we are facing apt-get update failures when installing packages on our Jetson Orin devices. It started happening today.
This is the output of apt-get update
#9 4.159 Get:22 https://repo.download.nvidia.com/jetson/t234 r36.4/main arm64 Packages [14.5 kB]
#9 5.099 Fetched 34.1 MB in 1s (23.4 MB/s)
#9 5.099 Reading package lists...
#9 5.882 E: Failed to fetch https://repo.download.nvidia.com/jetson/common/dists/r36.4/main/binary-arm64/Packages.gz File has unexpected size (29274 != 29110). Mirror sync in progress? [IP: 2.19.176.194 443]
#9 5.882 Hashes of expected file:
#9 5.882 - Filesize:29110 [weak]
#9 5.882 - SHA256:671ef304e3a3fe86fcd0523c5e422c40fe1e25006c13754f810949bf1144876d
#9 5.882 - SHA1:dc2844c94b86f7927638e907e302811dd0acdb98 [weak]
#9 5.882 - MD5Sum:de772488865cf02aba6b1b4f6cdc344f [weak]
#9 5.882 Release file created at: Tue, 04 Feb 2025 00:09:42 +0000
#9 5.882 E: Some index files failed to download. They have been ignored, or old ones used instead.
We tried without success:
apt-get clean ; apt-get update
Is there a solution or a workaround for this?
I have figured out that putting this line to /etc/hosts will cause the connection to be made to the mirror hosted in Frankfurt, instead of the one in Ireland
2.23.209.41 repo.download.nvidia.com
However, this does not seem right, as it will break as soon as the IP changes.
Same here, yesterday I had no problems.
Happens the same to me today when flashing JetPack 6.2 with additional components using SDK manager on AGX Orin 64 Dev kit
Same here can not able to update . tried flash . but the result is same.
Same problem. Looks like this has occurred a few times in the past as well. Hopefully a fix soon
For information, do you observe the issue when using Jetpack 6.1 or 6.2?
Hi
I have same question on Jetapck 6.2 , when use “apt-get update” command…
I have the same problem today.
apt-get update on a board was good. Then just hours later, did the same on the other board, it failed
E: Failed to fetch https://repo.download.nvidia.com/jetson/common/dists/r36.4/main/binary-arm64/Packages.gz File has unexpected size (29274 != 29110). Mirror sync in progress? [IP: 23.201.103.234 443]
problematic is this repository:
Hence, it will fail for anyone trying to access and download files from this repository regardless of “Jetpack”. For example it fails on my desktop computer when building a docker image for L4T.
Why are you interested in Jetpack Version?
For anyone having this problem, i suggest adjusting your setup for the time being to make DNS resolve to another IP, i.e.
- modify
/etc/hosts
- if doing docker builds which has read the file readonly, use special argument
--add-host repo.download.nvidia.com=2.23.209.41
a few hours later, I did it again without changing anything, it was OK.
Looks like apt-get update will be failed while the repository is doing kind of backup/synchronization,
Same problem right now with 36.4
Hit:1 http://ports.ubuntu.com/ubuntu-ports jammy InRelease
Get:2 https://repo.download.nvidia.com/jetson/common r36.4 InRelease [2558 B]
Hit:3 http://ports.ubuntu.com/ubuntu-ports jammy-updates InRelease
Hit:4 https://repo.download.nvidia.com/jetson/ffmpeg r36.4 InRelease
Hit:5 http://ports.ubuntu.com/ubuntu-ports jammy-backports InRelease
Hit:6 http://ports.ubuntu.com/ubuntu-ports jammy-security InRelease
Get:7 https://repo.download.nvidia.com/jetson/common r36.4/main arm64 Packages [29.1 kB]
Err:7 https://repo.download.nvidia.com/jetson/common r36.4/main arm64 Packages
File has unexpected size (29274 != 29110). Mirror sync in progress? [IP: 104.109.250.149 443]
Fetched 2558 B in 1s (3734 B/s)
We are checking this server issue. A quick fix is applied and it should be good now. Please try again.
