Flashing Jetpack 6.2 Fails with netcat error
I am using sdk manager to reflash a Jetson Orin Nano.
All downloads are checked and verified.
However flashing fails with an error:
12:17:25 ERROR: File System and OS - target_image: E: Unable to locate package netcat-openbsd-openbsd
12:17:25 ERROR: File System and OS - target_image: [exec_command]: /bin/bash -c /home/simond/.nvsdkm/replays/scripts/JetPack_6.2_Linux/NV_L4T_FILE_SYSTEM_AND_OS_COMP.sh; [error]: E: Unable to locate package netcat-openbsd-openbsd
12:17:25 INFO: File System and OS - target_image: [ Package Install Finished with Error ]
12:17:25 INFO: File System and OS - target_image: [host] [ 5.52 GB used. Disk Avail on Partition /dev/sda2: 152.25 GB ]
12:17:25 INFO: File System and OS - target_image: [ NV_L4T_FILE_SYSTEM_AND_OS_COMP Install took 3m15s ]
12:17:25 ERROR: command error code: 11
12:17:25 ERROR: File System and OS - target_image: command terminated with error
Seems like a problon the flashing script.
How can this be fixed or is there a work around?
I’m using Ubuntu 24.04.
Apparently only versions 22.04 and 20.04 are supported while 24.04 is there in the source/config but not yet supported.
See file $HOME/nvidia/nvidia_sdk/JetPack_6.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/tools/l4t_flash_prerequisites_2404.sh
It contains package_list, a list of required packages. For a reason it requires “netcat-openbsd-openbsd” (no such package in ubuntu) while the non-24.04 version require a proper “netcat-openbsd”.
I guess nobody tests it on 24.04.
I’ve got a workaround for flashing Jetpack 6.2 on Ubuntu 24.04.
You have to spoof the Ubuntu version number. To do so, modify /etc/os-release (e.g. “sudo vi /etc/os-release”),
change line VERSION_ID to version 22.04, i.e.:
VERSION_ID=“22.04”
Test with command:
lsb_release -r
Don’t forget to rollback the change and test the rollback (lsb_release -r) afterwards to avoid any unexpected problems with other software on your system.
