From 51xx Up until 525.85 this issue disappeared and i was not having problems with intermittent flicker or suspend, as soon as i upgraded to 525.89 the issue came back with a bite as the flicker is considerably worse.
I have been plagued with something similar issue. For me the monitors attached to the PC through the thunderbolt, the screen keeps going blank every few mins. SOmetimes they blink rapidly. I have another connection from gpu’s hdmi port going to the TV, and that works fine.
I have a 3080TI card. Do u know of a windows driver that has this issue resolved?
I’m really not sure about windows, because i haven’t used it in decades as a desktop OS. However, what i do know is that this issue went away around 7 or 8 release cycles ago and i was not having issues, as yourself, using the HDMI port didn’t show this behaviour, but, unfortunately, using a thunderbolt connection, directly or thru a dock (and moreover on optimus laptops, like mine) had all kinds of issues “detecting” displays, so, the flicker came and went.
This is also NVIDIA’s fault in the sense that the GPU cannot share outputs with the integrated video card and when you use a thunderbolt output you have to force the laptop to use the integrated GPU. This is by design, regretfully.
Thanks for the info. So you have a Nvidia GTX 1650 MaxQ, right?
So far I have not experienced this issue any longer since driver version 515.57.
But I do not have any screen supporting >60Hz refresh rate.
Does it help to reduce the refresh rate to 60Hz?
In addition, are you experiencing diagonal tearing as well when running at 4k 60Hz on an external monitor?
Since the X1 Extreme Gen2 is also running a Turing TU117 chip, as the quadro T2000, but to T2000 is more performant, it would be interesting to see, since user generix suggested to set it to maximum performance mode.
I’ve confirmed, as others in other threads, that the issue starts happening with refresh rates over 120hz. And this is an issue that was introduced on 525.89
