Get many logs of kernels when running deepstream app
• Hardware Platform (GPU)
• DeepStream Version 6.1
I got this log nvidia-uvm in syslog when running my deepstream app. Do you guys have any ideas? Thanks.
Which version of the gpu driver are you using?
I guess it is caused by the wrong driver version.
If you use DS-6.1, it is recommended to use version 510.47.03. You can try to reinstall the driver to solve this problem.
It is also recommended that you use DS-6.3 version with GPU driver 525.125.06
I’m running deepstream 6.1 with CUDA driver 470.182.03
But my app has been running stably for a long time with current settings.
I am wondering why I got this error in only some deployment environments which have no issues like this before
I’m guessing you were using DS-6.0.1 before ? Or you upgraded the kernel ?
As far as I know,version 470 of the GPU driver does not work well with DS-6.1.
Here is the compatibility table
