I just installed a new environment on TX2 (see this post, though it has problem to start GUI, yet I can ssh log into it to do something). Nvidia Jetson TX2 is hanging on “Started Update UTMP about System Runlevel Changes.” after flashing new packages with SDKManager 1.1
When I tried to start the docker daemon, it failed.
tx2@tx2-desktop:~$ sudo systemctl start docker
Job for docker.service failed because the control process exited with error code. See "systemctl status docker.service" and "journalctl -xe" for details.
tx2@tx2-desktop:~$ sudo systemctl status docker.service
● docker.service - Docker Application Container Engine Loaded: loaded (/lib/systemd/system/docker.service; disabled; vendor preset: enabled) Active: failed (Result: exit-code) since Tue 2020-06-09 22:36:18 EDT; 32s ago Docs: https://docs.docker.com Process: 19062 ExecStart=/usr/bin/dockerd -H fd:// --containerd=/run/containerd/containerd.sock (code=exited, status=1/FAILURE) Main PID: 19062 (code=exited, status=1/FAILURE) Jun 09 22:36:18 tx2-desktop systemd[1]: docker.service: Service hold-off time over, scheduling restart. Jun 09 22:36:18 tx2-desktop systemd[1]: docker.service: Scheduled restart job, restart counter is at 3. Jun 09 22:36:18 tx2-desktop systemd[1]: Stopped Docker Application Container Engine. Jun 09 22:36:18 tx2-desktop systemd[1]: docker.service: Start request repeated too quickly. Jun 09 22:36:18 tx2-desktop systemd[1]: docker.service: Failed with result 'exit-code'. Jun 09 22:36:18 tx2-desktop systemd[1]: Failed to start Docker Application Container Engine.
$ cat /var/log/syslog
Jun 9 22:36:10 tx2-desktop kernel: [75741.053337] device-mapper: table: 253:0: thin-pool: unknown target type
Jun 9 22:36:10 tx2-desktop kernel: [75741.063525] device-mapper: ioctl: error adding target to table
Jun 9 22:36:10 tx2-desktop dockerd[18852]: time=“2020-06-09T22:36:10.960167030-04:00” level=error msg="[graphdriver] prior storage driver devicemapper failed: devicemapper: Error running deviceCreate (CreatePool) dm_task_run failed"
Jun 9 22:36:10 tx2-desktop dockerd[18852]: failed to start daemon: error initializing graphdriver: devicemapper: Error running deviceCreate (CreatePool) dm_task_run failed
Jun 9 22:36:10 tx2-desktop systemd[1]: docker.service: Main process exited, code=exited, status=1/FAILURE
Jun 9 22:36:10 tx2-desktop systemd[1]: docker.service: Failed with result ‘exit-code’.
Jun 9 22:36:10 tx2-desktop systemd[1]: Failed to start Docker Application Container Engine.
Jun 9 22:36:13 tx2-desktop systemd[1]: docker.service: Service hold-off time over, scheduling restart.
Jun 9 22:36:13 tx2-desktop systemd[1]: docker.service: Scheduled restart job, restart counter is at 1.
Jun 9 22:36:13 tx2-desktop systemd[1]: Stopped Docker Application Container Engine.
This is a new installation from JetPack 4.4/SDKManager 1.1, I expected it to be working well if there is no issue with the installation, which I didn’t see any.
$ dpkg -l | grep docker
ii docker 1.5-1build1 arm64 System tray for KDE3/GNOME2 docklet applications
ii docker.io 19.03.6-0ubuntu1~18.04.1 arm64 Linux container runtime
ii nvidia-docker2 2.2.0-1 all nvidia-docker CLI wrapper
Any hints, suggestions are appreciated.
