I’m trying to use the GPIO on Agx Orin (Running JP6.0). I’ve followed the instruction here to change a the pin to GPIO output dynamically.
The command I used to configure the GPIO is:
sudo busybox devmem 0x02435008 w 0x004
I can see that the pin (GPIO_08, pin 16 on the 40 header) has been set to output mode with gpioinfo tool.
But when I used the jetson-gpio to set this pin output state, it doesn’t work. Measured with multimetter, the output never changes.
The tricky thing is I did the same thing on (GPIO_33, pin 7 on the 40 header), it worked fine.
Please help with this, anything I did wrong?
