Flash Failure - "ERROR: might be timeout in USB write" (tegrarcm_v2)
I’m trying to flash a Jetson Orin NX 16GB (AVerMedia D131L) using the provided BSP and JetPack 5.1.1. The flashing process fails consistently with the following error:
Details:
Host PC: Physical Ubuntu system (tested with both 18.04 and 20.04)
Connection: MicroUSB (Type-C not available on board)
Recovery mode was applied correctly
Tried 4 different USB cables
lsusb shows "NVIDIA Corp." when Jetson is connected
The error happens immediately after install.sh or flashcmd.txt is executed
Any help or guidance on resolving this USB write timeout would be appreciated.
install_log.txt (261.5 KB)
Please dump the serial console log from your jetson. That would help clarify.
Your only provided the host side log which is not sufficient.
