Jetson Orin NX:ERROR: might be timeout in USB write
The following error occurs when flashing Jetson Orin NX using SDK Manager:
SDKM_logs_JetPack_5.1.1_(rev._1)_Linux_for_Jetson_Orin_NX_16GB_2025-07-17_20-14-13.zip (208.8 KB)
20:21:45 INFO: exec_command [host]:
20:21:45 INFO: **********************
20:21:45 INFO: set -e
20:21:45 INFO: unset LC_ALL
20:29:38 ERROR: [   4.1812 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
20:29:38 ERROR: [   4.1813 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
20:29:38 ERROR: [   4.1815 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
20:33:31 ERROR: [   0.0179 ] ERROR: failed to read rcm_state
20:33:31 INFO: [   0.0179 ]
20:33:31 INFO: [   0.0235 ] tegrasign_v3.py --key None --getmode mode.txt
20:33:31 INFO: [   0.0237 ] Assuming zero filled SBK key
20:33:31 INFO: [   0.0182 ] Pre-processing config: tegra234-mb1-bct-device-p3767-0000.dts
20:33:31 INFO: [   0.0443 ] Pre-processing config: tegra234-mb1-bct-misc-p3767-0000.dts
20:33:31 INFO: [   0.0532 ] Parsing partition layout
20:33:31 INFO: [   0.1797 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
20:33:31 INFO: [   0.1983 ] adding BCH for mb2_t234_aligned.bin
20:33:31 INFO: [   0.2923 ] WARNING: boot chain is not completed. set to 0
20:33:31 INFO: [   0.2929 ] Get Signed section of bct
20:33:31 INFO: [   0.3154 ] Signing BCT
20:33:31 INFO: [   0.3210 ] tegrasign_v3.py --key None --list bct_list.xml --pubkeyhash pub_key.key --sha sha512
20:33:58 INFO: [   0.8787 ] Concatenating mb2-bct to mb2 binary
20:33:58 INFO: [   0.8818 ] Kernel DTB used: kernel_tegra234-p3767-0000-p3768-0000-a0.dtb
20:33:58 INFO: [   0.8818 ] kernel_dtb = kernel_tegra234-p3767-0000-p3768-0000-a0.dtb
20:33:58 INFO: [   0.8891 ] Creating list of images to be signed
20:33:58 INFO: [   0.8897 ] Generating ratchet blob
20:33:58 INFO: [   0.8897 ] Pre-processing config: tegra234-mb1-bct-reset-p3767-0000.dts
20:33:58 INFO: [   0.8939 ] Pre-processing config: tegra234-mb1-bct-device-p3767-0000.dts
20:33:58 INFO: [   0.8982 ] Pre-processing config: tegra234-mb1-bct-cprod-p3767-0000.dts
20:33:58 INFO: [   3.3232 ] Parsing config file :tegra234-mb1-bct-device-p3767-0000_cpp.dtb
20:33:59 INFO: [   4.1469 ] 32768+0 records in
20:34:12 INFO: [   0.1055 ] Added binary blob_nvdec_t234_prod_sigheader.fw.encrypt of size 294912
20:34:12 INFO: [   0.1067 ] Added binary blob_bpmp_t234-TE990M-A1_prod_sigheader.bin.encrypt of size 1048000
20:34:12 INFO: [   0.1072 ] Added binary blob_tegra234-bpmp-3767-0000-a02-3509-a02_with_odm_sigheader.dtb.encrypt of size 138880
20:34:12 INFO: [   0.1073 ] Added binary blob_camera-rtcpu-sce_sigheader.img.encrypt of size 166304
20:34:12 INFO: [   0.1075 ] Added binary blob_camera-rtcpu-t234-rce_sigheader.img.encrypt of size 537952
20:34:12 INFO: [   0.1076 ] Added binary blob_adsp-fw_sigheader.bin.encrypt of size 400960
20:34:12 INFO: [   0.1077 ] Added binary blob_spe_t234_sigheader.bin.encrypt of size 270336
20:34:12 INFO: [   0.1078 ] Added binary blob_tos-optee_t234_sigheader.img.encrypt of size 1064752
20:34:12 INFO: [   0.1081 ] Added binary blob_eks_t234_sigheader.img.encrypt of size 9232
20:34:12 INFO: [   0.1082 ] Added binary blob_boot0.img of size 55420928
20:34:12 INFO: [   0.1336 ] Added binary blob_tegra234-p3767-0000-p3768-0000-a0.dtb of size 344703
20:34:13 INFO: [   0.1738 ] tegrarcm_v2 --instance 1-8 --chip 0x23 0 --pollbl --download bct_mem mem_rcm_sigheader.bct.encrypt --download blob blob.bin
20:34:13 INFO: [   0.1743 ] BL: version 0.32.0.0-t234-54845784-57325615 last_boot_error: 0
20:34:13 INFO: [   0.2973 ] Sending bct_mem
20:34:13 INFO: [   0.3041 ] Sending blob
20:34:18 ERROR: [   0.3950 ] ERROR: might be timeout in USB write.
20:34:18 ERROR: Error: Return value 3
20:34:18 INFO: Command tegrarcm_v2 --instance 1-8 --chip 0x23 0 --pollbl --download bct_mem mem_rcm_sigheader.bct.encrypt --download blob blob.bin
20:34:18 INFO: Cleaning up...
20:34:18 ERROR: [exec_command]: /bin/bash -c /home/cai_kun/.nvsdkm/replays/scripts/JetPack_5.1.1_Linux/NV_L4T_FLASH_JETSON_LINUX_COMP.sh; [error]: 83156 blocks
20:34:18 INFO: [ Component Install Finished with Error ]
20:34:18 INFO: [host] [ 16.72 GB used. Disk Avail on Partition /dev/sda: 731.05 GB ]
20:34:18 INFO: [ NV_L4T_FLASH_JETSON_LINUX_COMP Install took 12m32s ]
20:34:18 ERROR: command error code: 11
20:34:18 ERROR: command terminated with error
20:34:18 SUMMARY: Installation failed.
If you use a VM, then the VM is likely the issue. Otherwise I don’t know; you might try a different port on the host PC, or different USB cable (but I’ve not seen USB-C cables fail, this is usually a topic for the micro-OTC cables).
I’m using an x86 desktop with Ubuntu 20 installed. It used to work fine for flashing, but suddenly it doesn’t. Here’s what I’ve done so far:
  1. Replaced the NX module.
  2. Switched to a different USB cable.
  3. Tried a different port on the host machine.
    Currently, I’m testing by replacing the baseboard.
Some questions to confirm:
  • Is your carrier board a dev kit or a custom board?
Could you flash with the latest JP6.2 to cross check the issue?
It’s really surprising that flashing Jetpack 6.2 works. But why can’t Jetpack 5.1.1 be flashed?
Most likely due to the PCN update.
Old BSP could not directly flash new modules.
Okay, thank you.
