I’ve just changed my version of CUDA from 0.8 to 1.0. Everything was working perfectly fine with the beta version. But here is what I got when I tried to compile with the 1.0:
I’ve got a Dell Precision 690 with a Dual Core Xeon 3.0GHz, one 8800 GTX and I’m running Kubuntu Edgy. Of course I’ve installed the latest driver (100.14).
No one says you have to change your OS. But change the version of CUDA you install. If you’re running Fedora 5, try to install CUDA for Suse Linux Entreprise version. That should be fixing your problem.
