I have a laptop ‘Lenovo Legion 5 15APH9’ and an LG 27GP850-B monitor with preferred mode 2560x1440@165hz connected together with a good cable. It works well on Windows, but with Linux (Arch with all last updates + nvidia 555.58.02 proprietary drivers + KDE Plasma 6 Wayland) I can’t get stable image with refresh rate 144 or 165hz.
I’ve tried:
nvidia.NVreg_DynamicPowerManagement
=0
/1
/2
nvidia.NVreg_EnableGpuFirmware
=0
/1
nvidia-drm.modeset
=0
/1
nvidia-drm.fbdev
=0
/1
And various combinations of above, then:
- Using
nvidia-open
andnvidia-beta
(560) - Set in bios
integrated graphics + discrete
oronly discrete
- Live CD with Linux Mint. External monitor were recognized but I found no usable configuration at all (not even 2560x1440@120 or 60).
- Live CD with Pop_OS NVIDIA both with Comsic and Gnome. None gave different result.
- Then I’ve tried to use another DP cable and it worked, but refresh rate was varying between 165 and 48hz depending on if the image changes. Switching to this “power-saving” mode is fast, but switching from 48 Hz to 165 Hz takes about 1-2 seconds, so my experience with this setup was pretty bad. Then I’ve tried to use
nvidia.NVreg_DynamicPowerManagemen=0
kernel parameter and got stable 165hz, but after about 10 seconds of stable work flickers and artifacts came back.
In bug report generated by nvidia-bug-report.log
I found messages about problems with EDID of external monitor and sbios
were mentioned there. My laptop have last version of bios and here is EDID from /sys/class/drm/card0-DP-6/edid
and parsed EDID by edid-decode
(I have changed serial number info):
LG_edid_parsed.txt (8.3 KB)
Here is the bug report log:
nvidia-bug-report.log.gz (1.2 MB)
journalctl -b -2:
I tried to use only discrete graphics + nvidia-drm.modeset=0
+nvidia-drm.fbdev=0
journalctl -b -1:
nvidia-open package were used there for nvidia drivers
journalctl -b -0:
nvidia proprietary package were used there for nvidia drivers
