Fedora 25 - NVIDIA Quadro M2000M - Display Driver 375.20 - Kernel updates not forcing recompile via DKMS?
Hello NVIDIA community,
my employer just provided me a new notebook, a Dell Precision. I configured the notebook with a NVIDIA Quadro M2000M graphics.
I am running Fedora 25 OS. As I digged around, I found out, that there is the possibility of using some RPM Fusion repo driver for the Xorg server (Howto/NVIDIA - RPM Fusion). As there was a recent switch in Fedora from X11 to Wayland, I decided to stick with the solution to install the official NVIDIA display driver and disabling the nouveau driver.
I downloaded the recent matching NVIDIA driver package (375.20) here: Linux x64 (AMD64/EM64T) Display Driver | 375.20 | Linux 64-bit | NVIDIA. Then, I followed a procedure described here: Fedora 36/35/34 NVIDIA [515.65.01 / 510.85.02 / 470.141.03 / 390.154 / 340.108] Drivers Install Guide – If Not True Then False. This included booting Fedora in runlevel 3, disabling the nouveau driver, etc.
This was the best guide I found so far. Anyway, I had to add two seperate steps:
  1. Disabling secure boot while running the NVIDIA installer (due to a kernel error)
  2. After rebooting, I had to downgrade the “mutter” package from 3.22.2 to 3.22.1 (the most recent package caused a black screen after reboot, informations found here: https://www.reddit.com/r/archlinux/comments/5ce6a6/black_screen_on_gnome_login_and_xorgwayland_switch/)
So, after performing all those steps, I was able to startup Fedora running with the Quadro M2000M graphics. Calling the NVIDIA settings dialog (from shell: nvidia-settings), all informations there seem to prove a stable running NVIDIA graphics.
So, today, there was a Fedora update, including an upgrade of the kernel from 4.8.10 to 4.8.11. I downloaded the updates and rebooted my system and I ran into the same black screen problem. I was able to solve this problem by downloading the NVIDIA driver package again via wget from the shell in runlevel 3 and then running the installer again.
I suppose, this is not the way it is intended to work, as I registered the driver with DKMS and therefore I assume, the driver should have been recompiled for the new kernel. And I fairly doubt, I have to run this procedure over and over again, everytime there is a kernel update in my distribution.
Hence, this points toward my question to the community: What am I missing here? Why wasn’t the driver kernel module recompiled via DKMS? Is there anything in the nvidia-* command list, that provides some functionality regarding this problem?
After booting the new kernel, but before recompiling the driver, there were (obviously) error messages in the kernel ring buffer which I was able to grep throug dmesg output. After recompiling, there seems everything to be ok.
I appreciate any help.
Best regards
ne0h
