferpool.so, dst_lnk: libnvdsbufferpool.so.1.0.0
src: /usr/lib/aarch64-linux-gnu/tegra/libnvidia-nvvm.so, src_lnk: libnvidia-nvvm.so.4, dst: /var/lib/docker/overlay2/fc468c827b67a9031d42aaec27e9a57dc46fb359b36da027221c8a016fab79b1/merged/usr/lib/aarch64-linux-gnu/tegra/libnvidia-nvvm.so, dst_lnk: libnvidia-nvvm.so.4
src: /usr/lib/aarch64-linux-gnu/tegra/libnvidia-nvvm.so.4, src_lnk: libnvidia-nvvm.so.4.0.0, dst: /var/lib/docker/overlay2/fc468c827b67a9031d42aaec27e9a57dc46fb359b36da027221c8a016fab79b1/merged/usr/lib/aarch64-linux-gnu/tegra/libnvidia-nvvm.so.4, dst_lnk: libnvidia-nvvm.so.4.0.0
src: /usr/lib/aarch64-linux-gnu/tegra/libnvid_mapper.so, src_lnk: libnvid_mapper.so.1.0.0, dst: /var/lib/docker/overlay2/fc468c827b67a9031d42aaec27e9a57dc46fb359b36da027221c8a016fab79b1/merged/usr/lib/aarch64-linux-gnu/tegra/libnvid_mapper.so, dst_lnk: libnvid_mapper.so.1.0.0
src: /usr/lib/aarch64-linux-gnu/tegra/libnvscibuf.so, src_lnk: libnvscibuf.so.1, dst: /var/lib/docker/overlay2/fc468c827b67a9031d42aaec27e9a57dc46fb359b36da027221c8a016fab79b1/merged/usr/lib/aarch64-linux-gnu/tegra/libnvscibuf.so, dst_lnk: libnvscibuf.so.1
src: /usr/lib/aarch64-linux-gnu/tegra/libnvscicommon.so, src_lnk: libnvscicommon.so.1, dst: /var/lib/docker/overlay2/fc468c827b67a9031d42aaec27e9a57dc46fb359b36da027221c8a016fab79b1/merged/usr/lib/aarch64-linux-gnu/tegra/libnvscicommon.so, dst_lnk: libnvscicommon.so.1
src: /usr/lib/aarch64-linux-gnu/tegra/libnvscistream.so, src_lnk: libnvscistream.so.1, dst: /var/lib/docker/overlay2/fc468c827b67a9031d42aaec27e9a57dc46fb359b36da027221c8a016fab79b1/merged/usr/lib/aarch64-linux-gnu/tegra/libnvscistream.so, dst_lnk: libnvscistream.so.1
src: /usr/lib/aarch64-linux-gnu/tegra/libnvscisync.so, src_lnk: libnvscisync.so.1, dst: /var/lib/docker/overlay2/fc468c827b67a9031d42aaec27e9a57dc46fb359b36da027221c8a016fab79b1/merged/usr/lib/aarch64-linux-gnu/tegra/libnvscisync.so, dst_lnk: libnvscisync.so.1
src: /usr/share/glvnd/egl_vendor.d/10_nvidia.json, src_lnk: ../../../lib/aarch64-linux-gnu/tegra-egl/nvidia.json, dst: /var/lib/docker/overlay2/fc468c827b67a9031d42aaec27e9a57dc46fb359b36da027221c8a016fab79b1/merged/usr/share/glvnd/egl_vendor.d/10_nvidia.json, dst_lnk: ../../../lib/aarch64-linux-gnu/tegra-egl/nvidia.json
, stderr: nvidia-container-cli: mount error: file creation failed: /var/lib/docker/overlay2/fc468c827b67a9031d42aaec27e9a57dc46fb359b36da027221c8a016fab79b1/merged/dev/nvhost-as-gpu: invalid argument: unknown.
ERRO[0000] error waiting for container: context canceled
Thanks a lot for your help!
Hi @user152354, please see this post:
thanks a lot @dusty_nv, it worked :)
