Flashing Device (Jetson AGX Orin Dev Kit)
Hi, i received this in log and could not flash the device.
16:46:32 INFO: Flash Jetson Linux - flash: [ 0.3873 ] Generating recovery mb1-bct
16:46:32 INFO: Flash Jetson Linux - flash: [ 0.3890 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct.cfg --misc tegra234-mb1-bct-misc-p3701-0000_cpp.dtb --device tegra234-mb1-bct-device-p3701-0000_cpp.dtb
16:46:32 INFO: Flash Jetson Linux - flash: [ 0.3915 ] MB1-BCT version: 0.10
16:46:32 ERROR: Flash Jetson Linux - flash: [ 0.3920 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED1/ is not supported
16:46:32 ERROR: Flash Jetson Linux - flash: [ 0.3928 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED1/ is not supported
16:46:32 ERROR: Flash Jetson Linux - flash: [ 0.3934 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED1/ is not supported
16:46:32 ERROR: Flash Jetson Linux - flash: [ 0.3939 ] ERROR: /misc/tsc_controls/tsc_locking_config is not supported
16:46:32 ERROR: Flash Jetson Linux - flash: [ 0.3949 ] ERROR: /misc/tsc_controls/tsc_locking_diff_configuration is not supported
16:46:32 ERROR: Flash Jetson Linux - flash: [ 0.3954 ] ERROR: /misc/tsc_controls/tsc_locking_ref_frequency_configuration is not supported
16:46:32 ERROR: Flash Jetson Linux - flash: [ 0.3958 ] ERROR: /misc/tsc_controls/tsc_locking_control is not supported
16:46:32 ERROR: Flash Jetson Linux - flash: [ 0.3961 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_configuration is not supported
16:46:32 ERROR: Flash Jetson Linux - flash: [ 0.3967 ] ERROR: /misc/tsc_controls/tsc_locking_fast_adjust_configuration is not supported
16:46:32 ERROR: Flash Jetson Linux - flash: [ 0.3967 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_delta_control is not supported
16:46:32 ERROR: Flash Jetson Linux - flash: [ 0.3967 ] ERROR: /misc/tsc_controls/tsc_capture_control_ptx is not supported
16:46:32 ERROR: Flash Jetson Linux - flash: [ 0.3967 ] ERROR: /misc/tsc_controls/tsc_capture_config_ptx is not supported
16:46:32 ERROR: Flash Jetson Linux - flash: [ 0.3967 ] ERROR: /misc/tsc_controls/tsc_stscrsr is not supported
16:46:32 ERROR: Flash Jetson Linux - flash: [ 0.3967 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_num_control is not supported
16:46:32 INFO: Flash Jetson Linux - flash: [ 0.3967 ]
16:46:32 INFO: Flash Jetson Linux - flash: [ 0.3967 ] Parsing config file :tegra234-mb1-bct-device-p3701-0000_cpp.dtb
16:46:32 INFO: Flash Jetson Linux - flash: [ 0.3967 ] Added Platform Config 9 data with size :- 100
16:46:32 INFO: Flash Jetson Linux - flash: [ 0.3968 ] Updating mb1-bct with firmware information
16:46:32 INFO: Flash Jetson Linux - flash: [ 0.3986 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct_MB1.bct --recov --updatefwinfo readinfo_t234_min_prod.xml.bin
16:46:32 INFO: Flash Jetson Linux - flash: [ 0.4034 ] tegrahost_v2 --chip 0x23 0 --align mb1_bct_MB1_aligned.bct
16:46:32 INFO: Flash Jetson Linux - flash: [ 0.4066 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --appendsigheader mb1_bct_MB1_aligned.bct zerosbk
16:46:32 INFO: Flash Jetson Linux - flash: [ 0.4095 ] adding BCH for mb1_bct_MB1_aligned.bct
16:46:32 INFO: Flash Jetson Linux - flash: [ 0.4234 ] tegrasign_v3.py --key None --list mb1_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
16:46:32 INFO: Flash Jetson Linux - flash: [ 0.4237 ] Assuming zero filled SBK key
16:46:32 INFO: Flash Jetson Linux - flash: [ 0.4277 ] Warning: pub_key.key is not found
16:46:32 INFO: Flash Jetson Linux - flash: [ 0.4174 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_bct_MB1_aligned_sigheader.bct.encrypt mb1_bct_MB1_aligned_sigheader.bct.hash zerosbk
16:46:32 ERROR: Flash Jetson Linux - flash: [ 0.4204 ] Error: Skip generating mem_bct because sdram_config is not defined
16:46:32 INFO: Flash Jetson Linux - flash: [ 0.4204 ] Copying signatures
16:46:32 INFO: Flash Jetson Linux - flash: [ 0.4231 ] tegrahost_v2 --chip 0x23 0 --partitionlayout readinfo_t234_min_prod.xml.bin --updatesig images_list_signed.xml
16:46:32 INFO: Flash Jetson Linux - flash: [ 0.4330 ] mb1_t234_prod_aligned_sigheader.bin.encrypt filename is from images_list
16:46:32 INFO: Flash Jetson Linux - flash: [ 0.4332 ] psc_bl1_t234_prod_aligned_sigheader.bin.encrypt filename is from images_list
16:46:32 INFO: Flash Jetson Linux - flash: [ 0.4332 ] Boot Rom communication
16:46:32 INFO: Flash Jetson Linux - flash: [ 0.4367 ] tegrarcm_v2 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
16:46:32 INFO: Flash Jetson Linux - flash: [ 0.4383 ] BR_CID: 0x80012344705DD50F3000000008000280
16:46:32 INFO: Flash Jetson Linux - flash: [ 0.4642 ] Sending bct_br
16:46:37 ERROR: Flash Jetson Linux - flash: [ 0.5072 ] ERROR: might be timeout in USB write.
16:46:37 ERROR: Flash Jetson Linux - flash: Error: Return value 3
16:46:37 INFO: Flash Jetson Linux - flash: Command tegrarcm_v2 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
16:46:37 ERROR: Flash Jetson Linux - flash: — Error: Reading board information failed.
16:46:37 INFO: Flash Jetson Linux - flash: [ Component Install Finished with Error ]
16:46:37 INFO: Flash Jetson Linux - flash: [host] [ 7.82 MB released. Disk Avail: 55.28 GB ]
16:46:37 INFO: Flash Jetson Linux - flash: [ NV_L4T_FLASH_JETSON_LINUX_COMP Install took 7s ]
16:46:37 ERROR: Flash Jetson Linux - flash: command terminated with error
16:46:37 SUMMARY: Flash Jetson Linux - flash: First Error: Installation failed.
please hotplug the usb cable and reboot the host PC more times and see if you still hit this issue.
It works now, thanks!
Did you reset it by reboot the host PC? or try other cables?
I did the same thing (4 times, including unplug and replug the same cable) and it works in the last flashing
Could you help check if you still hit this issue afterwards?
Don’t have any issue after the flashing, no errors.
