Have a good day, everyone. I’m using the Jetson Orin Nano 8GB Developer Kit. I’m facing an issue: I want to completely reinstall the system.
I launch SDK Manager, connect the device via USB Type-C, short the RECOVERY and GND pins, then connect the power supply. In lsusb, the device shows up as:
Bus 001 Device 025: ID 0955:7523 NVIDIA Corp. APX
I start the reinstallation process, but it always fails with an error during the Linux flashing stage.
I’m using Ubuntu 22.04 on the host and trying to install JetPack 6.0. The board is original, and I’m using a 256GB NVMe drive.
Here is the error:
18:55:15 ERROR: Flash Jetson Linux - flash: [exec_command]: /bin/bash -c /home/aboba/.nvsdkm/replays/scripts/JetPack_6.0_Linux/NV_L4T_FLASH_JETSON_LINUX_COMP.sh; [error]: 129884 blocks
18:55:15 INFO: Flash Jetson Linux - flash: [ Component Install Finished with Error ]
18:55:15 INFO: Flash Jetson Linux - flash: [host] [ 4.06 MB used. Disk Avail on Partition /dev/sda2: 289.09 GB ]
18:55:15 INFO: Flash Jetson Linux - flash: [ NV_L4T_FLASH_JETSON_LINUX_COMP Install took 5m33s ]
18:55:15 ERROR: command error code: *11*
18:55:15 ERROR: Flash Jetson Linux - flash: command terminated with error
18:55:15 SUMMARY: Flash Jetson Linux - flash: First Error: Installation failed
I’ve attached the log file. Thank you in advance for your help.
SDKM_logs_JetPack_6.0_(rev._2)Linux_for_Jetson_Orin_Nano[8GB_developer_kit_version]_2025-05-07_18-49-17.zip|attachment (329.9 KB)
