When we tried to flash Jetson Orin NX with BSP version L4TR35.3.1 Flashing failed on the "Step 3: Start the flashing process” step
Its failing at the below point
Waiting for target to boot-up…
Timeout
Cleaning up…
Below is command we have used for flashing
sudo ./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1p1 -c tools/kernel_flash/flash_l4t_external.xml -p “-c bootloader/t186ref/cfg/flash_t234_qspi.xml” --showlogs --network usb0 jetson-orin-nano-devkit internal
You don’t need to show a default nvidia device tree to a nvidia engineer. We already knew that.
What you need to care is whether this device tree really matches your hardware or not. I don’t know you or your hardware, so I cannot answer. But based on my experience, most of them do not match…
Below is the attached tegra234-p3768-0000-a0.dts file from the path public/hardware/nvidia/platform/t23x/p3768/kernel-dts/cvb which is used. Sorry for the confusion.
Are you really the software engineer handling this thing?
I am not sure what you are doing here. You told us you changed file A, and looks like file A is not in use. Then you give me file B but file B seems not have your modification.
Changing the companion as per the hardware design.
First file “tegra234-p3509-a02.dts” which I shared was used along with enabling HDMI-4k with below configuration in file “jetson-orin-nano-devkit.conf”.
PINMUX_CONFIG=“tegra234-mb1-bct-pinmux-p3767-hdmi-a03.dtsi”;
PMC_CONFIG=“tegra234-mb1-bct-padvoltage-p3767-hdmi-a03.dtsi”;
DTB_FILE=“tegra234-p3767-0000-p3509-a02.dtb”;
Second file “tegra234-p3768-0000-a0.dts” which I shared was used along with configuration file enabling dp with below configuration in file “jetson-orin-nano-devkit.conf”.
DEFAULT_EMC_FUSE=“0”;
PINMUX_CONFIG=“tegra234-mb1-bct-pinmux-p3767-dp-a03.dtsi”;
PMC_CONFIG=“tegra234-mb1-bct-padvoltage-p3767-dp-a03.dtsi”;
DTB_FILE=“tegra234-p3767-0000-p3768-0000-a0.dtb”;
In both case we are facing flashing issue when we change the companion in the respective files. The logs(uart and host log) captured with dp enabled in the config file.
Below are the changes which we have done in tegra234-p3768-0000-a0.dts in the path public/hardware/nvidia/platform/t23x/p3768/kernel-dts/cvb. Below mentioned changes are present in the above attached file “tegra234-p3768-0000-a0”
ports {
usb2-0 {/* Goes to recovery port */
mode = "otg";
status = "okay";
vbus-supply = <&p3768_vdd_5v_sys>;
usb-role-switch;
port {
typec_p0: endpoint {
remote-endpoint = <&fusb_p0>;
usb2-1 {/* Goes to hub */
mode = "host";
vbus-supply = <&p3768_vdd_av10_hub>;
status = "okay";
usb2-2 {/* Goes to M2.E */
mode = "host";
status = "okay";
usb3-0 {/* Goes to hub */
nvidia,usb2-companion = <0>;
status = "okay";
usb3-1 {/* Goes to J5 */
nvidia,usb2-companion = <1>;
status = "okay";
usb3-2 {
nvidia,usb2-companion = <2>;
status = "okay";
Please suggest if any further changes are required as per the hardware design change.
I don’t know your board.
Your just gave me a device tree which seems just a NVIDIA board configuration.
For example, do you use fusb301 as type C controller here? If not, then why do you leave type C controller configuration inside the device tree?
If you don’t know what I am talking about, that is the problem. Read the document first but not keep asking a stranger like me to fix your device tree.
I totally don’t know your hardware at all. Your info is not sufficient either. The mapping of usb 2 + usb3 is just a small info. You didn’t share any other info to us.
Of course you hit flash issue on both device tree, because none of them matches your board design.
