After upgrading to the 460.32.03 driver (Arch Linux, 5.10.5 kernel, KDE Plasma), I’ve started to experience flickering under normal desktop usage with my 1080 Ti. It occurs quite often (once every minute or so) and is mostly located at the bottom of the screen (though sometimes also fullscreen). I’m using an LG 27GN850-B monitor connected via DisplayPort 1.4 at 2560x1440/144Hz (in case that’s not obvious in the bug report).
I can confirm that downgrading to the previous stable driver (455.55.01) fixes the problem. The bug report was created after installing the driver via DKMS (https://archlinux.org/packages/extra/x86_64/nvidia-dkms/), but it’s the same with the regular version compiled against the 5.10.5 kernel (https://archlinux.org/packages/extra/x86_64/nvidia/).
Also, I am not sure if this could be related at all (as I don’t know if and how much code the Linux and Windows drivers share), but this issue appears very similar to the one introduced with the 460.79 Windows driver ([GeForce GTX 1080 Ti]: The desktop screen may flicker. [3200599]
). That one was specific to the 1080 Ti and has apparently been fixed in the latest Windows driver (461.09). I did experience flickering too when using 460.79 under Windows, downgrading to 456.71 fixed it.
nvidia-bug-report.log.gz (333.8 KB)
