Getting video feeds from both IMX219 and IMX477
I have an issue with making both cameras work at the same time. At first, the IMX219 (raspberry cam v2)worked just fine until I enabled the IMX477(raspberry cam HQ) following the instructions in Sony IMX219 Linux driver | Sony IMX219 Linux Driver for Jetson | RidgeRun Developer
Now I can run the IMX477 sensor but can’t run the IMX219.
Is there a way I can have both working at once?
Thanks in advance.
hello user43712,
may I know which JetPack release you’re working with.
please also setup a terminal to catch the logs, $ dmesg --follow,
you may save those failure logs as single text file for reference,
thanks
Dear JerryChang,
I am using JetPack 4.5.1 (L4T 32.5.2), and I have attached the logs file.
logs.cat (88.6 KB)
Thank you in advance,
Hamza
hello user43712,
I’ve only see warning messages for IMX477 set exposure,
for example,
[   70.567916] imx477 9-001a: imx477_set_exposure: exposure limited by frame_length: 3092 [lines]
[   70.646007] imx477 9-001a: imx477_set_exposure: exposure limited by frame_length: 3092 [lines]
[   70.954753] imx477 9-001a: imx477_set_exposure: exposure limited by frame_length: 3092 [lines]
[   71.052324] imx477 9-001a: imx477_set_exposure: exposure limited by frame_length: 3092 [lines]
there’s even no kernel logs related to IMX219 for sensor registration,
could you please contact with sensor vendor for correct device tree blob to register IMX219 camera sensor.
thanks
Dear JerryChang,
Thank you for your fast replies.
I reinstalled the latest Jetpack version (4.6) used sudo /opt/nvidia/jetson-io/jetson-io.py to configure the CSI connector. I set it to Camera IMX477-A and IMX219-B and now I got both mycameras working at the same time
