Flashing Orion NX on SEED reComputer J4012 - Success
Hi reflashed the Orion Nx 16 Modul, i needed multiple attemps but finally succeded.
Main Issure for me was a falling at flashing the OS at an status over 90%. I found out that i had just to had to allow the installation, to take longer then exspected.
I have highlighted chooses of mine, which i think, helped to succed.
My system setup:
Target Jetson:
  • hardware: Orion NX 16 Gb
  • custom board: reComputer J4012
  • SSD: 2TB M2 Samsung 970 EvoPlus SSD
Host machine:
  • VMware Workstation 17 Player
  • Ubuntu 22.04.4 LTS
    VMWaresettings:
  • USB Controller USB compatibillity USB 3.1
  • Serial Port - Connection - Use physical serial port
  • Serial Port - I/O Mode - Use Yield CPU on poll
Steps:
  • Installing newest SDK-Manager
  • Running SDK-Manager
  • Connecting Jetson over USB-C
  • Choose to always connect USB-Device to VM-Ware
  • Choose Installation of Jetpack 6DP
  • Disconnecting and Connecting NVME SDD as suggested
  • Detecting Orion NX 16 GB
  • Choose Manual Recovery Mode
  • Choose pre-oem
  • Choose on run-time
  • Choose NVME
  • PowerOff Jetson
  • Ground FC Rec Pin to GND with a jumper wire
  • PowerOn Jetson
  • Refresh at the TOP of the screen to find new connected jetson, and enable the Flash button
  • Flash
  • Disconnect Jumper Wire from Ground
  • It takes long to load the parts and some Errors occure in the terminal, which resolve them self
  • After a while the jetson reboots and only a “_” is seen on the connected display
  • Accepting to take longer then accepted for installation
  • Jetson rebooted with the new Jetpack Version.
I have added the full lok from my last two installation attemps. Feel free to leave a comment or explainations why it takes so really long, to flash the jetpack os.
SDKM_logs_2024-04-24_07-49-01.zip (788.3 KB)
So what’s the issue now?
You think it’s not supposed to take that long time?
for the failing attempts you ended up with
NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_ORIN_NX_TARGETS: Waiting for target to boot-up…
21:19:57.722 - info: NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_ORIN_NX_TARGETS: Waiting for target to boot-up…
21:19:59.892 - info: NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_ORIN_NX_TARGETS: Waiting for target to boot-up…
21:20:00.899 - info: NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_ORIN_NX_TARGETS: Timeout
21:20:00.900 - info: NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_ORIN_NX_TARGETS: Cleaning up…
21:20:01.213 - error: NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_ORIN_NX_TARGETS: [exec_command]: /bin/bash -c /tmp/tmp_NV_L4T_FLASH_JETSON_LINUX_COMP.bam.sh; [error]: 128422 blocks
This means that the device fails to expose the usb device mode related to flashing. It could be a known flashing bug on jp6.0 dp like this Jetson orin nano - jetpack 6 not flashing with SDK manager ubuntu 22.04 - #12 by DaveYYY
There is no issue.
Main goal of the post was, 1. to illustrate how a flashing was possible, using VMWare. 2. See if somebody can explain me the errors which occurred.
The discussion can be closed, from my point of view.
Thanks for the explanation. At the time it succeeded, USB-Devices (Mouse and keyboard) where connected.
