That 165 MHz limit is reported by the hardware, but NoMaxPClkCheck should be overriding it. However, I found what looks like a bug that could be causing this problem. I’ll try to track down a similar display so I can check.
Related topics
| 4k@60Hz works in Windows, not in Linux *** Workaround found *** | 39 | 46139 | January 30, 2020 | |
| [384.69] hdmi max pixel clock too low | 2 | 2384 | October 9, 2017 | |
| 4K Output to Sony KD-65X9005A/XBR-65X900A | 15 | 8173 | September 24, 2013 | |
| Display Port display not using correct display mode | 11 | 977 | January 9, 2021 | |
| Linux Mint with latest nvidia drivers and 4K monitor only with 30Hz | 26 | 7443 | December 18, 2019 | |
| display zoomed with screen ViewSonic VX2435wm | 20 | 1760 | July 4, 2018 | |
| linux and gtx960 with hdmi2.0 not capable 3840x2160 60Hz | 2 | 1462 | January 29, 2015 | |
| 2560x1440@60 Hz mode stopped working over HDMI | 9 | 11856 | August 11, 2015 | |
| No 4k output over HDMI on a GTX 1050TI | 11 | 2493 | January 16, 2019 | |
| No display on 1440p monitor | 18 | 11701 | May 25, 2014 |
