下面是docker的运行指令和报错信息
提示cannot allocate memory,但是没有错误码
下面时宿主机信息
I try to remove ‘–runtime nvidia’ and it works good.
Maybe there is a conflict between ‘–privileged=true’ and ‘–runtime nvidia’.
What is the JetPack version (L4T version) and docker related package version are you using?
L4T version: (JetPack 4.6.1 == L4T R32.7.1)
cat /etc/nv_tegra_release
output:
# R32 (release), REVISION: 7.1, GCID: 29818004, BOARD: t210ref, EABI: aarch64, DATE: Sat Feb 19 17:05:08 UTC 2022
Docker packages:
apt list --installed | grep -e docker -e container
output:
WARNING: apt does not have a stable CLI interface. Use with caution in scripts.
containerd/now 1.5.5-0ubuntu3~18.04.1 arm64 [installed,upgradable to: 1.5.5-0ubuntu3~18.04.2]
docker/bionic,now 1.5-1build1 arm64 [installed]
docker.io/bionic-updates,bionic-security,now 20.10.7-0ubuntu5~18.04.3 arm64 [installed]
libnvidia-container-tools/stable,now 1.7.0-1 arm64 [installed]
libnvidia-container0/stable,now 0.10.0+jetpack arm64 [installed]
libnvidia-container1/stable,now 1.7.0-1 arm64 [installed]
nvidia-container-csv-cuda/stable,now 10.2.460-1 arm64 [installed]
nvidia-container-csv-cudnn/stable,now 8.2.1.32-1+cuda10.2 arm64 [installed]
nvidia-container-csv-tensorrt/stable,now 8.2.1.8-1+cuda10.2 arm64 [installed]
nvidia-container-csv-visionworks/stable,now 1.6.0.501 arm64 [installed]
nvidia-container-runtime/stable,now 3.7.0-1 all [installed]
nvidia-container-toolkit/stable,now 1.7.0-1 arm64 [installed]
nvidia-docker2/stable,now 2.8.0-1 all [installed]
At least since JetPack 4.5, similar problems have occurred, and they are all caused by updating to a docker version that is mismatched with the JetPack version.
Hi naisy,
sorry to reply so late.
The JetPack version I used is v4.6 (L4T R32.6.1), see the below.
It looks like you are facing a similar issue as the below topic:
Could you try the solution to see if it also works for your case?
