**• Hardware Platform - Jetson **
**• DeepStream Version - 5.0 **
• JetPack Version - 4.5
• TensorRT Version - 7.1.3
• Issue Type( questions, bugs)
I work on DeepStream app that uses very simple pipeline where I need the inference only. I need the metadata and frames to be post processed on the separate threads beyond the DS pipeline so I decided to use pad probe to extract metadata and frames and store them in the external variables. It worked perfect until I added the the extraction of frame buffer. Now I have encountered the weird behaviour - app works perfect about 7 min +/- 30 sec then halts/hangs without saying a word. My Jetson is in MAXN power and has proper fan. No overheating or memory leaks.
The pipeline is:
gst-launch-1.0 v4l2src device=/dev/video0 io-mode=2 ! 'image/jpeg, width=3264, height=2448, framerate=15/1, format=MJPG' \
! jpegdec \
! videoconvert \
! nvvideoconvert ! 'video/x-raw(memory:NVMM),format=NV12' \
! m.sink_0 nvstreammux name=m batch-size=1 width=3264 height=2448 \
! nvinfer config-file-path=../config/pgie_config.txt batch-size=1 unique-id=1 \
! fakesink
The pad is connected to fakesink’s sink
The pad probe code is here:
static GstPadProbeReturn meta_probe_callback (GstPad * pad, GstPadProbeInfo * info,
gpointer u_data)
GstBuffer *buf = (GstBuffer *) info->data;
NvDsObjectMeta *obj_meta = NULL;
NvDsMetaList * l_frame = NULL;
NvDsMetaList * l_obj = NULL;
NvBufSurface *surface = NULL;
GstMapInfo in_map_info;
long long tt;
memset (&in_map_info, 0, sizeof (in_map_info));
if (gst_buffer_map (buf, &in_map_info, GST_MAP_READWRITE)) {
surface = (NvBufSurface *) in_map_info.data;
NvBufSurfaceMap(surface, -1, -1, NVBUF_MAP_READ_WRITE);
NvBufSurfaceSyncForCpu(surface, -1, -1);
NvDsBatchMeta *batch_meta = gst_buffer_get_nvds_batch_meta (buf);
for (l_frame = batch_meta->frame_meta_list; l_frame != NULL;
l_frame = l_frame->next) {
NvDsFrameMeta *frame_meta = (NvDsFrameMeta *) (l_frame->data);
gint frame_width = (gint)surface->surfaceList[frame_meta->batch_id].width;
gint frame_height = (gint)surface->surfaceList[frame_meta->batch_id].height;
void *frame_data = surface->surfaceList[frame_meta->batch_id].mappedAddr.addr[0];
size_t frame_step = surface->surfaceList[frame_meta->batch_id].pitch;
FRAME_BUF = cv::Mat(frame_height, frame_width, CV_8UC4, frame_data, frame_step);
for (l_obj = frame_meta->obj_meta_list; l_obj != NULL;
l_obj = l_obj->next) {
obj_meta = (NvDsObjectMeta *) (l_obj->data);
NvOSD_RectParams * rect_params = &(obj_meta->rect_params);
int left = (int) (rect_params->left);
int top = (int) (rect_params->top);
int right = left + (int) (rect_params->width);
int bottom = top + (int) (rect_params->height);
int class_index = obj_meta->class_id;
const char * lbl = CLASSES[obj_meta->class_id].c_str();
g_print("%s, ", lbl);
tt = get_timestamp_msec();
g_print("W: %d, H: %d, ", frame_width, frame_height);
g_print("duration: %lld \n", tt - TMP_T);
TMP_T = tt;
NvBufSurfaceUnMap(surface, -1, -1);
return GST_PAD_PROBE_OK;
No other threads are running outside the pipeline. CLASSES, FRAME_BUF etc are external variables.
Interesting to notice that after it’s halt/hang if I send SIGINT the log is the following and looks like the pipeline is destroyed for some reason.
^C*** Interrupted ***
0:07:26.097549195 23425 0x5592210000 DEBUG GST_EVENT gstevent.c:306:gst_event_new_custom: creating new event 0x5592640f10 eos 28174
0:07:26.097603362 23425 0x5592210000 DEBUG GST_ELEMENT_PADS gstelement.c:1856:gst_element_send_event: send eos event on element main-pipeline
0:07:26.097646800 23425 0x5592210000 DEBUG bin gstbin.c:3135:gst_bin_send_event:<main-pipeline> Sending eos event to src children
0:07:26.097718207 23425 0x5592210000 DEBUG GST_STATES gstbin.c:2032:bin_element_is_src:<main-pipeline> child fake_sink is not src
0:07:26.097752010 23425 0x5592210000 DEBUG GST_STATES gstbin.c:2032:bin_element_is_src:<main-pipeline> child primary-nvinference-engine is not src
0:07:26.097807323 23425 0x5592210000 DEBUG GST_STATES gstbin.c:2032:bin_element_is_src:<main-pipeline> child streammux is not src
0:07:26.097836386 23425 0x5592210000 DEBUG GST_STATES gstbin.c:2032:bin_element_is_src:<main-pipeline> child camera_bin is src
0:07:26.097907325 23425 0x5592210000 DEBUG GST_ELEMENT_PADS gstelement.c:1856:gst_element_send_event: send eos event on element camera_bin
0:07:26.097953836 23425 0x5592210000 DEBUG bin gstbin.c:3135:gst_bin_send_event:<camera_bin> Sending eos event to src children
0:07:26.098017014 23425 0x5592210000 DEBUG GST_STATES gstbin.c:2032:bin_element_is_src:<camera_bin> child nvvidconv_cap_filter is not src
0:07:26.098052535 23425 0x5592210000 DEBUG GST_STATES gstbin.c:2032:bin_element_is_src:<camera_bin> child nvvideoconv is not src
0:07:26.098081806 23425 0x5592210000 DEBUG GST_STATES gstbin.c:2032:bin_element_is_src:<camera_bin> child videoconv is not src
0:07:26.098167849 23425 0x5592210000 DEBUG GST_STATES gstbin.c:2032:bin_element_is_src:<camera_bin> child jpeg_dec is not src
0:07:26.098202537 23425 0x5592210000 DEBUG GST_STATES gstbin.c:2032:bin_element_is_src:<camera_bin> child src_cap_filter is not src
0:07:26.098457020 23425 0x5592210000 DEBUG GST_STATES gstbin.c:2032:bin_element_is_src:<camera_bin> child src_elem is src
0:07:26.098482281 23425 0x5592210000 DEBUG GST_ELEMENT_PADS gstelement.c:1856:gst_element_send_event: send eos event on element src_elem
0:07:26.098527594 23425 0x5592210000 DEBUG basesrc gstbasesrc.c:1786:gst_base_src_send_event:<src_elem> handling event 0x5592640f10 eos event: 0x5592640f10, time 99:99:99.999999999, seq-num 1113, (NULL)
0:07:26.098551188 23425 0x5592210000 DEBUG basesrc gstbasesrc.c:3679:gst_base_src_set_flushing:<src_elem> flushing 1
0:07:26.098568063 23425 0x5592210000 LOG bufferpool gstbufferpool.c:1387:gst_buffer_pool_set_flushing:<src_elem:pool:src> flushing 1
0:07:26.098582543 23425 0x5592210000 DEBUG v4l2bufferpool gstv4l2bufferpool.c:960:gst_v4l2_buffer_pool_flush_start:<src_elem:pool:src> start flushing
0:07:26.098610981 23425 0x5592210000 LOG GST_POLL gstpoll.c:1621:gst_poll_set_flushing: 0x7f34006cf0: flushing: 1
0:07:26.098630877 23425 0x5592210000 LOG v4l2 gstv4l2object.c:4117:gst_v4l2_object_unlock:<src_elem:src> start flushing
0:07:26.098645512 23425 0x5592210000 LOG bufferpool gstbufferpool.c:1387:gst_buffer_pool_set_flushing:<src_elem:pool:src> flushing 1
I would very much appreciated for any help or hints
