I have Debian 12.1 (kernel 6.1.0-10-amd64) with RTX 4060 (535.104.05), with the Powermizer default value “auto” i have the flicker issue. Recently set to “adaptive” and so far (less than 1h) flicker not occur but i think it will be return)
Just popping in to confirm a couple of things I’ve seen about this issue in this thread or elsewhere.
I’ve had this issue since I switched back from WSL to a full Linux desktop as my daily driver a few months back. IIRC, it first started when trying to solve tearing problems. Eventually, I reverted my settings after it showed up and forgot about it, assuming I’d just misconfigured something. A while later I tried to fix tearing again and the problem reappeared after switching on ‘Force Full Composition Pipeline’. It was either absent before then, or I didn’t notice it occurring. Interestingly, as far as I can tell it stops completely after resuming from suspend, but comes back after a reboot. I’m sure I’ve seen that behaviour mentioned somewhere with regard to power management issues. Something about the card drawing more power than expected, or not throttling down properly until resuming from suspend, after which it behaves.
Hello, I appreciate the reply. Is there a driver update planned that will undoubtedly resolve this issue once and for all time? This flashing has gotten to be quite annoying and frustrating. Don’t make the Linux community feel bad for choosing Nvidia. It’s been a few months since this issue first appeared. The problem, as far as I know, is root caused. Unfortunately, I need kernel 6.5 in order to get my laptop to run well. If the 525 drivers had compiled, I would have installed them long ago.
RTX 2080ti connected via DP to 144Hz 1080p screen. Running Arch 6.5.3-arch1-1, X11 and drivers 535.104.05.
Flickering still persists every other minute for a frame or two in the top quarter of the screen. changing powermizer settings doesn’t resolve the issue
Like downsj above, I’ve also just made an account to comment on this thread.
I can confirm I still have intermittent screen flicker on Endeavour running 6.5.3-arch-1-1 kernel & driver version 535.104.05 (2070 Super).
Things have gotten progressively better with each update, but nothing has solved the issue. At this point I’m thinking of swapping in an AMD card since I can get access to one—it shouldn’t have to come to that, but who knows how long this issue will go on for. Frustrating to say the least.
Setting PowerMizer to “Prefer Maximum Performance” mitigates the issue, but does not solve it.
Workload on the GPU increases the amount of flickering. This is already noticeable with high-quality video playback or lightweight titles like Factorio or Hollow Knight.
i7-9700K / 2070 Super
Mint 21.2 Cinnamon / 5.15.0-84-generic / Driver version: 535.104.05
Monitor: LG 27GP850P-B, 1440p@164.96hz
Flickers for me. In games seems to be fine(tested for 10 minutes). 1/3 of the top screen black mostly(sometimes white).
Seeing that this issue drags from at least June is really depressing. If NVIDIA doesn’t test its products properly - at the very least development team should be confident in their ability to fix issues quickly. Bug that prevents most basic usage of the GPU is 1 quarter old. And that’s in mature product that Turing series is supposed to be. It’s scary to think how Ada Lovelace is behaves on Linux systems.
P.S. Why does it says that “topic is solved” when I’m replying? It’s not.
I have a hunch that there is something wrong with the blob that is delivered and used by the driver. Since going from 470.182.03 to 470.199.02 I was surprised to have occasional flickering - either the whole screen(s) or just the top.
The context of the flickering was the following:
the full-screen flickering occurred when having two browsers opened (the active one being maximized) and having a VirtualBox VM running; it is randomly happening (sometimes a couple of days in between)
the top screen flickering occurs generally when unlocking the screen after the machine has been left alone for 10min -ish; again, it is randomly occurring (seems to occur every other day); usually it settles down after a few seconds.
The exact version of the video card is NVIDIA GK104GLM [Quadro K3000M], in a HP EliteBook 8770w. Quite old, but a solid machine; the interesting part is when the flickering issue started to manifest.
You could blame it on the kernel changes, the setup (external screen - ASUS PA278QV, DisplayPort), but I can really feel a difference between the two versions of the driver.
I hope this helps with the investigations; if someone needs extra details about my setup I could provide them.
Cheers and good luck finding and fixing the root problem !
I noticed that the flickering problem occured also for me today although i said weeks ago that was fixed.
I installed Counter Strike 2, and the flickering doesn’t stop!!
