is there a simple possibility to get the speed of a detected vehicle by using VisionWorks functinons. I’ve looked up the documentations of “VisionWorks - Structure from Motion” and “VisionWorks - Object Tracker Reference”, it only says that there is a possibility to do that (“An interface for getting information on ID, location, speed, and status of the tracked object”) but not how to. For testing I would like to use the function in a Sample App and write the current speed to a log-file.
Hope you can give me some support, thank you!
Excuse me but I am still searching for a solution approach. Is there nobody who can give me some support?
Hello daicatho,
Could you please let me know the references above came from in NV documentation of VisionWorks?
I couldn’t find the references in NV documentation of VisionWorks. Thanks.
I found it in the “NVIDIA_VisionWorks_Tracking_Reference/nvvwx_trk_docs/classObjectTracker_1_1TrackedObject.html” documentation for ObjectTracker::TrackedObject’s and it is named “An interface for getting information on ID, location, speed, and status of the tracked object.”
Hello daicatho,
Could you please check the doc version?
I couldn’t find your mentioned link in the VisionWorks doc.
Below are VisionWorks(version 1.6) links.
https://developer.nvidia.com/embedded/dlc/visionworks-1-6-documentation-for-l4t-27-1
Hallo Steve,
it is not to find in the “normal” VisionWorks documentation. It is available in the “Structure from Motion” (Version: DRAFT 0.88 Release) and “Object Tracker Referenc” (Version: DRAFT 0.84 Release) documentation.
