With reference to the Jetson Orin Nano Developer Kit and SDK-Manager
Hi team,
With reference to the Jetson Orin Nano Developer Kit. I am Installing Jetson Software with SDK Manager. In the following process, after manually setting up there are the following issues on the installation.
ERROR: Flash Jetson Linux - flash 52057 blocks
ERROR: Flash Jetson Linux - 20+0 records in
ERROR: Flash Jetson Linux - flash: ERROR: failed to read rcm_state
ERROR: Flash Jetson Linux - flash: [3.5363] ERROR: value0x31 is out of range
ERROR: Flash Jetson Linux - flash: [3.5382] ERROR: value0x31 is out of range
ERROR: Flash Jetson Linux - flash: [3.5385] ERROR: value0x31 is out of range
ERROR: Flash Jetson Linux - flash: tar: Write checkout 40000
ERROR: Flash Jetson Linux - flash: tar: Write checkout 50000
ERROR: Flash Jetson Linux - flash: nt: 150000
ERROR: Flash Jetson Linux - flash: 74756 blocks
ERROR: Flash Jetson Linux - flash: 128307 blocks
SUMMARY: Flash Jetson Linux - flash: First Error: No such file or directory
How to resolve them all?
The following LOG files are attached below.
SDKM_logs_JetPack_6.0_DP_Linux_for_Jetson_Orin_Nano_modules_2024-03-06_16-16-20.zip (271.1 KB)
Are you using VM or host PC with Ubuntu 20.04?
Which JetPack SW you’re installing?
Dump the full log, please.
Fragments help nothing at all.
Use the export button of SDK Manager; it will give you a .zip file containing everything.
The log you updated later does not help either.
Updated.
Error: Could not stat device /dev/nvme0n1 - No such file or directory.
Flash failure
Cleaning up...
So that means your Jetson device cannot find the NVMe drive to be flashed.
Consider the following:
  1. Format the NVMe drive before flashing.
  2. Find another NVMe drive for test
  3. Use a USB drive instead
you mean instead of flashing it to the jetson board nvme drive , do we have to install it in a usb drive?
I recommend that you disconnect the Jetson from the host, then disconnect the power supply to the Jetson. and reseat the NVMe securely. After that you can try again to see if the NVMe SSD goes up.
please let me know how can we reset the nvme drive of jetson board?
By reseating the NVMe drive, I mean that unplugging the NVMe SSD from the Jetson Orin Nano, and then replug it into the M.2 slot. You can watch the section “Install SSD” of this video for more information
