I am having issues finishing the “Getting Started with Deep Learning” course. When trying to load the assessment Notebook I spin infinitely (after 10 seconds the stop button shows up but that’s it).
I didn’t go over the 2 hours mark so that can’t be the problem.
I would appreciate so help !
Thanks in advance.
Hello, it usually takes a while for our courses to launch outside of our public and private workshops. With this particular course, I believe the launch time is ~5-10 minutes. Did you allow it sufficient time to launch?
Thanks for the response !
I’ve waited way above the 10 minutes mark multiple times without it ever working.
I could only access the assessment once and after taking a pause from it I couldn’t access it anymore. Since then I can’t access it again. I was only about 40 minutes in.
Can you try visiting http://websocketstest.courses.nvidia.com/ and making sure that all of the tests pass?
