How to Change imx219 to imx477 in jetpack 4.6.2.
I’m using Jetson Xavier Nx. I tried Changing with Jetsonio.py but its not changing.
I want to use the following camera,
https://www.arducam.com/product/b0242-arducam-imx477-hq-camera/
I have tried Editing the /boot/extlinux/extlinux.conf, but no use.
the following Forum tried.
After booting from the official JETPACK 5.0.2 downloaded through the sdk manager, we want to be able to view the video simply by applying our camera device-tree or camera driver.
Creating and uploading the driver module was successful.
How can we apply our device-tree (camera dtb) to /boot/dtb/kernel_tegra194-p3668-all-p3509-0000.dtb after booting?
Please be aware that 4.6.2 is using cboot but 5.0.1 does not have cboot at all, use UEFI instead.
And these two don’t affect each other. Currently, only 4.6.2 has known issue about extlinux.conf.
Any Help Toward It will be Helpfull. Thanks IN advance.
hello garva3583,
are you using Xavier NX developer kit?
may I know what’s the messages by using Jetson-IO to configure CSI.
please also share the kernel init messages for reference, $ dmesg > klogs.txt
klogs.txt (65.0 KB)
here is the Klogs.txt, i wish i got thee correct one, but now the jetsonio.py is also not opening
yes i’m using Xavier NX developer kit
hello garva3583,
it looks system still parsing cameras with IMX219 camera configurations.
for example,
[ 5.204083] imx219 9-0010: tegracam sensor driver:imx219_v2.0.6
[ 5.227556] tegra-i2c 3180000.i2c: no acknowledge from address 0x10
[ 5.228879] imx219 9-0010: imx219_board_setup: error during i2c read probe (-121)
[ 5.230220] imx219 9-0010: board setup failed
may I also know what did you meant Jetsonio.py is also not opening.
don’t you see menu for CSI configuration? are you running with root permission?
dyna
March 10, 2023, 10:10am
6
Hi Garva,
Are you able to use IMX477 with Xavier NX?
Thank you
Yeah now, I’m able to use IMX477 in Xavier Nx. with Jetpack 4.6.3
