I’m running with 364.19 successfully and am trying to update to 367.35 via ppa graphics-drivers with the following commands:
sudo apt-get purge nvidia-*
sudo add-apt-repository ppa:graphics-drivers/ppa
sudo apt update
sudo apt install nvidia-367
After reboot nvidia-smi indicates no nvidia driver is installed. apt log (/var/log/apt/term.log) shows:
Building initial module for 3.13.0-92-generic
ERROR: Cannot create report: [Errno 17] File exists: ‘/var/crash/nvidia-367.0.crash’
Error! Application of patch buildfix_kernel_4.7.patch failed.
Check /var/lib/dkms/nvidia-367/367.35/build/ for more information.
I checked the specified directory but nothing pops out to me. Can you point me in the right direction?
Should I remove the crash report (from a previous install attempt last week) and try again?
I can restore 364.19 via the above procedure OK.
3vi1
July 29, 2016, 8:07pm
2
What do the logs in /var/lib/dkms/nvidia-367/367.35/build/ say?
There are no logs in /var/lib/dkms/nvidia-367/367.35/build/ that I can find. If you can point me to something I’d be glad to take a look:
jerry@DigitalDVR:/var/lib/dkms/nvidia-367/367.35/build/$ ll
total 132
drwxr-xr-x 3 root root 4096 Jul 29 14:57 common/
-rwxr-xr-x 1 root root 90323 Jul 29 14:57 conftest.sh*
-rw-r–r-- 1 root root 976 Jul 29 14:57 dkms.conf
-rw-r–r-- 1 root root 5627 Jul 29 14:57 Kbuild
-rw-r–r-- 1 root root 4563 Jul 29 14:57 Makefile
drwxr-xr-x 2 root root 4096 Jul 29 14:57 nvidia/
drwxr-xr-x 2 root root 4096 Jul 29 14:57 nvidia-drm/
drwxr-xr-x 2 root root 4096 Jul 29 14:57 nvidia-modeset/
drwxr-xr-x 2 root root 4096 Jul 29 14:57 patches/
jerry@DigitalDVR:/var/lib/dkms/nvidia-367/367.35/build/$ ll *
common:
total 4
drwxr-xr-x 2 root root 4096 Jul 29 14:57 inc/
nvidia:
total 11820
-rw-r–r-- 1 root root 4807 Jul 29 14:57 ebridge_export.h
-rw-r–r-- 1 root root 8659 Jul 29 14:57 ebridge_linux.c
-rw-r–r-- 1 root root 6932 Jul 29 14:57 ibmnpu_export.h
-rw-r–r-- 1 root root 22774 Jul 29 14:57 ibmnpu_linux.c
-rw-r–r-- 1 root root 43866 Jul 29 14:57 nv-acpi.c
-rw-r–r-- 1 root root 110419 Jul 29 14:57 nv.c
-rw-r–r-- 1 root root 803 Jul 29 14:57 nv-chrdev.c
-rw-r–r-- 1 root root 7042 Jul 29 14:57 nv-cray.c
-rw-r–r-- 1 root root 14781 Jul 29 14:57 nv-dma.c
-rw-r–r-- 1 root root 10204 Jul 29 14:57 nv-frontend.c
-rw-r–r-- 1 root root 1161 Jul 29 14:57 nv-frontend.h
-rw-r–r-- 1 root root 14851 Jul 29 14:57 nv_gpu_ops.h
-rw-r–r-- 1 root root 3112 Jul 29 14:57 nv-gvi.c
-rw-r–r-- 1 root root 8325 Jul 29 14:57 nv-i2c.c
-rw-r–r-- 1 root root 6218 Jul 29 14:57 nvidia.Kbuild
-rw-r–r-- 1 root root 1082 Jul 29 14:57 nvidia-sources.Kbuild
-rw-r–r-- 1 root root 2169 Jul 29 14:57 nv-instance.c
-rw-r–r-- 1 root root 758 Jul 29 14:57 nv-instance.h
-rw-r–r-- 1 root root 11505776 Jul 29 14:57 nv-kernel.o_binary
-rw-r–r-- 1 root root 4732 Jul 29 14:57 nvlink_common.h
-rw-r–r-- 1 root root 2066 Jul 29 14:57 nvlink_errors.h
-rw-r–r-- 1 root root 1767 Jul 29 14:57 nvlink_export.h
-rw-r–r-- 1 root root 10599 Jul 29 14:57 nvlink_linux.c
-rw-r–r-- 1 root root 1688 Jul 29 14:57 nvlink_linux.h
-rw-r–r-- 1 root root 2391 Jul 29 14:57 nvlink_pci.c
-rw-r–r-- 1 root root 3042 Jul 29 14:57 nvlink_pci.h
-rw-r–r-- 1 root root 1794 Jul 29 14:57 nvlink_proto.h
-rw-r–r-- 1 root root 2981 Jul 29 14:57 nv-memdbg.h
-rw-r–r-- 1 root root 582 Jul 29 14:57 nv-mempool.c
-rw-r–r-- 1 root root 14179 Jul 29 14:57 nv-mmap.c
-rw-r–r-- 1 root root 3393 Jul 29 14:57 nv-modeset-interface.c
-rw-r–r-- 1 root root 8417 Jul 29 14:57 nv-p2p.c
-rw-r–r-- 1 root root 6796 Jul 29 14:57 nv-p2p.h
-rw-r–r-- 1 root root 7034 Jul 29 14:57 nv-pat.c
-rw-r–r-- 1 root root 1226 Jul 29 14:57 nv-pci-table.c
-rw-r–r-- 1 root root 478 Jul 29 14:57 nv-pci-table.h
-rw-r–r-- 1 root root 17845 Jul 29 14:57 nv-procfs.c
-rw-r–r-- 1 root root 16239 Jul 29 14:57 nv-reg.h
-rw-r–r-- 1 root root 2816 Jul 29 14:57 nv-usermap.c
-rw-r–r-- 1 root root 43171 Jul 29 14:57 nv_uvm_interface.c
-rw-r–r-- 1 root root 17543 Jul 29 14:57 nv-vm.c
-rw-r–r-- 1 root root 1037 Jul 29 14:57 nv-vtophys.c
-rw-r–r-- 1 root root 35811 Jul 29 14:57 os-interface.c
-rw-r–r-- 1 root root 3846 Jul 29 14:57 os-mlock.c
-rw-r–r-- 1 root root 3069 Jul 29 14:57 os-pci.c
-rw-r–r-- 1 root root 7216 Jul 29 14:57 os-registry.c
-rw-r–r-- 1 root root 1384 Jul 29 14:57 os-usermap.c
-rw-r–r-- 1 root root 1474 Jul 29 14:57 rmil.h
-rw-r–r-- 1 root root 531 Jul 29 14:57 rmp2pdefines.h
nvidia-drm:
total 212
-rw-r–r-- 1 root root 1911 Jul 29 14:57 nvidia-drm.c
-rw-r–r-- 1 root root 13356 Jul 29 14:57 nvidia-drm-connector.c
-rw-r–r-- 1 root root 2176 Jul 29 14:57 nvidia-drm-connector.h
-rw-r–r-- 1 root root 10533 Jul 29 14:57 nvidia-drm-crtc.c
-rw-r–r-- 1 root root 1826 Jul 29 14:57 nvidia-drm-crtc.h
-rw-r–r-- 1 root root 20926 Jul 29 14:57 nvidia-drm-drv.c
-rw-r–r-- 1 root root 1411 Jul 29 14:57 nvidia-drm-drv.h
-rw-r–r-- 1 root root 12239 Jul 29 14:57 nvidia-drm-encoder.c
-rw-r–r-- 1 root root 2072 Jul 29 14:57 nvidia-drm-encoder.h
-rw-r–r-- 1 root root 10232 Jul 29 14:57 nvidia-drm-fb.c
-rw-r–r-- 1 root root 1899 Jul 29 14:57 nvidia-drm-fb.h
-rw-r–r-- 1 root root 12655 Jul 29 14:57 nvidia-drm-gem.c
-rw-r–r-- 1 root root 3373 Jul 29 14:57 nvidia-drm-gem.h
-rw-r–r-- 1 root root 1300 Jul 29 14:57 nvidia-drm.h
-rw-r–r-- 1 root root 3696 Jul 29 14:57 nvidia-drm-ioctl.h
-rw-r–r-- 1 root root 2605 Jul 29 14:57 nvidia-drm.Kbuild
-rw-r–r-- 1 root root 5844 Jul 29 14:57 nvidia-drm-linux.c
-rw-r–r-- 1 root root 4778 Jul 29 14:57 nvidia-drm-mmap.c
-rw-r–r-- 1 root root 1455 Jul 29 14:57 nvidia-drm-mmap.h
-rw-r–r-- 1 root root 24104 Jul 29 14:57 nvidia-drm-modeset.c
-rw-r–r-- 1 root root 1880 Jul 29 14:57 nvidia-drm-modeset.h
-rw-r–r-- 1 root root 2593 Jul 29 14:57 nvidia-drm-os-interface.h
-rw-r–r-- 1 root root 4011 Jul 29 14:57 nvidia-drm-priv.h
-rw-r–r-- 1 root root 9319 Jul 29 14:57 nvidia-drm-utils.c
-rw-r–r-- 1 root root 2907 Jul 29 14:57 nvidia-drm-utils.h
nvidia-modeset:
total 884
-rw-r–r-- 1 root root 2940 Jul 29 14:57 nvidia-modeset.Kbuild
-rw-r–r-- 1 root root 32235 Jul 29 14:57 nvidia-modeset-linux.c
-rw-r–r-- 1 root root 9214 Jul 29 14:57 nvidia-modeset-os-interface.h
-rw-r–r-- 1 root root 1900 Jul 29 14:57 nvkms.h
-rw-r–r-- 1 root root 1585 Jul 29 14:57 nvkms-ioctl.h
-rw-r–r-- 1 root root 843844 Jul 29 14:57 nv-modeset-kernel.o_binary
patches:
total 76
-rw-r–r-- 1 root root 824 Jul 29 14:57 allow_sublevel_greater_than_5.patch
-rw-r–r-- 1 root root 837 Jul 29 14:57 buildfix_kernel_3.0.patch
-rw-r–r-- 1 root root 18257 Jul 29 14:57 buildfix_kernel_3.10.patch
-rw-r–r-- 1 root root 2909 Jul 29 14:57 buildfix_kernel_3.11.patch
-rw-r–r-- 1 root root 1389 Jul 29 14:57 buildfix_kernel_3.13.patch
-rw-r–r-- 1 root root 1298 Jul 29 14:57 buildfix_kernel_3.14.patch
-rw-r–r-- 1 root root 737 Jul 29 14:57 buildfix_kernel_3.18.patch
-rw-r–r-- 1 root root 483 Jul 29 14:57 buildfix_kernel_3.6.patch
-rw-r–r-- 1 root root 761 Jul 29 14:57 buildfix_kernel_3.8.patch
-rw-r–r-- 1 root root 1114 Jul 29 14:57 buildfix_kernel_4.3.patch
-rw-r–r-- 1 root root 1673 Jul 29 14:57 buildfix_kernel_4.6.patch
-rw-r–r-- 1 root root 1478 Jul 29 14:57 buildfix_kernel_4.7.patch
-rw-r–r-- 1 root root 1503 Jul 29 14:57 make-use-of-the-new-uapi-framework.patch
-rw-r–r-- 1 root root 2589 Jul 29 14:57 register-VT-switch-requirements.patch
-rw-r–r-- 1 root root 829 Jul 29 14:57 replace-VM_RESERVED-with-VM_DONTEXPAND-and-VM_DONTDU.patch
