Gaussian filtering computed by cpu through opencv is much faster than Gaussian filtering through CUDA on jetson nano
Dear Community,
I calculate the Gaussian filter on the jetson nano,the image size is 1920*1200 , and i use opencv firstly,it comput by cpu. then i use cuda, but CUDA takes more time then opencv-cpu. i can’t understand,why cpu is faster then gpu。
Here is the opencv-cpu code:
cv::Mat smooth_mat(d_image_height_, d_image_width_, CV_8UC1, pattern_ptr);
cv::GaussianBlur(smooth_mat, smooth_mat, cv::Size(5, 5), 1, 1);
Here is the CUDA code:
void main(void )
dim3 threadsPerBlock(8, 8);
dim3 blocksPerGrid((d_image_width_ + threadsPerBlock.x - 1) / threadsPerBlock.x,(d_image_height_ + threadsPerBlock.y - 1) / threadsPerBlock.y);
cudaMallocManaged((void **)&d_patterns_list_[i], d_image_height_ * d_image_width_ * sizeof(unsigned char));
// Some fill data code is omitted here...
kernel_gaussian_blur <<< blocksPerGrid, threadsPerBlock >>> (d_patterns_list_[serial_flag], d_patterns_list_[serial_flag], d_image_height_, d_image_width_, gauss_filter_width);
cudaDeviceSynchronize();
__global__ void kernel_gaussian_blur(const uchar* src, uchar* dst, int height, int width, int filterWidth)
	int y = blockDim.y * blockIdx.y + threadIdx.y; //X
	int x = blockDim.x * blockIdx.x + threadIdx.x; //y
	int ind = y * width + x;
	if (y >= height || x >= width)
		return;
	float color = 0.0f;
	for (int i = 0; i < filterWidth; i++)
		for (int j = 0; j < filterWidth; j++)
			int clamp_x = min(max(x + j - filterWidth / 2, 0), width - 1);
			int clamp_y = min(max(y + i - filterWidth / 2, 0), height - 1);
			// float avg = d_const_Gaussian_5_5[i * filterWidth + j];
			color += (d_const_Gaussian_5_5[i * filterWidth + j] * static_cast<float>(src[clamp_y * width + clamp_x]));
	dst[ind] = color;
Thanks for visiting the NVIDIA Developer forums! Your topic will be best served in the Jetson category.
I will move this post over for visibility.
Cheers,
Tom
thank you !
Have you tried our VPI library which also has the Gaussian filter?
You can find the expected performance in the below table.
https://docs.nvidia.com/vpi/1.2/algo_gaussian_filter.html
Since OpenCV is a third-party library, please contact the OpenCV team if you prefer to use their implementation.
