i need to work in python 3.7 with numpy and opencv. I have jetpack4.3 installed and it comes with opencv and python 3.6.9. Everything works great. I need python 3.7 so i install it and it does not see numpy or opencv.
I make a virtual environment and try to pip install numpy. It wont install it has errors about missing mkl_rt
libraries mkl_rt not found in ['/home/nvidia/.virtualenvs/vcam/lib', '/usr/local/lib', '/usr/lib', '/usr/lib/aarch64-linux-gnu']
NOT AVAILABLE
blis_info:
libraries blis not found in ['/home/nvidia/.virtualenvs/vcam/lib', '/usr/local/lib', '/usr/lib', '/usr/lib/aarch64-linux-gnu']
NOT AVAILABLE
What can i do to get this working?
Thank you
edit: the above works fine on an x86 laptop so i think i am getting the wrong packages for jetson from pip.
What do i need to do to get numpy and python 3.7 working together on Jetson? I cant get a version of numpy that is compatible with the jetson board when i install via pip. If i apt install it only works with the original 3.6 version of python.
