Since updating the Nvidia driver to 5.25.78.01 I am experiencing a diagonal screen tearing on my external Monitor Thinkvision P27u running either via USB-C DP alt mode, HDMI or connected via Thunderbolt Workstation Dock Gen2 Display Port. Same issue with a or Dell S7271QS via HDMI or Display Port via Thunderbolt Workstation Dock Gen2.
Notebook: Thinkpad P1 Gen2
The GPU is a T2000
OS: Fedora 37
Drivers not working so far: 525.78.01, 525.85.05, 525.89.02
Last driver working: 525.60.11
I am experiencing the same issue with the nouveau drive as weel since day one. It is just the other diagonale and appears even for example when scrolling web sites, open new tabs, etc…
Since Nvidia driver 525.78.01 the exact same problem appears.
The most easiest to reproduce the issue was to simply show the sleep/reboot/shutdown/log off screen
I have same issue on my Optimus device. I have tearing problem while using XWayland applications on Wayland server with PRIME Render Offload. 520 drivers just works fine.
Enabling Performance Mode and using Weston as compositor solves my issue for now.
@aplattner@amrits
I am still waiting for your feedback to this issue
Looks like you are forcing us (University IT department) to completely switch from Nvidia CUDA.
We can not use it anyway when drivers are not working properly.
I suspect this is a fallout from nvidia changing their clocking algorithm trying to mitigate high power consumption with multi-monitor setups (check the forum for posts from users complaining about it). For your setup, the memory clocks are likely now too low to provide the needed memory bandwidth/latency.
Instead of using max performance, you could check whether your gpu supports nvidia-smi -lgc to manually just set a higher minimum memory clock.
Edit: I meant nvidia-smi -lmc for memory clocks.
I checked the change log of 525.78.01 and found the following:
Could be that this “fix” causes the new issue.
Surprisingly the problem also appears when not running in “Reverse Prime” but also in regular “Prime”.
@amrits@aplattner
Could you please take care of this issue and fix it.
Even when scrolling in texts, this is really unusable and extremely distracting.
Don’t get me wrong, but the the Nvidia Quadro T2000 was a quite powerful mobile graphic chips and by introducing this change, it turns into showing garbage, almost impossible to not get distracted from work with 3500$ machines
Btw.:
During experiencing massive screen tearing I checked
nvidia-smi dmon
and did not see any signifigance differene in clockspeeds between driver versions 525.65.01 (no tearing) and 525.89.02 (massive tearing), but see for yourself
@fhortner
I have filed a bug 4004122 internally for tracking purpose.
I will check for similar hardware internally and try for local repro.
Can you please confirm if issue is only reproducible with dock connected?
@amrits
Thanks for taking care.
Issue is reproducible also without dock connected, so completely independent from dock.
I tried with a 4K monitor directly connected to laptop via HDMI or USB-C (so dock disconnected)
Also tried with a 4K monitor via Display Port with dock connected via thunderbolt
@fhortner
Apologize for the late response.
I tried on couple of Thinkpad notebooks (ThinkPad P1 Gen 3 and ThinkPad P1 Gen 5) but did not observe any flickering/tearing issue so far.
I will spend few more cycles on it and update.
Are you seeing this issue consistently or happen after certain amount of time post boot ?
The issue is consistently on every boot, independent of time past after boot.
BUT:
Reducing resolution to FullHD 1080p helps to reduce the issue
with monitors native resolution 4k the issue is much worse than with FullHD
The issue is best visible with changing gradients like opening the sleep/restart/shutdown dialog in KDE Plasma wih X11 (Wayland is so laggy that it is totally unusable)
