HELLO!
I have flashed the NVIDIA TX2 with Jetpack3.1, but how could I install the opencv and tensorflow for python3.5(not python2.7) in a correct and easy way ? To be frank, this isn’t my first time to install opencv and tensorflow in TX2, but when I installed tensorflow successfully and use it to run my demo, the emergency occurred to me: the course was killed due to the severe lack of the disk.So I want to look for a more reliable way to install these components.Can you give me some advice?
You can check the following solution:
TensorFlow:
It’s recommended to install our pip wheel directly:
[url]https://devtalk.nvidia.com/default/topic/1038957/jetson-tx2/tensorflow-for-jetson-tx2-/post/5278617/#5278617[/url]
This is a binary file for installation.
You don’t need to build it from source so the OOM won’t be an issue for you.
OpenCV:
Check this script to build it from source:
[url]https://github.com/AastaNV/JEP/blob/master/script/install_opencv3.4.0_TX2.sh[/url]
We didn’t meet OOM issue when building OpenCV on TX2 before. So the default space should be already enough.
