Flashing J401 with NX16GB board
Hi all,
I have been trying to flash Jetpack 6 on a NX 16GB module with a J401 custom board.
Every time it gets stuck at “Waiting for target to boot-up…”
I have been using this command :
sudo ./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1p1 -c tools/kernel_flash/flash_l4t_external.xml -p "-c bootloader/generic/cfg/flash_t234_qspi.xml" --showlogs --network usb0 p3509-a02-p3767-0000 internal
and tried many combinations of similar commands.
Did anyone have clues on how to make it work on this carrier boards ?
For any custom board, please check with the vendor if they have updated the BSP to match new BSP.
I will be also trying this later today.
According to this link reComputer J30 Series, J40 Series | J401 | Seeed Studio Wiki the board uses the BSP downloaded from NVidia.
At least one user suggests it’s doable:
Then please try to dump the uart console from device when flash failure happened.
I’ve only just started dabbling with Jetson so I don’t know to do that yet.
Here is the log from the flash command though, in case that helps.
log.txt (236.3 KB)
Ok, if this is first time, then please check this page and buy the cable first.
