Fedora 41 cuda 12.9 issues with kernel 6.15 and compiling nvidia module for AD107GLM RTX 500 Ada Generation
hello,
I’m on fedora 41 and AD107GLM RTX 500 Ada Generation
since kernel 6.15.4 update, os updates are causing system failing to boot
this seems related on nviadia module compiling. If I reinstall the kernel, system boot again, however it seems nvidia module fails to compile
sudo dkms install -m nvidia -v 575.57.08
returns
Building module(s)…(bad exit status: 2)
Failed command:
‘make’ -j22 KERNEL_UNAME=6.15.4-100.fc41.x86_64 modules
Error! Bad return status for module build on kernel: 6.15.4-100.fc41.x86_64 (x86_64)
Consult /var/lib/dkms/nvidia/575.57.08/build/make.log for more information.
looking to the logs
ERROR: modpost: GPL-incompatible module nvidia.ko uses GPL-only symbol ‘__vma_start_write’
ERROR: modpost: GPL-incompatible module nvidia-drm.ko uses GPL-only symbol ‘__vma_start_write’
make[4]: *** [/usr/src/kernels/6.15.4-100.fc41.x86_64/scripts/Makefile.modpost:147: Module.symvers] Error 1
make[3]: *** [/usr/src/kernels/6.15.4-100.fc41.x86_64/Makefile:1993: modpost] Error 2
make[2]: *** [/usr/src/kernels/6.15.4-100.fc41.x86_64/Makefile:260: __sub-make] Error 2
make[2]: Leaving directory ‘/var/lib/dkms/nvidia/575.57.08/build’
make[1]: *** [Makefile:260: __sub-make] Error 2
make[1]: Leaving directory ‘/usr/src/kernels/6.15.4-100.fc41.x86_64’
make: *** [Makefile:140: modules] Error 2
exit code: 2
elapsed time: 00:00:38
Looking here, it seems driver 575.64 has fixed the issue.
umm .. so may nvidia still need to update the fedora repo
I can’t see it there Index of /compute/cuda/repos/fedora41/x86_64
and I’m using this repo
How often is the repository updated?
I have the same issue and am waiting for a driver that works. :/
