It would be like raspberry pi. The OS installed in sd card. It should skip the eeprom reading steps in flash and help you flash successfully. If it is really related to eeprom, it would have no mac addr after boot up…
Well , the custom carrier board i am planning to use won’t have SD card port . this solution can be just temporary for my use case . However in case it’s a hardware issue , which i am now quite sure it is ( newly bought TX2 module works just fine) what suggestion do you have for me ? could it still be a software or poorly configured issue ?
Regards
I think you could use our RMA process for this broken module.
Go through RMA process, see https://developer.nvidia.com/embedded/support
Here’s the process to get an RMA via NVIDIA Support:
- Go to NVIDIA Support
- Select “Live Chat” or “Ask a Question” from the options near the top of the page.
- Enter your personal information.
- Select the appropriate product from the drop-down list (“Tegra” in this case).
- Submit the request.
UPDATE !!
I just discovered a new rather complicated problem. My old TX2 had already ubuntu os ( bought together with jetson board ) . and now it seems the system doesn’t boot anymore . well half an hour ago during my last comment in the topic , it was all good and running except the mac address issue . and suddenly it started rebooting on it’s own . and reboot wouldn’t complete , it would start rebooting again. sp here are the serial console outputs i am getting . i press the reset button and booting stops at different stage ,sometime t stops too early . sometimes a bit late .
[0000.245] C> ERROR: Highest Layer Module = 0x1d, Lowest Layer Module = 0x15,
Aux Info = 0x0, Reason = 0x1c
[0[0000.234] C> ERROR: Highest Layer Module = 0x1d, Lowest Layer Module = 0x15,
[0[0000.244] I> Welcome to MB2(TBoot-BPMP)(version: 01.00.160913-t186-M-00.00-mobile-f4c42291)
[0000.253] I> Default Heap @ [0xd486400 - 0xd488400]
[0000.258] I> DMA Heap @ [0x84900000 - 0x85300000]
[0000.262] I> bit @ 0xd480000
[0000.265] I> BR-BCT relocated to 0xf7f20000
[0000.269] I> Boot-device: eMMC
[0000.273] I> pmic: reset reason (nverc) : 0x50
[0000.278] I> Reading GPT from 512 for device 00000003
[0000.284] I> Reading GPT from 8388096 for device 00000003
[0000.292] I> Found 6 partitions in 00000003 device
[0000.296] I> Reading GPT from 512 for device 00010003
[0000.303] I> Found 17 partitions in 00010003 device
[0000.308] W> No valid slot number is found in scratch register
[0000.314] W> Return default slot: _a
[0000.317] I> A/B: bin_type (16) slot 0
[0000.321] I> Select partition: bpmp-fw
[0000.324] I> Loading partition bpmp-fw at 0xf7600000
[0000.329] I> Reading two headers - addr:0xf7600000 blocks:1
[0000.335] I> Addr: 0xf7600000, start-block: 58739717, num_blocks: 1
[0000.350] I> Binary(16) of size 524480 is loaded @ 0xf7600000
[0000.355] W> No valid slot number is found in scratch register
[0000.361] W> Return default slot: _a
[0000.364] I> A/B: bin_type (17) slot 0
[0000.368] I> Select partition: bpmp-fw-dtb
[0000.372] I> Loading partition bpmp-fw-dtb at 0xf77f0000
[0000.377] I> Reading two headers - addr:0xf77f0000 blocks:1
[0000.383] I> Addr: 0xf77f0000, start-block: 58740925, num_blocks: 1
[0000.395] I> Binary(17) of size 326672 is loaded @ 0xf77b0200
[0000.526] I> BPMP-FW load address = 0xf7600000
[0000.531] I> BPMP-FW DTB load address = 0x501b0200
[0000.535] I> Loading SCE-FW ...
[0000.538] W> No valid slot number is found in scratch register
[0000.544] W> Return default slot: _a
[0000.547] I> A/B: bin_type (12) slot 0
[0000.551] I> Select partition: sce-fw
[0000.555] I> Loading partition sce-fw at 0xf7800000
[0000.559] I> Reading two headers - addr:0xf7800000 blocks:1
[0000.565] I> Addr: 0xf7800000, start-block: 58741925, num_blocks: 1
[0000.573] I> Binary(12) of size 65088 is loaded @ 0xf7800000
[0000.579] I> Init SCE
[0000.581] I> Copy BTCM section
[0000.584] W> No valid slot number is found in scratch register
[0000.590] W> Return default slot: _a
[0000.593] I> A/B: bin_type (13) slot 0
[0000.597] I> Select partition: cpu-bootloader
[0000.601] I> Loading partition cpu-bootloader at 0x96000000
[0000.606] I> Reading two headers - addr:0x96000000 blocks:1
[0000.612] I> Addr: 0x96000000, start-block: 58732545, num_blocks: 1
[0000.622] I> Binary(13) of size 195776 is loaded @ 0x96000000
[0000.628] W> No valid slot number is found in scratch register
[0000.633] W> Return default slot: _a
[0000.637] I> A/B: bin_type (20) slot 0
[0000.641] I> Select partition: bootloader-dtb
[0000.645] I> Loading partition bootloader-dtb at 0x85300000
[0000.650] I> Reading two headers - addr:0x85300000 blocks:1
[0000.656] I> Addr: 0x85300000, start-block: 58733057, num_blocks: 1
[0000.668] I> Binary(20) of size 248032 is loaded @ 0x85300000
[0000.674] I> MB2-params @ 0xf7f00000
[0000.677] I> CPUBL-params @ 0xf7f00000
[0000.681] I> CPU-BL loaded at : 0x96000000
[0000.685] I> Loading TOS ...
[0000.687] W> No valid slot number is found in scratch register
[0000.693] W> Return default slot: _a
[0000.696] I> A/B: bin_type (14) slot 0
[0000.701] I> Select partition: secure-os
[0000.705] I> Loading partition secure-os at 0x8490f400
[0000.710] I> Reading two headers - addr:0x8490f400 blocks:1
[0000.715] I> Addr: 0x8490f400, start-block: 58733569, num_blocks: 1
[0000.724] I> Binary(14) of size 54384 is loaded @ 0x8490f400
[0000.730] I> Copying Monitor (length: 0xd270) from 0x8490f600 to 0x40000000
[0000.737] I> Erasing Monitor @ 0x8490f600
[0000.741] I> Unhalting SCE
[0000.745] I> Waypoint2-ACK: 0x5200b8d0
[0002.481] !!! Exception !!! [lr:0x52001abe, dfar:0x2c126e0, dfsr:0x8]
the second time i pressed the reset button i got the following
[0000.266] I> Welcome to MB2(TBoot-BPMP)(version: 01.00.160913-t186-M-00.00-mobile-f4c42291)
[0000.275] I> Default Heap @ [0xd486400 - 0xd488400]
[0000.279] I> DMA Heap @ [0x84900000 - 0x85300000]
[0000.284] I> bit @ 0xd480000
[0000.287] I> BR-BCT relocated to 0xf7f20000
[0000.291] I> Boot-device: eMMC
[0000.295] I> pmic: reset reason (nverc) : 0x80
[0000.299] I> Reading GPT from 512 for device 00000003
[0000.305] I> Reading GPT from 8388096 for device 00000003
[0000.312] I> Found 6 partitions in 00000003 device
[0000.317] I> Reading GPT from 512 for device 00010003
[0000.324] I> Found 17 partitions in 00010003 device
[0000.329] W> No valid slot number is found in scratch register
[0000.334] W> Return default slot: _a
[0000.338] I> A/B: bin_type (16) slot 0
[0000.341] I> Select partition: bpmp-fw
[0000.345] I> Loading partition bpmp-fw at 0xf7600000
[0000.350] I> Reading two headers - addr:0xf7600000 blocks:1
[0000.355] I> Addr: 0xf7600000, start-block: 58739717, num_blocks: 1
[0000.370] I> Binary(16) of size 524480 is loaded @ 0xf7600000
[0000.376] W> No valid slot number is found in scratch register
[0000.382] W> Return default slot: _a
[0000.385] I> A/B: bin_type (17) slot 0
[0000.389] I> Select partition: bpmp-fw-dtb
[0000.393] I> Loading partition bpmp-fw-dtb at 0xf77f0000
[0000.398] I> Reading two headers - addr:0xf77f0000 blocks:1
[0000.403] I> Addr: 0xf77f0000, start-block: 58740925, num_blocks: 1
[0000.415] I> Binary(17) of size 326672 is loaded @ 0xf77b0200
[0000.543] I> BPMP-FW load address = 0xf7600000
[0000.548] I> BPMP-FW DTB load address = 0x501b0200
[0000.552] I> Loading SCE-FW ...
[0000.555] W> No valid slot number is found in scratch register
[0000.561] W> Return default slot: _a
[0000.565] I> A/B: bin_type (12) slot 0
[0000.568] I> Select partition: sce-fw
[0000.572] I> Loading partition sce-fw at 0xf7800000
[0000.576] I> Reading two headers - addr:0xf7800000 blocks:1
[0000.582] I> Addr: 0xf7800000, start-block: 58741925, num_blocks: 1
[0000.590] I> Binary(12) of size 65088 is loaded @ 0xf7800000
[0000.596] I> Init SCE
[0000.598] I> Copy BTCM section
[0000.601] W> No valid slot number is found in scratch register
[0000.607] W> Return default slot: _a
[0000.610] I> A/B: bin_type (13) slot 0
[0000.614] I> Select partition: cpu-bootloader
[0000.618] I> Loading partition cpu-bootloader at 0x96000000
[0000.624] I> Reading two headers - addr:0x96000000 blocks:1
[0000.629] I> Addr: 0x96000000, start-block: 58732545, num_blocks: 1
[0000.639] I> Binary(13) of size 195776 is loaded @ 0x96000000
[0000.645] W> No valid slot number is found in scratch register
[0000.651] W> Return default slot: _a
[0000.654] I> A/B: bin_type (20) slot 0
[0000.658] I> Select partition: bootloader-dtb
[0000.662] I> Loading partition bootloader-dtb at 0x85300000
[0000.667] I> Reading two headers - addr:0x85300000 blocks:1
[0000.673] I> Addr: 0x85300000, start-block: 58733057, num_blocks: 1
[0000.684] I> Binary(20) of size 248032 is loaded @ 0x85300000
[0000.689] I> MB2-params @ 0xf7f00000
[0000.693] I> CPUBL-params @ 0xf7f00000
[0000.696] I> CPU-BL loaded at : 0x96000000
[0000.700] I> Loading TOS ...
[0000.703] W> No valid slot number is found in scratch register
[0000.709] W> Return default slot: _a
[0000.712] I> A/B: bin_type (14) slot 0
[0000.716] I> Select partition: secure-os
[0000.720] I> Loading partition secure-os at 0x8490f400
[0000.725] I> Reading two headers - addr:0x8490f400 blocks:1
[0000.730] I> Addr: 0x8490f400, start-block: 58733569, num_blocks: 1
[0000.738] I> Binary(14) of size 54384 is loaded @ 0x8490f400
[0000.744] I> Copying Monitor (length: 0xd270) from 0x8490f600 to 0x40000000
[0000.751] I> Erasing Monitor @ 0x8490f600
[0000.756] I> Unhalting SCE
[0000.759] I> Waypoint2-ACK: 0x5200b8d0
[0000.763] I> MB2(TBoot-BPMP) done
NOTICE: BL31: v1.2(release):ff7a644
NOTICE: BL31: Built : 21:06:35, Mar 1 2017
NOTICE: Trusty image missing.
ERROR: Error initializing runtime service trusty_fast
[0001.126] I> Welcome to Cboot
[0001.128] I> Cboot Version: 00.00.2014.50-t186-fabbc56c
[0001.133] I> CPU-BL Params @ 0xf7f00000
[0001.137] I> 0) Base:0x00000000 Size:0x00000000
[0001.142] I> 1) Base:0xf7e00000 Size:0x00100000
[0001.146] I> 2) Base:0xf7d00000 Size:0x00100000
[0001.150] I> 3) Base:0xf7c00000 Size:0x00100000
[0001.155] I> 4) Base:0xf7b00000 Size:0x00100000
[0001.159] I> 5) Base:0xf7a00000 Size:0x00100000
[0001.164] I> 6) Base:0xf7600000 Size:0x00200000
[0001.168] I> 7) Base:0xf7000000 Size:0x00400000
[0001.173] I> 8) Base:0xf7900000 Size:0x00100000
[0001.177] I> 9) Base:0xf7800000 Size:0x00100000
[0001.181] I> 10) Base:0xf6800000 Size:0x00800000
[0001.186] I> 11) Base:0x30000000 Size:0x00040000
[0001.190] I> 12) Base:0xf7500000 Size:0x00100000
[0001.195] I> 13) Base:0x30040000 Size:0x00001000
[0001.199] I> 14) Base:0x30048000 Size:0x00001000
[0001.204] I> 15) Base:0x30049000 Size:0x00001000
[0001.208] I> 16) Base:0x3004a000 Size:0x00001000
[0001.212] I> 17) Base:0x3004b000 Size:0x00001000
[0001.217] I> 18) Base:0x3004c000 Size:0x00001000
[0001.221] I> 19) Base:0x3004d000 Size:0x00001000
[0001.226] I> 20) Base:0x3004e000 Size:0x00001000
[0001.230] I> 21) Base:0x3004f000 Size:0x00001000
[0001.235] I> 22) Base:0x00000000 Size:0x00000000
[0001.239] I> 23) Base:0xf7ff0000 Size:0x00010000
[0001.243] I> 24) Base:0x00000000 Size:0x00000000
[0001.248] I> 25) Base:0x00000000 Size:0x00000000
[0001.252] I> 26) Base:0x00000000 Size:0x00000000
[0001.257] I> 27) Base:0x00000000 Size:0x00000000
[0001.261] I> 28) Base:0x84400000 Size:0x00400000
[0001.266] I> 29) Base:0x30000000 Size:0x00010000
[0001.270] I> 30) Base:0xf8000000 Size:0x08000000
[0001.274] I> 31) Base:0x00000000 Size:0x00000000
[0001.279] I> 32) Base:0xf6000000 Size:0x00600000
[0001.283] I> 33) Base:0x80000000 Size:0x76000000
[0001.288] I> 34) Base:0x100000000 Size:0x180000000
[0001.292] I> 35) Base:0x00000000 Size:0x00000000
[0001.297] I> 36) Base:0x00000000 Size:0x00000000
[0001.301] I> 37) Base:0xf7fc0000 Size:0x00020000
[0001.306] I> 38) Base:0x84000000 Size:0x00400000
[0001.310] I> 39) Base:0x96000000 Size:0x02000000
[0001.314] I> 40) Base:0x84800000 Size:0x00b00000
[0001.319] I> 41) Base:0xf7f00000 Size:0x00080000
[0001.323] I> 42) Base:0x00000000 Size:0x00000000
[0001.328] I> 43) Base:0x00000000 Size:0x00000000
[0001.332] platform_init_interrupts-121, 1*
[0001.336] Interrupts Init done
[0001.340] calling constructors
[0001.343] initializing heap
[0001.345] initializing threads
[0001.348] initializing timers
[0001.352] creating bootstrap completion thread
[0001.356] top of bootstrap2()
[0001.359] CPU: ARM Cortex A57
[0001.362] CPU: MIDR: 0x411FD073, MPIDR: 0x80000100
[0001.367] initializing platform
[0001.371] I> Boot-device: eMMC
[0001.374] I> odm data is 1090000
[0001.377] I> Reading GPT from 512 for device 00000003
[0001.383] I> Reading GPT from 8388096 for device 00000003
[0001.390] I> Found 6 partitions in 00000003 device
[0001.394] I> Reading GPT from 512 for device 00010003
[0001.400] I> Found 17 partitions in 00010003 device
[0001.405] W> No valid slot number is found in scratch register
[0001.410] W> Return default slot: _a
[0001.414] I> A/B: bin_type (1) slot 0
[0001.417] I> Select partition: kernel-dtb
[0001.421] I> Loading partition kernel-dtb at 0x92000000
[0001.430] I> Kernel_dtb @0x92000000
[0001.433] I> Bl_dtb @0x85300000
[0001.436] I> gpio framework initialized
[0001.440] I> tegrabl_gpio_driver_register: register 'tegra_gpio_main_driver' driver
[0001.447] I> tegrabl_gpio_driver_register: register 'tegra_gpio_aon_driver' driver
[0001.455] I> tegrabl_tca9539_init: i2c bus: 0, slave addr: 0xee
[0001.463] I> tegrabl_gpio_driver_register: register 'tca9539_gpio_driver' driver
[0001.470] I> tegrabl_tca9539_init: i2c bus: 0, slave addr: 0xe8
[0001.479] I> tegrabl_gpio_driver_register: register 'tca9539_gpio_driver' driver
[0001.487] E> tegrabl_blob_init: BMP partition does not have valid Blob
[0001.493] E> tegrabl_load_bmp_blob: BMP blob initialization failed
[0001.499] W> Loading bmp blob to memory failed
[0001.507] I> Find /i2c@c250000's alias i2c7
[0001.511] I> Reading eeprom i2c=7 address=0x50
[0001.518] I> Eeprom read failed 0x1a800027
[0001.522] I> Reading eeprom i2c=7 address=0x57
[0001.529] I> Eeprom read failed 0x1a800027
[0001.533] I> Find /i2c@c240000's alias i2c1
[0001.537] I> Reading eeprom i2c=1 address=0x51
[0001.544] I> Eeprom read failed 0x1a800027
[0001.549] I> Find /i2c@3160000's alias i2c0
[0001.553] I> Reading eeprom i2c=0 address=0x50
[0001.558] I> Eeprom read failed 0x1a800027
[0001.563] I> Find /i2c@3180000's alias i2c2
[0001.567] I> Reading eeprom i2c=2 address=0x54
[0001.571] I> Enabling gpio chip_id = 2, gpio pin = 9
[0001.602] I> Disabling gpio chip_id = 2, gpio pin = 9
[0001.607] I> Device at /i2c@3180000:0x54
[0001.611] I> create_pm_ids: id: 3326-1000-100-M, len: 15
[0001.616] I> config: mem-type:ff,power-config:ff,misc-config:ff,modem-config:ff,touch-config:ff,display-config:ff,, len: 93
[0001.627] initializing target
[0001.630] calling apps_init()
[0001.633] starting app android_boot_app
[0001.637] I> Gpio keyboard init success
[0001.641] I> Kernel type = Normal
[0001.644] I> Loading kernel/boot.img ...
[0001.648] W> No valid slot number is found in scratch register
[0001.653] W> Return default slot: _a
[0001.657] I> A/B: bin_type (0) slot 0
[0001.660] I> Select partition: kernel
[0001.664] I> Loading partition kernel at 0xa8000000
[0001.745] W> No valid slot number is found in scratch register
[0001.750] W> Return default slot: _a
[0001.754] I> A/B: bin_type (1) slot 0
[0001.757] I> Select partition: kernel-dtb
[0001.761] I> Loading partition kernel-dtb at 0x92000000
[0001.770] I> Kernel DTB @ 0x92000000
[0001.773] I> Verified boot state = Orange
[0001.777] E> tegrabl_display_clear: display is not initialized
[0001.783] I> Checking boot.img header magic ... [0001.787] I> [OK]
[0001.789] I> Valid boot.img @ 0xa8000000
[0001.792] I> decompressor handler not found
[0001.796] I> Copying kernel image (462634 bytes) from 0xa8000800 to 0x80080000 ... [0001.804] I> Done
[0001.806] I> Move ramdisk (len: 6252235) from 0xa8071800 to 0x98000000
[0001.815] I> Updated bpmp info to DTB
[0001.821] I> Ramdisk: Base: 0x98000000; Size: 0x5f66cb
[0001.826] I> Updated initrd info to DTB
[0001.829] I> disabled_core_mask: 0xffffff0c
[0001.833] I> Kernel type = Normal
[0001.836] E> Error 445464577: Failed to read CVM EEPROM
[0001.841] E> Failed to get board info. Booting w/o Serial Number
[0001.847] W> No valid slot number is found in scratch register
[0001.853] W> Return default slot: _a
[0001.856] I> Linux Cmdline: root=/dev/mmcblk0p1 rw rootwait fbcon=map:0 net.ifnames=0 console=tty0 OS=l4t console=ttyS0,115200n8 memtype=0 video=tegrafb no_console_suspend=1 earlycon=uart8250,mmio32,0x03
[0001.892] I> Updated bootarg info to DTB
[0001.898] E> Error 445464577: Failed to get CVM EEPROM contents
[0001.903] E> Booting w/o MAC ddresses for WIFI, Bluetooth & Ethernet
[0001.910] E> Failed to get WIFI MAC address
[0001.914] E> "ids" doesn't exist, creating
[0001.918] E> "connection" doesn't exist, creating
[0001.922] E> "configs" doesn't exist, creating
[0001.927] I> create_pm_ids: id: 3326-1000-100-M, len: 15
[0001.932] I> config: mem-type:ff,power-config:ff,misc-config:ff,modem-config:ff,touch-config:ff,display-config:ff,, len: 93
[0001.943] I> Adding plugin-manager/ids/3326-1000-100=/i2c@3180000:module@0x54
[0001.950] E> "i2c@3180000" doesn't exist, creating
[0001.954] E> "module@0x54" doesn't exist, creating
[0001.963] E> "chip-id" doesn't exist, creating
[0001.967] I> Adding plugin-manager/chip-id/A02P
[0001.974] I> Updated memory info to DTB
[0001.979] E> "reset" doesn't exist, creating
[0001.983] E> "pmc-reset-reason" doesn't exist, creating
[0001.989] E> "pmic-reset-reason" doesn't exist, creating
[0001.994] I> disabled_core_mask: 0xffffff0c
[0002.004] I> tegrabl_load_kernel_and_dtb: Done
U-Boot 2016.07-g5971907 (Mar 01 2017 - 21:06:45 -0800)
TEGRA186
Model: NVIDIA P2771-0000-500
DRAM: 7.8 GiB
MC: Tegra SD/MMC: 0, Tegra SD/MMC: 1
*** Warning - bad CRC, using default environment
In: serial
Out: serial
Err: serial
Can't find nvidia,ether-mac property in nvtboot DTB
Net:
Error: ethernet@2490000 address not set.
No ethernet found.
Hit any key to stop autoboot: 0
MMC: no card present
switch to partitions #0, OK
mmc0(part 0) is current device
Scanning mmc 0:1...
Found /boot/extlinux/extlinux.conf
Retrieving file: /boot/extlinux/extlinux.conf
524 bytes read in 81 ms (5.9 KiB/s)
p2771-0000 eMMC boot options
1: primary kernel
Enter choice: 1: primary kernel
Retrieving file: /boot/Image
18965312 bytes read in 500 ms (36.2 MiB/s)
append: fbcon=map:0 net.ifnames=0 console=tty0 OS=l4t console=ttyS0,115200n8 memtype=0 video=tegrafb no_console_suspend=1 earlycon=uart8250,mmio32,0x03100000 gpt tegraid=18.1.2.0.0 tegra_keep_boot_clocks t
Retrieving file: /boot/dtb/tegra186-quill-p3310-1000-c03-00-base.dtb
188611 bytes read in 65 ms (2.8 MiB/s)
## Flattened Device Tree blob at 82000000
Booting using the fdt blob at 0x82000000
reserving fdt memory region: addr=80000000 size=10000
Using Device Tree in place at 0000000082000000, end 00000000820310c2
ERROR: DT property /chosen/nvidia,bluetooth-mac missing in source; can't copy
at /dvs/git/dirty/git-master_linux/3rdparty/u-boot/arch/arm/mach-tegra/dt-edit.c:156/fdt_iter_copy_prop()
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x100
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 4.4.15-tegra-leopard (simon@simon-ubuntu) (gcc version 4.8.5 (GCC) ) #2 SMP PREEMPT Thu Jun 1 17:08:10 PDT 2017
[ 0.000000] Boot CPU: AArch64 Processor [411fd073]
[ 0.000000] earlycon: Early serial console at MMIO32 0x3100000 (options '')
[ 0.000000] bootconsole [uart0] enabled
[ 0.000000] Reserved memory: initialized node vpr-carveout, compatible id nvidia,vpr-carveout
[ 0.000000] Reserved memory: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] cma: Reserved 64 MiB at 0x00000000f2000000
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] PERCPU: Embedded 17 pages/cpu @ffffffc1ffd1b000 s31104 r8192 d30336 u69632
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 2019520
[ 0.000000] Kernel command line: fbcon=map:0 net.ifnames=0 console=tty0 OS=l4t console=ttyS0,115200n8 memtype=0 video=tegrafb no_console_suspend=1 earlycon=uart8250,mmio32,0x03100000 gpt tegraid=18.1.2t
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes)
[ 0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] Memory: 7286824K/8206336K available (10168K kernel code, 1668K rwdata, 5424K rodata, 1132K init, 679K bss, 165848K reserved, 753664K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vmalloc : 0xffffff8000000000 - 0xffffffbdbfff0000 ( 246 GB)
[ 0.000000] vmemmap : 0xffffffbdc0000000 - 0xffffffbfc0000000 ( 8 GB maximum)
[ 0.000000] 0xffffffbdc2000000 - 0xffffffbdca000000 ( 128 MB actual)
[ 0.000000] fixed : 0xffffffbffa7fd000 - 0xffffffbffac00000 ( 4108 KB)
[ 0.000000] PCI I/O : 0xffffffbffae00000 - 0xffffffbffbe00000 ( 16 MB)
[ 0.000000] modules : 0xffffffbffc000000 - 0xffffffc000000000 ( 64 MB)
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc200000000 ( 8192 MB)
[ 0.000000] .init : 0xffffffc000fbb000 - 0xffffffc0010d6000 ( 1132 KB)
[ 0.000000] .text : 0xffffffc000080000 - 0xffffffc000fbb000 ( 15596 KB)
[ 0.000000] .data : 0xffffffc0010f5000 - 0xffffffc001296340 ( 1669 KB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=6.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=6
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] Architected cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000002] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.008756] tegra-id: chipid=21817.
[ 0.012533] tegra-id: opt_subrevision=1.
[ 0.017106] Console: colour dummy device 80x25
[ 0.022058] console [tty0] enabled
[ 0.025589] kmemleak: Kernel memory leak detector disabled
[ 0.031286] Calibrating delay loop (skipped), value calculated using timer frequency.. 62.50 BogoMIPS (lpj=125000)
[ 0.042041] pid_max: default: 32768 minimum: 301
[ 0.046867] Security Framework initialized
[ 0.051141] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.058277] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.066214] Initializing cgroup subsys freezer
[ 0.070837] Initializing cgroup subsys debug
[ 0.075396] CPU0 ipc=752
[ 0.078035] CPU1 ipc=1024
[ 0.080751] CPU2 ipc=1024
[ 0.083473] CPU3 ipc=752
[ 0.086104] CPU4 ipc=752
[ 0.088732] CPU5 ipc=752
[ 0.091391] ASID allocator initialised with 65536 entries
[ 0.133745] CPU1: Booted secondary processor [4e0f0030]
[ 0.145323] CPU2: Booted secondary processor [4e0f0030]
[ 0.157175] CPU3: Booted secondary processor [411fd073]
[ 0.169163] CPU4: Booted secondary processor [411fd073]
[ 0.181177] CPU5: Booted secondary processor [411fd073]
[ 0.181218] Brought up 6 CPUs
[ 0.211431] SMP: Total of 6 processors activated.
[ 0.216319] CPU: All CPU(s) started at EL2
[ 0.220944] devtmpfs: initialized
[ 0.241060] Initilizing CustomIPI irq domain
[ 0.245682] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.266173] pinctrl core: initialized pinctrl subsystem
[ 0.271963] OS set in device tree is L4T.
[ 0.276679] regulator-dummy: no parameters
[ 0.281209] Initializing plugin-manager
[ 0.285284] Plugin module not found
[ 0.289302] node /plugin-manager/soc-prod-a02-fragment match with chip-id A02P
[ 0.297206] node /plugin-manager/fragement@0 match with odm-data enable-tegra-wdt
[ 0.305545] node /plugin-manager/fragement@4 match with odm-data enable-tegra-wdt
[ 0.317416] Adding domain adsp-pd to PM domain ape-pd
[ 0.326362] NET: Registered protocol family 16
[ 0.332592] console [pstore-1] enabled
[ 0.336537] pstore: Registered ramoops as persistent store backend
[ 0.343023] ramoops: attached 0x200000@0x100000000, ecc: 0/0
[ 0.357378] cpuidle: using governor ladder
[ 0.369346] cpuidle: using governor menu
[ 0.374985] bpmp: waiting for handshake
[ 0.379018] bpmp: handshake completed
[ 0.382899] bpmp: synchronizing channels
[ 0.387011] bpmp: channels synchronized
[ 0.391041] bpmp: connect returned 0
[ 0.395200] tegra186-pmc device create success
[ 0.399856] scratch reg offset dts data not present
[ 0.405063] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 0.412607] PMC: configuring io pad defaults
[ 0.417105] T186 pmc padctrl driver initialized
[ 0.421835] ### PMC reset source: Power on reset
[ 0.426655] ### PMC reset level: L0
[ 0.430302] ### PMC reset status reg: 0x0
[ 0.434780] vdso: 2 pages (1 code @ ffffffc0010fd000, 1 data @ ffffffc0010fc000)
[ 0.442588] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.451134] atomic_pool_init():526: DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.461250] tegra_powergate_init: DONE
[ 0.465354] DTS File Name: /home/simon/TX2/IMX377/kernel/kernel-4.4/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t18x/quill/kernel-dts/tegra186-quill-p3310-1000-c03-00-base.dts
[ 0.483411] DTB Build time: Jun 1 2017 17:09:43
[ 0.489615] Tegra reboot handler registered.
[ 0.494948] Registering Tegra186 clocks (this may take a while)...done
[ 0.503536] arm-smmu 12000000.iommu: probing hardware configuration...
[ 0.510358] arm-smmu 12000000.iommu: SMMUv2 with:
[ 0.515303] arm-smmu 12000000.iommu: stage 1 translation
[ 0.520959] arm-smmu 12000000.iommu: stage 2 translation
[ 0.526623] arm-smmu 12000000.iommu: nested translation
[ 0.532196] arm-smmu 12000000.iommu: stream matching with 128 register groups, mask 0x7f80
[ 0.540937] arm-smmu 12000000.iommu: SMMU address space size (0x800000) differs from mapped region size (0x1000000)!
[ 0.551939] arm-smmu 12000000.iommu: 64 context banks (0 stage-2 only)
[ 0.558862] arm-smmu 12000000.iommu: Stage-1: 39-bit VA -> 48-bit IPA
[ 0.565690] arm-smmu 12000000.iommu: Stage-2: 39-bit IPA -> 48-bit PA
[ 0.602202] arm-smmu 12000000.iommu: registered 66 master devices
[ 0.612212] iommu: Adding device 3460000.sdhci to group 0
[ 0.618489] iommu: Adding device 3400000.sdhci to group 1
[ 0.626626] iommu: Adding device 3507000.ahci-sata to group 2
[ 0.632999] iommu: Adding device 3160000.i2c to group 3
[ 0.638782] iommu: Adding device c240000.i2c to group 4
[ 0.644484] iommu: Adding device 3180000.i2c to group 5
[ 0.650211] iommu: Adding device 3190000.i2c to group 6
[ 0.656047] iommu: Adding device 31b0000.i2c to group 7
[ 0.661800] iommu: Adding device 31c0000.i2c to group 8
[ 0.667530] iommu: Adding device c250000.i2c to group 9
[ 0.673271] iommu: Adding device 31e0000.i2c to group 10
[ 0.680595] iommu: Adding device 3210000.spi to group 11
[ 0.686457] iommu: Adding device c260000.spi to group 12
[ 0.692290] iommu: Adding device 3240000.spi to group 13
[ 0.698539] iommu: Adding device 3100000.serial to group 14
[ 0.704635] iommu: Adding device 3110000.serial to group 15
[ 0.710743] iommu: Adding device 3130000.serial to group 16
[ 0.717481] iommu: Adding device 2490000.ether_qos to group 17
[ 0.723970] iommu: Adding device b000000.rtcpu to group 18
[ 0.730392] Wake73 for irq=42
[ 0.733824] iommu: Adding device smmu_test to group 19
[ 0.739652] mc: mapped MMIO address: 0xffffff8000560000 -> 0x2c10000
[ 0.746317] mc: mapped MMIO address: 0xffffff8000640000 -> 0x2c20000
[ 0.752967] mc: mapped MMIO address: 0xffffff8000660000 -> 0x2c30000
[ 0.759619] mc: mapped MMIO address: 0xffffff8000fa0000 -> 0x2c40000
[ 0.766263] mc: mapped MMIO address: 0xffffff8000fc0000 -> 0x2c50000
[ 0.772908] mc-err: Set intmask: 0xf3140
[ 0.777179] dram-ecc: DRAM ECC disabled-MC_ECC_CONTROL:0x0000000c
[ 0.784011] Wake76 for irq=199
[ 0.787226] Wake77 for irq=199
[ 0.790415] Wake78 for irq=199
[ 0.793603] Wake79 for irq=199
[ 0.796790] Wake80 for irq=199
[ 0.799975] Wake81 for irq=199
[ 0.803162] Wake82 for irq=199
[ 0.806484] iommu: Adding device 3530000.xhci to group 20
[ 0.812430] iommu: Adding device 3550000.xudc to group 21
[ 0.818772] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CTRL_0 = 3
[ 0.824964] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CNTRL_24(PMU_INT) = 320
[ 0.832736] iommu: Adding device 13e10000.host1x to group 22
[ 0.838891] iommu: Adding device 13e10000.host1x:ctx0 to group 23
[ 0.845516] iommu: Adding device 13e10000.host1x:ctx1 to group 24
[ 0.852087] iommu: Adding device 13e10000.host1x:ctx2 to group 25
[ 0.858641] iommu: Adding device 13e10000.host1x:ctx3 to group 26
[ 0.865275] iommu: Adding device 13e10000.host1x:ctx4 to group 27
[ 0.871857] iommu: Adding device 13e10000.host1x:ctx5 to group 28
[ 0.878443] iommu: Adding device 13e10000.host1x:ctx6 to group 29
[ 0.885013] iommu: Adding device 13e10000.host1x:ctx7 to group 30
[ 0.891753] iommu: Adding device 150c0000.nvcsi to group 31
[ 0.897995] iommu: Adding device 15700000.vi to group 32
[ 0.903807] iommu: Adding device 15600000.isp to group 33
[ 0.909722] iommu: Adding device 15210000.nvdisplay to group 34
[ 0.916097] iommu: Adding device 15340000.vic to group 35
[ 0.921963] iommu: Adding device 154c0000.nvenc to group 36
[ 0.927997] iommu: Adding device 15480000.nvdec to group 37
[ 0.934114] iommu: Adding device 15380000.nvjpg to group 38
[ 0.940112] iommu: Adding device 15500000.tsec to group 39
[ 0.946016] iommu: Adding device 15100000.tsecb to group 40
[ 0.952412] iommu: Adding device 15810000.se to group 41
[ 0.958138] iommu: Adding device 15820000.se to group 42
[ 0.963870] iommu: Adding device 15830000.se to group 43
[ 0.969587] iommu: Adding device 15840000.se to group 44
[ 0.975530] iommu: Adding device 17000000.gp10b to group 45
[ 0.982464] tegra-reset 5000000.clock: registered 193 resets.
[ 0.989662] iommu: Adding device d000000.bpmp to group 46
[ 0.995502] bpmp: ping status is 0
[ 0.999210] bpmp d000000.bpmp: firmware tag is c11dd04ae487c849cc552f8f702ed830
[ 1.009036] iommu: Adding device 2600000.dma to group 47
[ 1.015259] GPIO line 424 (wifi-enable) hogged as output/high
[ 1.021373] gpiochip_add_data: registered GPIOs 320 to 511 on device: tegra-gpio
[ 1.030776] GPIO line 315 (wifi-wake-ap) hogged as input
[ 1.036473] gpiochip_add_data: registered GPIOs 256 to 319 on device: tegra-gpio-aon
[ 1.045300] iommu: Adding device 10003000.pcie-controller to group 48
[ 1.052422] iommu: Adding device sound to group 49
[ 1.059129] iommu: Adding device 3510000.hda to group 50
[ 1.065955] iommu: Adding device adsp_audio to group 51
[ 1.072481] iommu: Adding device 2993000.adsp to group 52
[ 1.083247] iommu: Adding device c160000.aon to group 53
[ 1.090791] vdd-ac-bat: 5000 mV
[ 1.096056] vdd-1v8-ap: 1800 mV
[ 1.100337] gpio tegra-gpio-aon wake30 for gpio=60(FF:4)
[ 1.106066] gpio tegra-gpio-aon wake69 for gpio=59(FF:3)
[ 1.127931] SCSI subsystem initialized
[ 1.132152] usbcore: registered new interface driver usbfs
[ 1.137952] usbcore: registered new interface driver hub
[ 1.143615] usbcore: registered new device driver usb
[ 1.151889] GPIO line 241 (touch-rail-1) hogged as output/high
[ 1.158236] GPIO line 242 (touch-rail-2) hogged as output/high
[ 1.164422] gpiochip_add_data: registered GPIOs 240 to 255 on device: tca9539
[ 1.172637] gpiochip_add_data: registered GPIOs 224 to 239 on device: tca9539
[ 1.180280] tps65132 0-003e: No active discharge gpio for regulator tps65132-outp
[ 1.188267] tegra-i2c 3160000.i2c: no acknowledge from address 0x3e
[ 1.195375] tegra-i2c 3160000.i2c: no acknowledge from address 0x3e
[ 1.202331] outp: 4000 <--> 6000 mV
[ 1.206140] tps65132 0-003e: No active discharge gpio for regulator tps65132-outn
[ 1.214058] tegra-i2c 3160000.i2c: no acknowledge from address 0x3e
[ 1.221193] tegra-i2c 3160000.i2c: no acknowledge from address 0x3e
[ 1.228166] outn: 4000 <--> 6000 mV
[ 1.242142] media: Linux media interface: v0.10
[ 1.246948] Linux video capture interface: v2.00
[ 1.255383] pps_core: LinuxPPS API ver. 1 registered
[ 1.260579] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 1.270131] PTP clock support registered
[ 1.275826] Tegra WDT setup timeout = 120 seconds.
[ 1.280884] tegra_wdt_t18x 30c0000.watchdog: tegra_wdt_t18x_probe done
[ 1.289076] max77620 4-003c: PMIC Version OTP:0x45 and ES:0x8
[ 1.296863] GPIO line 221 (spmic_gpio_input_5) hogged as input
[ 1.303111] GPIO line 222 (spmic_gpio_input_6) hogged as input
[ 1.309301] gpiochip_add_data: registered GPIOs 216 to 223 on device: max77620-gpio
[ 1.321496] vddio-ddr: at 1125 mV
[ 1.329342] avdd_dsi_csi: 1200 mV
[ 1.337342] vdd-1v8: 1800 mV
[ 1.345341] vdd-3v3-sys: 3300 mV
[ 1.349796] spmic-ldo0: at 1800 mV
[ 1.354176] spmic-ldo1: at 800 mV
[ 1.361343] vddio-3v3: 3300 mV
[ 1.365230] vddio-sdmmc1: 1800 <--> 3300 mV at 3300 mV
[ 1.373341] vdd-rtc: 1000 mV
[ 1.377191] avdd-ts-hv: 1800 <--> 3300 mV at 1800 mV
[ 1.383070] spmic-ldo6: at 1500 mV
[ 1.387465] vdd-pex-1v05: 1000 mV
[ 1.391632] dvdd-pex: 1000 mV
[ 1.395171] max77620 4-003c: max77620 probe successful
[ 1.400808] Advanced Linux Sound Architecture Driver Initialized.
[ 1.408626] en-vdd-sd: 3300 mV
[ 1.412368] en-vdd-cam: 1800 mV
[ 1.416215] vdd-hdmi: 5000 mV
[ 1.419636] vdd-usb0-5v: 5000 mV
[ 1.423327] vdd-usb1-5v: 5000 mV
[ 1.429342] [0000.267]
pressing reset button the third time i got the following output
[code]Welcome to MB2(TBoot-BPMP)(version: 01.00.160913-t186-M-00.00-mobile-f4c42291)
[0000.280] I> DMA Heap @ [0x84900000 - 0x85300000]
[0000.285] I> bit @ 0xd480000
[0000.292] I> Boot-device: eMMC
[0000.296] I> pmic: reset reason (nverc) : 0x80
[0000.300] I> Reading GPT from 512 for device 00000003
[0000.306] I> Reading GPT from 8388096 for device 00000003
[0000.313] I> Found 6 partitions in 00000003 device
[0000.318] I> Reading GPT from 512 for device 00010003
[0000.335] W> Return default slot: _a
[0000.339] I> A/B: bin_type (16) slot 0
[0000.342] I> Select partition: bpmp-fw
[0000.346] I> Loading partition bpmp-fw at 0xf7600000
[0000.351] I> Reading two headers - addr:0xf7600000 blocks:1
[0000.356] I> Addr: 0xf7600000, start-block: 58739717, num_blocks: 1
[0000.371] I> Binary(16) of size 524480 is loaded @ 0xf7600000
[0000.377] W> No valid slot number is found in scratch register
[0000.386] I> A/B: bin_type (17) slot 0
[0000.404] I> Addr: 0xf77f0000, start-block: 58740925, num_blocks: 1
[0000.416] I> Binary(17) of size 326672 is loaded @ 0xf77b0200
[0000.553] I> Loading SCE-FW …
[0000.556] W> No valid slot number is found in scratch register
[0000.697] I> CPU-BL loaded at : 0x96000000
[0000.701] I> Loading TOS …
[0000.739] I> Binary(14) of size 54384 is loaded @ 0x8490f400
[0000.760] I> Waypoint2-ACK: 0x5200b8d0
[0001.129] I> Cboot Version: 00.00.2014.50-t186-fabbc56c
[0001.134] I> CPU-BL Params @ 0xf7f00000
[0001.138] I> 0) Base:0x00000000 Size:0x00000000
[0001.151] I> 3) Base:0xf7c00000 Size:0x00100000
[0001.160] I> 5) Base:0xf7a00000 Size:0x00100000
[0001.169] I> 7) Base:0xf7000000 Size:0x00400000
[0001.182] I> 10) Base:0xf6800000 Size:0x00800000
[0001.191] I> 12) Base:0xf7500000 Size:0x00100000
[0001.200] I> 14) Base:0x30048000 Size:0x00001000
[0001.213] I> 17) Base:0x3004b000 Size:0x00001000
[0001.222] I> 19) Base:0x3004d000 Size:0x00001000
[0001.231] I> 21) Base:0x3004f000 Size:0x00001000
[0001.244] I> 24) Base:0x00000000 Size:0x00000000
[0001.253] I> 26) Base:0x00000000 Size:0x00000000
[0001.262] I> 28) Base:0x84400000 Size:0x00400000
[0001.275] I> 31) Base:0x00000000 Size:0x00000000
[0001.284] I> 33) Base:0x80000000 Size:0x76000000
[0001.293] I> 35) Base:0x00000000 Size:0x00000000
[0001.302] I> 37) Base:0xf7fc0000 Size:0x00020000
[0001.315] I> 40) Base:0x84800000 Size:0x00b00000
[0001.324] I> 42) Base:0x00000000 Size:0x00000000
[0001.333] platform_init_interrupts-121, 1*
[0001.337] Interrupts Init done
[0001.346] initializing threads
[0001.349] initializing timers
[0001.357] top of bootstrap2()
[0001.360] CPU: ARM Cortex A57
[0001.363] CPU: MIDR: 0x411FD073, MPIDR: 0x80000100
[0001.368] initializing platform
[0001.375] I> odm data is 1090000
[0001.378] I> Reading GPT from 512 for device 00000003
[0001.395] I> Reading GPT from 512 for device 00010003
[0001.411] W> Return default slot: _a
[0001.418] I> Select partition: kernel-dtb
[0001.422] I> Loading partition kernel-dtb at 0x92000000
[0001.434] I> Bl_dtb @0x85300000
[0001.437] I> gpio framework initialized
[0001.440] I> tegrabl_gpio_driver_register: register ‘tegra_gpio_main_driver’ driver
[0001.448] I> tegrabl_gpio_driver_register: register ‘tegra_gpio_aon_driver’ driver
[0001.464] I> tegrabl_gpio_driver_register: register ‘tca9539_gpio_driver’ driver
[0001.471] I> tegrabl_tca9539_init: i2c bus: 0, slave addr: 0xe8
[0001.479] I> tegrabl_gpio_driver_register: register ‘tca9539_gpio_driver’ driver
[0001.507] I> Find /i2c@c250000’s alias i2c7
[0001.534] I> Find /i2c@c240000’s alias i2c1
[0001.538] I> Reading eeprom i2c=1 address=0x51
[0001.545] I> Eeprom read failed 0x1a800027
[0001.549] I> Find /i2c@3160000’s alias i2c0
[0001.559] I> Eeprom read failed 0x1a800027
[0001.563] I> Find /i2c@3180000’s alias i2c2
[0001.572] I> Enabling gpio chip_id = 2, gpio pin = 9
[0001.616] I> config: mem-type:ff,power-config:ff,misc-config:ff,modem-config:ff,touch-config:ff,display-config:ff, len: 93
[0001.644] I> Loading kernel/boot.img …
[0001.751] W> Return default slot: _a
[0001.758] I> Select partition: kernel-dtb
[0001.774] I> Verified boot state = Orange
[0001.783] I> Checking boot.img header magic … [0001.787] I> [OK]
[0001.793] I> decompressor handler not found
[0001.797] I> Copying kernel image (462634 bytes) from 0xa8000800 to 0x80080000 … [0001.804] I> Done
[0001.830] I> disabled_core_mask: 0xffffff0c
[0001.834] I> Kernel type = Normal
[0001.837] E> Error 445464577: Failed to read CVM EEPROM
[0001.842] E> Failed to get board info. Booting w/o Serial Number
[0001.848] W> No valid slot number is found in scratch register
[0001.857] I> Linux Cmdline: root=/dev/mmcblk0p1 rw rootwait fbcon=map:0 net.ifnames=0 console=tty0 OS=l4t console=ttyS0,115200n8 memtype=0 video=tegrafb no_console_suspend=1 earlycon=uart8250,mmio32,0x03
[0001.893] I> Updated bootarg info to DTB
[0001.904] E> Booting w/o MAC ddresses for WIFI, Bluetooth & Ethernet
[0001.914] E> “ids” doesn’t exist, creating
[0001.918] E> “connection” doesn’t exist, creating
[0001.923] E> “configs” doesn’t exist, creating
[0001.932] I> config: mem-type:ff,power-config:ff,misc-config:ff,modem-config:ff,touch-config:ff,display-config:ff, len: 93
[0001.950] E> “i2c@3180000” doesn’t exist, creating
[0001.955] E> “module@0x54” doesn’t exist, creating
[0001.963] E> “chip-id” doesn’t exist, creating
[0001.968] I> Adding plugin-manager/chip-id/A02P
[0001.980] E> “reset” doesn’t exist, creating
[0001.984] E> “pmc-reset-reason” doesn’t exist, creating
[0001.989] E> “pmic-reset-reason” doesn’t exist, creating
[0001.995] I> disabled_core_mask: 0xffffff0c
[0002.005] I> tegrabl_load_kernel_and_dtb: Done
TEGRA186
DRAM: 7.8 GiB
In: serial
Out: serial
Err: serial
Can’t find nvidia,ether-mac property in nvtboot DTB
Net:
No ethernet found.
Scanning mmc 0:1…
524 bytes read in 80 ms (5.9 KiB/s)
1: primary kernel
18965312 bytes read in 501 ms (36.1 MiB/s)
ERROR: DT property /chosen/nvidia,bluetooth-mac missing in source; can’t copy
Starting kernel …
[ 0.000000] earlycon: Early serial console at MMIO32 0x3100000 (options ‘’)
[ 0.008757] tegra-id: chipid=21817.
[ 0.017107] Console: colour dummy device 80x25
[ 0.022057] console [tty0] enabled
[ 0.025590] kmemleak: Kernel memory leak detector disabled
[ 0.042042] pid_max: default: 32768 minimum: 301
[ 0.058278] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.066213] Initializing cgroup subsys freezer
[ 0.070836] Initializing cgroup subsys debug
[ 0.075394] CPU0 ipc=752
[ 0.078032] CPU1 ipc=1024
[ 0.080748] CPU2 ipc=1024
[ 0.083470] CPU3 ipc=752
[ 0.086102] CPU4 ipc=752
[ 0.088731] CPU5 ipc=752
[ 0.133744] CPU1: Booted secondary processor [4e0f0030]
[ 0.145318] CPU2: Booted secondary processor [4e0f0030]
[ 0.157169] CPU3: Booted secondary processor [411fd073]
[ 0.169164] CPU4: Booted secondary processor [411fd073]
[ 0.181164] CPU5: Booted secondary processor [411fd073]
[ 0.181204] Brought up 6 CPUs
[ 0.211415] SMP: Total of 6 processors activated.
[ 0.216301] CPU: All CPU(s) started at EL2
[ 0.220961] devtmpfs: initialized
[ 0.241062] Initilizing CustomIPI irq domain
[ 0.245705] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.266749] pinctrl core: initialized pinctrl subsystem
[ 0.272536] OS set in device tree is L4T.
[ 0.277240] regulator-dummy: no parameters
[ 0.281722] Initializing plugin-manager
[ 0.285785] Plugin module not found
[ 0.289920] node /plugin-manager/soc-prod-a02-fragment match with chip-id A02P
[ 0.297825] node /plugin-manager/fragement@0 match with odm-data enable-tegra-wdt
[ 0.306062] node /plugin-manager/fragement@4 match with odm-data enable-tegra-wdt
[ 0.317761] Adding domain adsp-pd to PM domain ape-pd
[ 0.327277] NET: Registered protocol family 16
[ 0.333544] console [pstore-1] enabled
[ 0.337503] pstore: Registered ramoops as persistent store backend
[ 0.343980] ramoops: attached 0x200000@0x100000000, ecc: 0/0
[ 0.357343] cpuidle: using governor ladder
[ 0.369335] cpuidle: using governor menu
[ 0.374922] bpmp: waiting for handshake
[ 0.378964] bpmp: handshake completed
[ 0.382837] bpmp: synchronizing channels
[ 0.386968] bpmp: channels synchronized
[ 0.390973] bpmp: connect returned 0
[ 0.395303] tegra186-pmc device create success
[ 0.399980] scratch reg offset dts data not present
[ 0.405197] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 0.412744] PMC: configuring io pad defaults
[ 0.417241] T186 pmc padctrl driver initialized
[ 0.421972] ### PMC reset source: Power on reset
[ 0.426804] ### PMC reset level: L0
[ 0.430442] ### PMC reset status reg: 0x0
[ 0.435770] vdso: 2 pages (1 code @ ffffffc0010fd000, 1 data @ ffffffc0010fc000)
[ 0.443560] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.452551] atomic_pool_init():526: DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.462695] tegra_powergate_init: DONE
[ 0.466775] DTS File Name: /home/simon/TX2/IMX377/kernel/kernel-4.4/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t18x/quill/kernel-dts/tegra186-quill-p3310-1000-c03-00-base.dts
[ 0.484843] DTB Build time: Jun 1 2017 17:09:43
[ 0.491038] Tegra reboot handler registered.
[ 0.496428] Registering Tegra186 clocks (this may take a while)…done
[ 0.505264] arm-smmu 12000000.iommu: probing hardware configuration…
[ 0.512102] arm-smmu 12000000.iommu: SMMUv2 with:
[ 0.517052] arm-smmu 12000000.iommu: stage 1 translation
[ 0.522716] arm-smmu 12000000.iommu: stage 2 translation
[ 0.528370] arm-smmu 12000000.iommu: nested translation
[ 0.533934] arm-smmu 12000000.iommu: stream matching with 128 register groups, mask 0x7f80
[ 0.542672] arm-smmu 12000000.iommu: SMMU address space size (0x800000) differs from mapped region size (0x1000000)!
[ 0.553672] arm-smmu 12000000.iommu: 64 context banks (0 stage-2 only)
[ 0.560596] arm-smmu 12000000.iommu: Stage-1: 39-bit VA → 48-bit IPA
[ 0.567454] arm-smmu 12000000.iommu: Stage-2: 39-bit IPA → 48-bit PA
[ 0.603260] arm-smmu 12000000.iommu: registered 66 master devices
[ 0.613350] iommu: Adding device 3460000.sdhci to group 0
[ 0.619641] iommu: Adding device 3400000.sdhci to group 1
[ 0.627884] iommu: Adding device 3507000.ahci-sata to group 2
[ 0.634279] iommu: Adding device 3160000.i2c to group 3
[ 0.640399] iommu: Adding device c240000.i2c to group 4
[ 0.646145] iommu: Adding device 3180000.i2c to group 5
[ 0.651883] iommu: Adding device 3190000.i2c to group 6
[ 0.657701] iommu: Adding device 31b0000.i2c to group 7
[ 0.663435] iommu: Adding device 31c0000.i2c to group 8
[ 0.669153] iommu: Adding device c250000.i2c to group 9
[ 0.674873] iommu: Adding device 31e0000.i2c to group 10
[ 0.682188] iommu: Adding device 3210000.spi to group 11
[ 0.688001] iommu: Adding device c260000.spi to group 12
[ 0.693820] iommu: Adding device 3240000.spi to group 13
[ 0.700062] iommu: Adding device 3100000.serial to group 14
[ 0.706207] iommu: Adding device 3110000.serial to group 15
[ 0.712339] iommu: Adding device 3130000.serial to group 16
[ 0.719052] iommu: Adding device 2490000.ether_qos to group 17
[ 0.725580] iommu: Adding device b000000.rtcpu to group 18
[ 0.732047] Wake73 for irq=42
[ 0.735431] iommu: Adding device smmu_test to group 19
[ 0.741273] mc: mapped MMIO address: 0xffffff8000560000 → 0x2c10000
[ 0.747926] mc: mapped MMIO address: 0xffffff8000640000 → 0x2c20000
[ 0.754572] mc: mapped MMIO address: 0xffffff8000660000 → 0x2c30000
[ 0.761217] mc: mapped MMIO address: 0xffffff8000fa0000 → 0x2c40000
[ 0.767862] mc: mapped MMIO address: 0xffffff8000fc0000 → 0x2c50000
[ 0.774507] mc-err: Set intmask: 0xf3140
[ 0.778770] dram-ecc: DRAM ECC disabled-MC_ECC_CONTROL:0x0000000c
[ 0.785662] Wake76 for irq=199
[ 0.788855] Wake77 for irq=199
[ 0.792042] Wake78 for irq=199
[ 0.795227] Wake79 for irq=199
[ 0.798412] Wake80 for irq=199
[ 0.801599] Wake81 for irq=199
[ 0.804783] Wake82 for irq=199
[ 0.808101] iommu: Adding device 3530000.xhci to group 20
[ 0.814055] iommu: Adding device 3550000.xudc to group 21
[ 0.820424] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CTRL_0 = 3
[ 0.826618] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CNTRL_24(PMU_INT) = 320
[ 0.834360] iommu: Adding device 13e10000.host1x to group 22
[ 0.840490] iommu: Adding device 13e10000.host1x:ctx0 to group 23
[ 0.847064] iommu: Adding device 13e10000.host1x:ctx1 to group 24
[ 0.853619] iommu: Adding device 13e10000.host1x:ctx2 to group 25
[ 0.860199] iommu: Adding device 13e10000.host1x:ctx3 to group 26
[ 0.866804] iommu: Adding device 13e10000.host1x:ctx4 to group 27
[ 0.873372] iommu: Adding device 13e10000.host1x:ctx5 to group 28
[ 0.879958] iommu: Adding device 13e10000.host1x:ctx6 to group 29
[ 0.886573] iommu: Adding device 13e10000.host1x:ctx7 to group 30
[ 0.893302] iommu: Adding device 150c0000.nvcsi to group 31
[ 0.899519] iommu: Adding device 15700000.vi to group 32
[ 0.905327] iommu: Adding device 15600000.isp to group 33
[ 0.911231] iommu: Adding device 15210000.nvdisplay to group 34
[ 0.917637] iommu: Adding device 15340000.vic to group 35
[ 0.923447] iommu: Adding device 154c0000.nvenc to group 36
[ 0.929479] iommu: Adding device 15480000.nvdec to group 37
[ 0.935571] iommu: Adding device 15380000.nvjpg to group 38
[ 0.941576] iommu: Adding device 15500000.tsec to group 39
[ 0.947479] iommu: Adding device 15100000.tsecb to group 40
[ 0.953874] iommu: Adding device 15810000.se to group 41
[ 0.959633] iommu: Adding device 15820000.se to group 42
[ 0.965392] iommu: Adding device 15830000.se to group 43
[ 0.971116] iommu: Adding device 15840000.se to group 44
[ 0.977075] iommu: Adding device 17000000.gp10b to group 45
[ 0.983996] tegra-reset 5000000.clock: registered 193 resets.
[ 0.991196] iommu: Adding device d000000.bpmp to group 46
[ 0.997042] bpmp: ping status is 0
[ 1.000752] bpmp d000000.bpmp: firmware tag is c11dd04ae487c849cc552f8f702ed830
[ 1.010795] iommu: Adding device 2600000.dma to group 47
[ 1.017347] GPIO line 424 (wifi-enable) hogged as output/high
[ 1.023459] gpiochip_add_data: registered GPIOs 320 to 511 on device: tegra-gpio
[ 1.032814] GPIO line 315 (wifi-wake-ap) hogged as input
[ 1.038463] gpiochip_add_data: registered GPIOs 256 to 319 on device: tegra-gpio-aon
[ 1.047269] iommu: Adding device 10003000.pcie-controller to group 48
[ 1.054184] iommu: Adding device sound to group 49
[ 1.060587] iommu: Adding device 3510000.hda to group 50
[ 1.067140] iommu: Adding device adsp_audio to group 51
[ 1.073683] iommu: Adding device 2993000.adsp to group 52
[ 1.084578] iommu: Adding device c160000.aon to group 53
[ 1.092265] vdd-ac-bat: 5000 mV
[ 1.097474] vdd-1v8-ap: 1800 mV
[ 1.101720] gpio tegra-gpio-aon wake30 for gpio=60(FF:4)
[ 1.107447] gpio tegra-gpio-aon wake69 for gpio=59(FF:3)
[ 1.127840] SCSI subsystem initialized
[ 1.132110] usbcore: registered new interface driver usbfs
[ 1.137901] usbcore: registered new interface driver hub
[ 1.143575] usbcore: registered new device driver usb
[ 1.151912] GPIO line 241 (touch-rail-1) hogged as output/high
[ 1.158269] GPIO line 242 (touch-rail-2) hogged as output/high
[ 1.164456] gpiochip_add_data: registered GPIOs 240 to 255 on device: tca9539
[ 1.172677] gpiochip_add_data: registered GPIOs 224 to 239 on device: tca9539
[ 1.180312] tps65132 0-003e: No active discharge gpio for regulator tps65132-outp
[ 1.188264] tegra-i2c 3160000.i2c: no acknowledge from address 0x3e
[ 1.195369] tegra-i2c 3160000.i2c: no acknowledge from address 0x3e
[ 1.202323] outp: 4000 ↔ 6000 mV
[ 1.206133] tps65132 0-003e: No active discharge gpio for regulator tps65132-outn
[ 1.214078] tegra-i2c 3160000.i2c: no acknowledge from address 0x3e
[ 1.221185] tegra-i2c 3160000.i2c: no acknowledge from address 0x3e
[ 1.228154] outn: 4000 ↔ 6000 mV
[ 1.242095] media: Linux media interface: v0.10
[ 1.246889] Linux video capture interface: v2.00
[ 1.255290] pps_core: LinuxPPS API ver. 1 registered
[ 1.260482] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
[ 1.270039] PTP clock support registered
[ 1.275666] Tegra WDT setup timeout = 120 seconds.
[ 1.280697] tegra_wdt_t18x 30c0000.watchdog: tegra_wdt_t18x_probe done
[ 1.288928] max77620 4-003c: PMIC Version OTP:0x45 and ES:0x8
[ 1.296734] GPIO line 221 (spmic_gpio_input_5) hogged as input
[ 1.302984] GPIO line 222 (spmic_gpio_input_6) hogged as input
[ 1.309174] gpiochip_add_data: registered GPIOs 216 to 223 on device: max77620-gpio
[ 1.321492] vddio-ddr: at 1125 mV
[ 1.329338] avdd_dsi_csi: 1200 mV
[ 1.337336] vdd-1v8: 1800 mV
[ 1.345339] vdd-3v3-sys: 3300 mV
[ 1.349789] spmic-ldo0: at 1800 mV
[ 1.354169] spmic-ldo1: at 800 mV
[ 1.361338] vddio-3v3: 3300 mV
[ 1.365230] vddio-sdmmc1: 1800 ↔ 3300 mV at 3300 mV
[ 1.373336] vdd-rtc: 1000 mV
[ 1.377197] avdd-ts-hv: 1800 ↔ 3300 mV at 1800 mV
[ 1.383076] spmic-ldo6: at 1500 mV
[ 1.387463] vdd-pex-1v05: 1000 mV
[ 1.391847] dvdd-pex: 1000 mV
[ 1.395382] max77620 4-003c: max77620 probe successful
[ 1.401050] Advanced Linux Sound Architecture Driver Initialized.
[ 1.408721] en-vdd-sd: 3300 mV
[ 1.412478] en-vdd-cam: 1800 mV
[ 1.416310] vdd-hdmi: 5000
[0000.300] !!! Exception !!! [lr:0x40024e0a, dfar:0x2c10df8, dfsr:0x1008]
[0000.306] MB1-BIT() boot status dump :
0000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
[0000.335] Last seen error : 0x00000000
[0000.301] !!! Exception !!! [lr:0x40024e0a, dfar:0x2c10df8, dfsr:0x1008]
[0000.307] MB1-BIT() boot status dump :
[0000.336] Last seen error : 0x00000000
some last part was missing
It really seems like a hardware failure needing RMA. Still, I am very curious about “Reason = 0x1c”. I’m wondering if there is a list of codes visible for “Reason”, e.g., “0x1c”?
Thanks all. I’ve sent my board back. Looking forward to getting a new one.
I didn’t understand what codes should be visible , I posted whatever output i managed to get from serial console . I can’t re check for you though , as i have already sent it back to the vendor i bought it from .
Much obliged for your help.
