We are developing OrinNX system.
And we consider how to flash when we manufacture mass production.
We want to directly flash to only qspi on OrinNX Module.
And NVMe SSD would be clone from the other flashed SSD.
How to flash only qspi on OrinNX Module??
I searched the idea from some scripts under “/Linux_for_Tegra/tools/kernel_flash”
I found the option “–qspi-only”, but I have no idea how to use it.
Please remove the ethernet cable and provide the full serial console log for further check.
Or you can enter into boot menu to check what’s the boot device currently.
It seems worked with the previous flash command provided.
For this use case, please refer to the Workflow 12: Manually generate a bootable external storage device from Linux_for_Tegra/tools/kernel_flash/README_initrd_flash.txt through connecting your NVMe on your host PC and run the command.
