Flash AGX Xavier error
Hi, I can’t relash my AGX.
Days ago, I flash my AGX Xavier to Jetpack 4.4, Now I wantto flash to Jetpack 4.3, it always has rpoblem, and stops at 99.8%.
Please help me. My host is a toshiba laptop with uuntu 18.04 installed.
here is some of the logs:
  • 16:10:03 ERROR : Flash Jetson AGX Xavier : 5019: SKP: 14213120( 3470 blks) ==> 4353403744:12
  • 16:10:03 ERROR : Flash Jetson AGX Xavier : 5020: RAW: 33394688( 8153 blks) ==> 4353403756:33394700
  • 16:10:04 ERROR : Flash Jetson AGX Xavier : 5021: SKP: 1375891456( 335911 blks) ==> 4386798456:12
  • 16:10:04 ERROR : Flash Jetson AGX Xavier : 5022: RAW: 12288( 3 blks) ==> 4386798468:12300
  • 16:10:04 ERROR : Flash Jetson AGX Xavier : 5023: SKP: 53248( 13 blks) ==> 4386810768:12
  • 16:10:04 ERROR : Flash Jetson AGX Xavier : 5024: RAW: 8192( 2 blks) ==> 4386810780:8204
  • 16:10:04 ERROR : Flash Jetson AGX Xavier : 5025: SKP: 57344( 14 blks) ==> 4386818984:12
  • 16:10:04 ERROR : Flash Jetson AGX Xavier : 5026: RAW: 2809856( 686 blks) ==> 4386818996:2809868
  • 16:10:04 ERROR : Flash Jetson AGX Xavier : 5027: SKP: 30744576( 7506 blks) ==> 4389628864:12
    delete some logs
  • 16:10:27 INFO : Flash Jetson AGX Xavier : [ 12.3412 ] Boot Rom communication
  • 16:10:27 INFO : Flash Jetson AGX Xavier : [ 12.3443 ] tegrarcm_v2 --chip 0x19 0 --rcm rcm_list_signed.xml
  • 16:12:27 INFO : Flash Jetson AGX Xavier : [ 12.3478 ] B
  • 16:27:09 INFO : Flash Jetson AGX Xavier : ootRom is not running
  • 16:27:09 INFO : Flash Jetson AGX Xavier : [ 17.6554 ]
  • 16:27:09 INFO : Flash Jetson AGX Xavier : [ 18.6611 ] tegrarcm_v2 --isapplet
Same problem here!
You are posting in the wrong forum. These should be in the Jetson AGX Xavier forum.
Moving this thread now.
Hence we are closing this topic. If need further support, please open a new one. Thanks
Hi yudong.fang and elia.bruni,
Is this still an issue at your site?
