Get all state from dynamic control resets the effort set previously
Hi, I am using Dynamic control to apply torque to my robot joint using dc.set_dof_effort(). I have found that if I get all dof state using dc.get_articulation_dof_states() API, it resets the effort I set previously. Can you help me confirm this behaviour? is it a bug?
A minimal example is provided below:
effort = 10
dc.set_dof_effort(joint_handle, effort)
dof_efforts = dc.get_articulation_dof_efforts(art_handle)
print(dof_efforts) # This value is correct. It shows the effort that was set.
dof_state = dc.get_articulation_dof_states(art_handle, dc.STATE_ALL)
print(dof_state["effort"] # This value is wrong. It does not show the effort that was set.
print(dof_efforts) # This value is now wrong. It no longer shows the effort that was set
When
is called it currently will return the force due to gravity on the articulation. Which overrides the effort that was set. There is a larger effort to fix the efforts that are reported because currently they only contain gravity, and there are other problems with joint force sensors that we are working on fixing.
I would consider this a bug from a user’s perspective. I am not sure if there is a way to workaround this though, PhysX resets the effort variable that’s used internally when gravitational forces are computed.
But yes I can confirm the behavior and why its happening.
