Hey, please i need some help , i am using jeston orin 64GB developer kit , i am trying to flash it from my pc with Virtualbox ubuntu, i did all the instructions in the nvidia guide (version (35.5.0), i am facing a problem in the flashing step,
[ 2.8044 ] MB1-BCT version: 0.12
[ 2.8045 ] ERROR: /misc/enable_dram_page_blacklisting is not supported
[ 2.8077 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED1/ is not supported
[ 2.8135 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED1/ is not supported
[ 2.8144 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED1/ is not supported
[ 2.8228 ] ERROR: /misc/tsc_controls/tsc_locking_config is not supported
[ 2.8268 ] ERROR: /misc/tsc_controls/tsc_locking_diff_configuration is not supported
[ 2.8271 ] ERROR: /misc/tsc_controls/tsc_locking_ref_frequency_configuration is not supported
[ 2.8273 ] ERROR: /misc/tsc_controls/tsc_locking_control is not supported
[ 2.8275 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_configuration is not supported
[ 2.8287 ] ERROR: /misc/tsc_controls/tsc_locking_fast_adjust_configuration is not supported
[ 2.8288 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_delta_control is not supported
[ 2.8289 ] ERROR: /misc/tsc_controls/tsc_capture_control_ptx is not supported
[ 2.8290 ] ERROR: /misc/tsc_controls/tsc_capture_config_ptx is not supported
[ 2.8291 ] ERROR: /misc/tsc_controls/tsc_stscrsr is not supported
[ 2.8291 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_num_control is not supported
[ 2.8447 ] Parsing config file :tegra234-mb1-bct-pinmux-p3701-0000-a04_cpp.dtb
[ 2.8460 ] Added Platform Config 0 data with size :- 2936
[ 2.8586 ] Parsing config file :tegra234-mb1-bct-padvoltage-p3701-0000-a04_cpp.dtb
[ 2.8589 ] WARNING: unknown node ‘g2’
[ 2.8601 ] WARNING: unknown node ‘g2’
[ 2.8602 ] WARNING: unknown node ‘g9’
[ 2.8642 ] WARNING: unknown node ‘g9’
[ 2.8643 ] Added Platform Config 2 data with size :- 24
[ 2.8644 ] Parsing config file :tegra234-mb1-bct-pmic-p3701-0005_cpp.dtb
[ 2.8644 ] Added Platform Config 4 data with size :- 580
[ 2.8656 ] Parsing config file :tegra234-mb1-bct-reset-p3701-0000_cpp.dtb
[ 2.8658 ] Added Platform Config 3 data with size :- 52
[ 2.8660 ] Parsing config file :tegra234-mb1-bct-prod-p3701-0000_cpp.dtb
[ 2.8661 ] WARNING: unknown property ‘major’
[ 2.8662 ] WARNING: unknown property ‘minor’
[ 2.8758 ] Added Platform Config 5 data with size :- 524
[ 2.8759 ] Parsing config file :tegra234-mb1-bct-gpioint-p3701-0000_cpp.dtb
[ 2.8760 ] WARNING: unknown property ‘major’
[ 2.8777 ] WARNING: unknown property ‘minor’
[ 2.8783 ] Added Platform Config 7 data with size :- 380
[ 2.8787 ] Parsing config file :tegra234-mb1-bct-uphylane-si_cpp.dtb
[ 2.8790 ] Added Platform Config 8 data with size :- 24
[ 2.8798 ] Parsing config file :tegra234-mb1-bct-device-p3701-0000_cpp.dtb
[ 2.8799 ] Added Platform Config 9 data with size :- 100
[ 2.8808 ] Parsing config file :tegra234-mb1-bct-cprod-p3701-0000_cpp.dtb
[ 2.8810 ] ModuleCount 0 NumProdNames 0
[ 2.8810 ] Added Platform Config 6 data with size :- 16
[ 2.8810 ] Parsing config file :tegra234-mb1-bct-ratchet-p3701-0000_cpp.dtb
[ 2.8813 ] Updating mb1-bct with firmware information
[ 2.8819 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo flash.xml.bin
[ 2.9207 ] tegrahost_v2 --chip 0x23 0 --align mb1_cold_boot_bct_MB1_aligned.bct
[ 2.9247 ] Generating SHA2 Hash for mb1bct
[ 2.9425 ] Sha saved in mb1_cold_boot_bct_MB1_aligned.sha
[ 2.9657 ] Sha saved in mb1_cold_boot_bct_MB1.sha
[ 2.9621 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --ratchet_blob ratchet_blob.bin --appendsigheader mb1_cold_boot_bct_MB1_aligned.bct zerosbk
[ 2.9625 ] adding BCH for mb1_cold_boot_bct_MB1_aligned.bct
[ 2.9716 ] tegrasign_v3.py --key None --list mb1_cold_boot_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[ 2.9718 ] Assuming zero filled SBK key
[ 3.0130 ] Warning: pub_key.key is not found
[ 3.0098 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_cold_boot_bct_MB1_aligned_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_aligned_sigheader.bct.hash zerosbk
[ 3.0273 ] tegrahost_v2 --chip 0x23 0 --partitionlayout flash.xml.bin --ratchet_blob ratchet_blob.bin --list images_list.xml zerosbk
[ 3.0297 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[ 3.0306 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[ 3.0321 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[ 3.0593 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[ 3.0595 ] Header already present for nvdec_t234_prod_aligned.fw
[ 3.0782 ] adding BCH for mb2_t234_with_mb2_cold_boot_bct_MB2_aligned.bin
[ 3.0869 ] adding BCH for xusb_t234_prod_aligned.bin
[ 3.1213 ] Header already present for bpmp_t234-TE990M-A1_prod_aligned.bin
[ 3.1414 ] adding BCH for tegra234-bpmp-3701-0005-3737-0000_with_odm_aligned.dtb
[ 3.1742 ] Header already present for pscfw_t234_prod_aligned.bin
[ 3.2213 ] Header already present for mce_flash_o10_cr_prod_aligned.bin
[ 3.2321 ] Header already present for sc7_t234_prod.bin
[ 3.2463 ] Header already present for psc_rf_t234_prod_aligned.bin
[ 3.2567 ] adding BCH for mb2rf_t234_aligned.bin
[ 3.2653 ] INFO: compressing uefi_jetson_with_dtb_aligned.bin
[ 3.3404 ] INFO: complete compression, uefi_jetson_with_dtb_aligned.bin, ratio = 87%
[ 3.3638 ] adding BCH for uefi_jetson_with_dtb_aligned_blob_w_bin_aligned.bin
[ 3.4521 ] adding BCH for tos-optee_t234_aligned.img
[ 3.5462 ] adding BCH for eks_t234_aligned.img
[ 3.5600 ] INFO: compressing display-t234-dce_with_kernel_tegra234-p3701-0005-p3737-0000_aligned.bin
[ 3.6807 ] INFO: complete compression, display-t234-dce_with_kernel_tegra234-p3701-0005-p3737-0000_aligned.bin, ratio = 7%
[ 3.7177 ] adding BCH for display-t234-dce_with_kernel_tegra234-p3701-0005-p3737-0000_aligned_blob_w_bin_aligned.bin
[ 3.7657 ] adding BCH for spe_t234_aligned.bin
[ 3.7939 ] adding BCH for camera-rtcpu-t234-rce_aligned.img
[ 3.8055 ] adding BCH for adsp-fw_aligned.bin
[ 3.8361 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[ 3.8618 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[ 3.8638 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[ 3.8959 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[ 3.8980 ] Header already present for nvdec_t234_prod_aligned.fw
[ 3.9005 ] adding BCH for mb2_t234_with_mb2_cold_boot_bct_MB2_aligned.bin
[ 3.9392 ] adding BCH for xusb_t234_prod_aligned.bin
[ 3.9551 ] Header already present for bpmp_t234-TE990M-A1_prod_aligned.bin
[ 3.9848 ] adding BCH for tegra234-bpmp-3701-0005-3737-0000_with_odm_aligned.dtb
[ 4.0277 ] Header already present for pscfw_t234_prod_aligned.bin
[ 4.0554 ] Header already present for mce_flash_o10_cr_prod_aligned.bin
[ 4.0733 ] Header already present for sc7_t234_prod.bin
[ 4.0893 ] Header already present for psc_rf_t234_prod_aligned.bin
[ 4.0931 ] adding BCH for mb2rf_t234_aligned.bin
[ 4.0989 ] INFO: compressing uefi_jetson_with_dtb_aligned.bin
[ 4.1963 ] INFO: complete compression, uefi_jetson_with_dtb_aligned.bin, ratio = 87%
[ 4.1977 ] adding BCH for uefi_jetson_with_dtb_aligned_blob_w_bin_aligned.bin
[ 4.2742 ] adding BCH for tos-optee_t234_aligned.img
[ 4.3400 ] adding BCH for eks_t234_aligned.img
[ 4.3882 ] INFO: compressing display-t234-dce_with_kernel_tegra234-p3701-0005-p3737-0000_aligned.bin
[ 4.5359 ] INFO: complete compression, display-t234-dce_with_kernel_tegra234-p3701-0005-p3737-0000_aligned.bin, ratio = 7%
[ 4.5699 ] adding BCH for display-t234-dce_with_kernel_tegra234-p3701-0005-p3737-0000_aligned_blob_w_bin_aligned.bin
[ 4.6062 ] adding BCH for spe_t234_aligned.bin
[ 4.6579 ] adding BCH for camera-rtcpu-t234-rce_aligned.img
[ 4.6750 ] adding BCH for adsp-fw_aligned.bin
[ 4.7570 ] Filling MB1 storage info
[ 4.7572 ] Parsing dev params for multi chains
[ 4.7694 ] Generating br-bct
[ 4.7700 ] Updating dev and MSS params in BR BCT
[ 4.7701 ] tegrabct_v2 --dev_param tegra234-br-bct-p3701-0000_cpp.dtb --sdram tegra234-p3701-0005-sdram-l4t_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[ 4.8918 ] Updating bl info
[ 4.9009 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo flash.xml.bin
[ 4.9489 ] Generating br-bct
[ 4.9494 ] Updating dev and MSS params in BR BCT
[ 4.9495 ] tegrabct_v2 --dev_param tegra234-br-bct_b-p3701-0000_cpp.dtb --sdram tegra234-p3701-0005-sdram-l4t_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[ 5.0782 ] Updating bl info
[ 5.0934 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo flash.xml.bin
[ 5.1364 ] Generating BCT backup image
[ 5.1365 ] dd if=/dev/zero of=bct_backup.img bs=1 count=32768
[ 5.1375 ] 32768+0 enregistrements lus
[ 5.1748 ] 32768+0 enregistrements écrits
[ 5.1752 ] 32768 octets (33 kB, 32 KiB) copiés, 0,036486 s, 898 kB/s
[ 5.1760 ] Concatenating BCT for chain A to bct_backup.img
[ 5.1760 ] dd if=br_bct_BR.bct of=bct_backup.img bs=1 seek=0 conv=notrunc
[ 5.1772 ] 8192+0 enregistrements lus
[ 5.1843 ] 8192+0 enregistrements écrits
[ 5.1843 ] 8192 octets (8,2 kB, 8,0 KiB) copiés, 0,00504186 s, 1,6 MB/s
[ 5.1846 ] Concatenating BCT for chain B to bct_backup.img
[ 5.1847 ] dd if=br_bct_b_BR.bct of=bct_backup.img bs=1 seek=16384 conv=notrunc
[ 5.1857 ] 8192+0 enregistrements lus
[ 5.1908 ] 8192+0 enregistrements écrits
[ 5.1909 ] 8192 octets (8,2 kB, 8,0 KiB) copiés, 0,00368495 s, 2,2 MB/s
[ 5.2141 ] Generating signatures
[ 5.2189 ] tegrasign_v3.py --key None --list images_list.xml --pubkeyhash pub_key.key --sha sha512
[ 5.2190 ] Assuming zero filled SBK key
[ 5.7009 ] Warning: pub_key.key is not found
[ 5.7142 ] Parsing dev params for multi chains
[ 5.7143 ] Generating br-bct
[ 5.7158 ] Updating dev and MSS params in BR BCT
[ 5.7158 ] tegrabct_v2 --dev_param tegra234-br-bct-p3701-0000_cpp.dtb --sdram tegra234-p3701-0005-sdram-l4t_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[ 5.8392 ] Updating customer data section
[ 5.8517 ] tegrabct_v2 --chip 0x23 0 --brbct br_bct_BR.bct --update_custinfo custinfo_out.bin
[ 5.8727 ] Updating bl info
[ 5.8812 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
[ 5.9329 ] Get Signed section of bct
[ 5.9433 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --listbct bct_list.xml
[ 5.9788 ] Signing BCT
[ 5.9836 ] tegrasign_v3.py --key None --list bct_list.xml --pubkeyhash pub_key.key --sha sha512
[ 5.9837 ] Assuming zero filled SBK key
[ 6.0157 ] Sha saved in br_bct_BR.sha
[ 6.0166 ] Warning: pub_key.key is not found
[ 6.0119 ] Updating BCT with signature
[ 6.0125 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesig bct_list_signed.xml
[ 6.0146 ] Offset :4608 Len :3584
[ 6.0418 ] Generating SHA2 Hash
[ 6.0466 ] tegrasign_v3.py --key None --list bct_list.xml --sha sha512
[ 6.0467 ] Assuming zero filled SBK key
[ 6.0468 ] Assuming zero filled SBK key
[ 6.0749 ] Sha saved in br_bct_BR.sha
[ 6.0712 ] Updating BCT with SHA2 Hash
[ 6.0718 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesha bct_list_signed.xml
[ 6.0734 ] Offset :4608 Len :3584
[ 6.0742 ] Offset :68 Len :8124
[ 6.0758 ] Generating br-bct
[ 6.0797 ] Updating dev and MSS params in BR BCT
[ 6.0797 ] tegrabct_v2 --dev_param tegra234-br-bct_b-p3701-0000_cpp.dtb --sdram tegra234-p3701-0005-sdram-l4t_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[ 6.2171 ] Updating customer data section
[ 6.2279 ] tegrabct_v2 --chip 0x23 0 --brbct br_bct_BR.bct --update_custinfo custinfo_out.bin
[ 6.2749 ] Updating bl info
[ 6.2757 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
[ 6.3218 ] Get Signed section of bct
[ 6.3359 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --listbct bct_list.xml
[ 6.3760 ] Signing BCT
[ 6.3809 ] tegrasign_v3.py --key None --list bct_list.xml --pubkeyhash pub_key.key --sha sha512
[ 6.3810 ] Assuming zero filled SBK key
[ 6.4175 ] Sha saved in br_bct_BR.sha
[ 6.4185 ] Warning: pub_key.key is not found
[ 6.4138 ] Updating BCT with signature
[ 6.4147 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesig bct_list_signed.xml
[ 6.4149 ] Offset :4608 Len :3584
[ 6.4196 ] Generating SHA2 Hash
[ 6.4244 ] tegrasign_v3.py --key None --list bct_list.xml --sha sha512
[ 6.4245 ] Assuming zero filled SBK key
[ 6.4592 ] Sha saved in br_bct_BR.sha
[ 6.4558 ] Updating BCT with SHA2 Hash
[ 6.4567 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesha bct_list_signed.xml
[ 6.4582 ] Offset :4608 Len :3584
[ 6.4606 ] Offset :68 Len :8124
[ 6.4606 ]
[ 6.4607 ] Generating BCT backup image
[ 6.4608 ] dd if=/dev/zero of=bct_backup.img bs=1 count=32768
[ 6.4611 ] 32768+0 enregistrements lus
[ 6.4841 ] 32768+0 enregistrements écrits
[ 6.4843 ] 32768 octets (33 kB, 32 KiB) copiés, 0,0205352 s, 1,6 MB/s
[ 6.4846 ] Concatenating BCT for chain A to bct_backup.img
[ 6.4846 ] dd if=br_bct_BR.bct of=bct_backup.img bs=1 seek=0 conv=notrunc
[ 6.4851 ] 8192+0 enregistrements lus
[ 6.5013 ] 8192+0 enregistrements écrits
[ 6.5014 ] 8192 octets (8,2 kB, 8,0 KiB) copiés, 0,00361465 s, 2,3 MB/s
[ 6.5014 ]
[ 6.5014 ] Concatenating BCT for chain B to bct_backup.img
[ 6.5015 ] dd if=br_bct_b_BR.bct of=bct_backup.img bs=1 seek=16384 conv=notrunc
[ 6.5027 ] 8192+0 enregistrements lus
[ 6.5173 ] 8192+0 enregistrements écrits
[ 6.5174 ] 8192 octets (8,2 kB, 8,0 KiB) copiés, 0,013222 s, 620 kB/s
[ 6.5221 ] Generating coldboot mb1-bct
[ 6.5224 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct.cfg --misc tegra234-mb1-bct-misc-p3701-0000_cpp.dtb --wb0sdram tegra234-p3701-0005-wb0sdram-l4t_cpp.dtb --pinmux tegra234-mb1-bct-pinmux-p3701-0000-a04_cpp.dtb --pmc tegra234-mb1-bct-padvoltage-p3701-0000-a04_cpp.dtb --pmic tegra234-mb1-bct-pmic-p3701-0005_cpp.dtb --brcommand tegra234-mb1-bct-reset-p3701-0000_cpp.dtb --prod tegra234-mb1-bct-prod-p3701-0000_cpp.dtb --gpioint tegra234-mb1-bct-gpioint-p3701-0000_cpp.dtb --uphy tegra234-mb1-bct-uphylane-si_cpp.dtb --device tegra234-mb1-bct-device-p3701-0000_cpp.dtb --deviceprod tegra234-mb1-bct-cprod-p3701-0000_cpp.dtb --minratchet tegra234-mb1-bct-ratchet-p3701-0000_cpp.dtb --ratchet_blob ratchet_blob.bin
[ 6.5270 ] MB1-BCT version: 0.12
[ 6.5410 ] ERROR: /misc/enable_dram_page_blacklisting is not supported
[ 6.5411 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED1/ is not supported
[ 6.5413 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED1/ is not supported
[ 6.5413 ] ERROR: /misc/tsc_controls/tsc_locking_config is not supported
[ 6.5435 ] ERROR: /misc/tsc_controls/tsc_locking_diff_configuration is not supported
[ 6.5481 ] ERROR: /misc/tsc_controls/tsc_locking_ref_frequency_configuration is not supported
[ 6.5486 ] ERROR: /misc/tsc_controls/tsc_locking_control is not supported
[ 6.5487 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_configuration is not supported
[ 6.5488 ] ERROR: /misc/tsc_controls/tsc_locking_fast_adjust_configuration is not supported
[ 6.5489 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_delta_control is not supported
[ 6.5490 ] ERROR: /misc/tsc_controls/tsc_capture_control_ptx is not supported
[ 6.5491 ] ERROR: /misc/tsc_controls/tsc_capture_config_ptx is not supported
[ 6.5492 ] ERROR: /misc/tsc_controls/tsc_stscrsr is not supported
[ 6.5492 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_num_control is not supported
[ 6.5493 ] Parsing config file :tegra234-mb1-bct-pinmux-p3701-0000-a04_cpp.dtb
[ 6.5494 ] Added Platform Config 0 data with size :- 2936
[ 6.5700 ] Parsing config file :tegra234-mb1-bct-padvoltage-p3701-0000-a04_cpp.dtb
[ 6.5710 ] WARNING: unknown node ‘g2’
[ 6.5775 ] WARNING: unknown node ‘g2’
[ 6.5777 ] WARNING: unknown node ‘g9’
[ 6.5778 ] Added Platform Config 2 data with size :- 24
[ 6.5778 ] Parsing config file :tegra234-mb1-bct-pmic-p3701-0005_cpp.dtb
[ 6.5779 ] Added Platform Config 4 data with size :- 580
[ 6.5779 ] Parsing config file :tegra234-mb1-bct-reset-p3701-0000_cpp.dtb
[ 6.5780 ] Added Platform Config 3 data with size :- 52
[ 6.5781 ] Parsing config file :tegra234-mb1-bct-prod-p3701-0000_cpp.dtb
[ 6.5781 ] WARNING: unknown property ‘major’
[ 6.5782 ] WARNING: unknown property ‘minor’
[ 6.5782 ] Added Platform Config 5 data with size :- 524
[ 6.5782 ] Parsing config file :tegra234-mb1-bct-gpioint-p3701-0000_cpp.dtb
[ 6.5783 ] WARNING: unknown property ‘major’
[ 6.5922 ] WARNING: unknown property ‘minor’
[ 6.5923 ] Added Platform Config 7 data with size :- 380
[ 6.5925 ] Parsing config file :tegra234-mb1-bct-uphylane-si_cpp.dtb
[ 6.5931 ] Added Platform Config 8 data with size :- 24
[ 6.5938 ] Parsing config file :tegra234-mb1-bct-device-p3701-0000_cpp.dtb
[ 6.6007 ] Added Platform Config 9 data with size :- 100
[ 6.6009 ] Parsing config file :tegra234-mb1-bct-cprod-p3701-0000_cpp.dtb
[ 6.6011 ] ModuleCount 0 NumProdNames 0
[ 6.6011 ] Added Platform Config 6 data with size :- 16
[ 6.6012 ] Parsing config file :tegra234-mb1-bct-ratchet-p3701-0000_cpp.dtb
[ 6.6030 ] Updating mb1-bct with firmware information
[ 6.6036 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo flash.xml.bin
[ 6.6417 ] tegrahost_v2 --chip 0x23 0 --align mb1_cold_boot_bct_MB1_aligned.bct
[ 6.6669 ] Generating SHA2 Hash for mb1bct
[ 6.6736 ] Sha saved in mb1_cold_boot_bct_MB1_aligned.sha
[ 6.6765 ] Sha saved in mb1_cold_boot_bct_MB1.sha
[ 6.6746 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --ratchet_blob ratchet_blob.bin --appendsigheader mb1_cold_boot_bct_MB1_aligned.bct zerosbk
[ 6.6847 ] adding BCH for mb1_cold_boot_bct_MB1_aligned.bct
[ 6.7226 ] tegrasign_v3.py --key None --list mb1_cold_boot_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[ 6.7228 ] Assuming zero filled SBK key
[ 6.7775 ] Warning: pub_key.key is not found
[ 6.7737 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_cold_boot_bct_MB1_aligned_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_aligned_sigheader.bct.hash zerosbk
[ 6.7799 ] Generating recovery mb1-bct
[ 6.7807 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct.cfg --misc tegra234-mb1-bct-misc-p3701-0000_cpp.dtb --wb0sdram tegra234-p3701-0005-wb0sdram-l4t_cpp.dtb --pinmux tegra234-mb1-bct-pinmux-p3701-0000-a04_cpp.dtb --pmc tegra234-mb1-bct-padvoltage-p3701-0000-a04_cpp.dtb --pmic tegra234-mb1-bct-pmic-p3701-0005_cpp.dtb --brcommand tegra234-mb1-bct-reset-p3701-0000_cpp.dtb --prod tegra234-mb1-bct-prod-p3701-0000_cpp.dtb --gpioint tegra234-mb1-bct-gpioint-p3701-0000_cpp.dtb --uphy tegra234-mb1-bct-uphylane-si_cpp.dtb --device tegra234-mb1-bct-device-p3701-0000_cpp.dtb --deviceprod tegra234-mb1-bct-cprod-p3701-0000_cpp.dtb --minratchet tegra234-mb1-bct-ratchet-p3701-0000_cpp.dtb --ratchet_blob ratchet_blob.bin
[ 6.7810 ] MB1-BCT version: 0.12
[ 6.7827 ] ERROR: /misc/enable_dram_page_blacklisting is not supported
[ 6.7829 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED1/ is not supported
[ 6.7835 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED1/ is not supported
[ 6.7845 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED1/ is not supported
[ 6.7882 ] ERROR: /misc/tsc_controls/tsc_locking_config is not supported
[ 6.7883 ] ERROR: /misc/tsc_controls/tsc_locking_diff_configuration is not supported
[ 6.7885 ] ERROR: /misc/tsc_controls/tsc_locking_ref_frequency_configuration is not supported
[ 6.7887 ] ERROR: /misc/tsc_controls/tsc_locking_control is not supported
[ 6.7896 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_configuration is not supported
[ 6.7898 ] ERROR: /misc/tsc_controls/tsc_locking_fast_adjust_configuration is not supported
[ 6.7992 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_delta_control is not supported
[ 6.7994 ] ERROR: /misc/tsc_controls/tsc_capture_control_ptx is not supported
[ 6.7996 ] ERROR: /misc/tsc_controls/tsc_capture_config_ptx is not supported
[ 6.8003 ] ERROR: /misc/tsc_controls/tsc_stscrsr is not supported
[ 6.8004 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_num_control is not supported
[ 6.8005 ] Parsing config file :tegra234-mb1-bct-pinmux-p3701-0000-a04_cpp.dtb
[ 6.8006 ] Added Platform Config 0 data with size :- 2936
[ 6.8238 ] Parsing config file :tegra234-mb1-bct-padvoltage-p3701-0000-a04_cpp.dtb
[ 6.8239 ] WARNING: unknown node ‘g2’
[ 6.8319 ] WARNING: unknown node ‘g9’
[ 6.8320 ] WARNING: unknown node ‘g9’
[ 6.8321 ] Added Platform Config 2 data with size :- 24
[ 6.8321 ] Parsing config file :tegra234-mb1-bct-pmic-p3701-0005_cpp.dtb
[ 6.8322 ] Added Platform Config 4 data with size :- 580
[ 6.8336 ] Parsing config file :tegra234-mb1-bct-reset-p3701-0000_cpp.dtb
[ 6.8337 ] Added Platform Config 3 data with size :- 52
[ 6.8356 ] Parsing config file :tegra234-mb1-bct-prod-p3701-0000_cpp.dtb
[ 6.8357 ] WARNING: unknown property ‘major’
[ 6.8358 ] WARNING: unknown property ‘minor’
[ 6.8358 ] Added Platform Config 5 data with size :- 524
[ 6.8440 ] Parsing config file :tegra234-mb1-bct-gpioint-p3701-0000_cpp.dtb
[ 6.8442 ] WARNING: unknown property ‘major’
[ 6.8668 ] WARNING: unknown property ‘minor’
[ 6.8669 ] Added Platform Config 7 data with size :- 380
[ 6.8670 ] Parsing config file :tegra234-mb1-bct-uphylane-si_cpp.dtb
[ 6.8672 ] Added Platform Config 8 data with size :- 24
[ 6.8673 ] Parsing config file :tegra234-mb1-bct-device-p3701-0000_cpp.dtb
[ 6.8675 ] Added Platform Config 9 data with size :- 100
[ 6.8678 ] Parsing config file :tegra234-mb1-bct-cprod-p3701-0000_cpp.dtb
[ 6.8684 ] ModuleCount 0 NumProdNames 0
[ 6.8690 ] Added Platform Config 6 data with size :- 16
[ 6.8706 ] Parsing config file :tegra234-mb1-bct-ratchet-p3701-0000_cpp.dtb
[ 6.8945 ] Updating mb1-bct with firmware information
[ 6.8954 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct_MB1.bct --recov --updatefwinfo flash.xml.bin
[ 6.9432 ] tegrahost_v2 --chip 0x23 0 --align mb1_bct_MB1_aligned.bct
[ 6.9445 ] Generating SHA2 Hash for mb1bct
[ 6.9517 ] Sha saved in mb1_bct_MB1_aligned.sha
[ 6.9620 ] Sha saved in mb1_bct_MB1.sha
[ 6.9579 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --ratchet_blob ratchet_blob.bin --appendsigheader mb1_bct_MB1_aligned.bct zerosbk
[ 6.9608 ] adding BCH for mb1_bct_MB1_aligned.bct
[ 6.9854 ] tegrasign_v3.py --key None --list mb1_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[ 6.9856 ] Assuming zero filled SBK key
[ 6.9965 ] Warning: pub_key.key is not found
[ 7.0001 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_bct_MB1_aligned_sigheader.bct.encrypt mb1_bct_MB1_aligned_sigheader.bct.hash zerosbk
[ 7.0416 ] Generating coldboot mem-bct
[ 7.0427 ] tegrabct_v2 --chip 0x23 0 --sdram tegra234-p3701-0005-sdram-l4t_cpp.dtb --wb0sdram tegra234-p3701-0005-wb0sdram-l4t_cpp.dtb --membct tegra234-p3701-0005-sdram-l4t_cpp_1.bct tegra234-p3701-0005-sdram-l4t_cpp_2.bct tegra234-p3701-0005-sdram-l4t_cpp_3.bct tegra234-p3701-0005-sdram-l4t_cpp_4.bct
[ 7.0431 ] packing sdram params with Wb0 file tegra234-p3701-0005-wb0sdram-l4t_cpp.dtb
[ 7.1765 ] Packing sdram param for instance[0]
[ 7.1779 ] Packing sdram param for instance[1]
[ 7.1780 ] Packing sdram param for instance[2]
[ 7.1781 ] Packing sdram param for instance[3]
[ 7.1781 ] Packing sdram param for instance[4]
[ 7.1782 ] Packing sdram param for instance[5]
[ 7.1782 ] Packing sdram param for instance[6]
[ 7.1782 ] Packing sdram param for instance[7]
[ 7.1794 ] Packing sdram param for instance[8]
[ 7.1795 ] Packing sdram param for instance[9]
[ 7.1803 ] Packing sdram param for instance[10]
[ 7.1809 ] Packing sdram param for instance[11]
[ 7.1880 ] Packing sdram param for instance[12]
[ 7.1881 ] Packing sdram param for instance[13]
[ 7.1892 ] Packing sdram param for instance[14]
[ 7.1900 ] Packing sdram param for instance[15]
[ 7.3011 ] Getting sector size from pt
[ 7.3151 ] tegraparser_v2 --getsectorsize flash.xml.bin sector_info.bin
[ 7.3344 ] BlockSize read from layout is 0x200
[ 7.3442 ] tegrahost_v2 --chip 0x23 0 --blocksize 512 --magicid MEMB --addsigheader_multi tegra234-p3701-0005-sdram-l4t_cpp_1.bct tegra234-p3701-0005-sdram-l4t_cpp_2.bct tegra234-p3701-0005-sdram-l4t_cpp_3.bct tegra234-p3701-0005-sdram-l4t_cpp_4.bct
[ 7.3445 ] Binary 0 length is 58752
[ 7.3470 ] Binary 0 align length is 58880
[ 7.3471 ] Binary 1 length is 58752
[ 7.3471 ] Binary 1 align length is 58880
[ 7.3558 ] Binary 2 length is 58752
[ 7.3559 ] Binary 2 align length is 58880
[ 7.3559 ] Binary 3 length is 58752
[ 7.3561 ] Binary 3 align length is 58880
[ 7.3647 ] Buffer length is 235520
[ 7.3648 ] adding BCH for tegra234-p3701-0005-sdram-l4t_cpp_1.bct
[ 7.3648 ] new length is 243712
[ 7.3762 ] tegrahost_v2 --chip 0x23 0 --align mem_coldboot_aligned.bct
[ 7.3819 ] tegrahost_v2 --chip 0x23 0 --magicid MEMB --ratchet_blob ratchet_blob.bin --appendsigheader mem_coldboot_aligned.bct zerosbk
[ 7.3824 ] Header already present for mem_coldboot_aligned.bct
[ 7.3949 ] tegrasign_v3.py --key None --list mem_coldboot_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[ 7.3950 ] Assuming zero filled SBK key
[ 7.4038 ] Warning: pub_key.key is not found
[ 7.3996 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mem_coldboot_aligned_sigheader.bct.encrypt mem_coldboot_aligned_sigheader.bct.hash zerosbk
[ 7.4388 ] Generating recovery mem-bct
[ 7.4399 ] tegrabct_v2 --chip 0x23 0 --sdram tegra234-p3701-0005-sdram-l4t_cpp.dtb --wb0sdram tegra234-p3701-0005-wb0sdram-l4t_cpp.dtb --membct tegra234-p3701-0005-sdram-l4t_cpp_1.bct tegra234-p3701-0005-sdram-l4t_cpp_2.bct tegra234-p3701-0005-sdram-l4t_cpp_3.bct tegra234-p3701-0005-sdram-l4t_cpp_4.bct
[ 7.4565 ] packing sdram params with Wb0 file tegra234-p3701-0005-wb0sdram-l4t_cpp.dtb
[ 7.5661 ] Packing sdram param for instance[0]
[ 7.5763 ] Packing sdram param for instance[1]
[ 7.5773 ] Packing sdram param for instance[2]
[ 7.5842 ] Packing sdram param for instance[3]
[ 7.5847 ] Packing sdram param for instance[4]
[ 7.5853 ] Packing sdram param for instance[5]
[ 7.5860 ] Packing sdram param for instance[6]
[ 7.5866 ] Packing sdram param for instance[7]
[ 7.5876 ] Packing sdram param for instance[8]
[ 7.5881 ] Packing sdram param for instance[9]
[ 7.5887 ] Packing sdram param for instance[10]
[ 7.5910 ] Packing sdram param for instance[11]
[ 7.5942 ] Packing sdram param for instance[12]
[ 7.5943 ] Packing sdram param for instance[13]
[ 7.5950 ] Packing sdram param for instance[14]
[ 7.6067 ] Packing sdram param for instance[15]
[ 7.7404 ] Reading ramcode from backup chip_info.bin file
[ 7.7461 ] RAMCODE Read from Device: 3
[ 7.7463 ] Using ramcode 0
[ 7.7463 ] Disabled BPMP dtb trim, using default dtb
[ 7.7463 ]
[ 7.7531 ] tegrahost_v2 --chip 0x23 0 --align mem_rcm_aligned.bct
[ 7.7630 ] tegrahost_v2 --chip 0x23 0 --magicid MEM0 --ratchet_blob ratchet_blob.bin --appendsigheader mem_rcm_aligned.bct zerosbk
[ 7.7659 ] adding BCH for mem_rcm_aligned.bct
[ 7.7905 ] tegrasign_v3.py --key None --list mem_rcm_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[ 7.7907 ] Assuming zero filled SBK key
[ 7.8210 ] Warning: pub_key.key is not found
[ 7.8177 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mem_rcm_aligned_sigheader.bct.encrypt mem_rcm_aligned_sigheader.bct.hash zerosbk
[ 7.8626 ] Copying signatures
[ 7.8640 ] tegrahost_v2 --chip 0x23 0 --partitionlayout flash.xml.bin --updatesig images_list_signed.xml
[ 7.9730 ] Boot Rom communication
[ 7.9860 ] tegrarcm_v2 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
Error: Return value 8
Command tegrarcm_v2 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
Failed flashing t186ref.
Thank you in advance,
