Gfxbench (https://gfxbench.com/) gfxbench_gl-linux-qt-4.0.13+community_64bit is not working on Ubuntu 14.04.5 LTS 64bit with Nvidia 370.28 driver.
It’s the only available driver to me that works with the GTX 1060 3GB, it is in the extra Ubuntu driver PPA.
The 367.57 driver doesn’t work.
I have no clue if this a problem with gfxbench or with the driver, I’m emailing already with gfxbench, but I wanted to post it here too for completeness.
All other graphics programs that I have tested are running without any problems.
Console output:
[INFO ]: Dictionary loaded
[WARN ]: Empty dictionary
[INFO ]: Application started
[INFO ]: start
[INFO ]: Dispatching initialize
[INFO ]: Executing initialize
[INFO ]: App data path: /home/vuurdraak/.local/share/Kishonti Ltd/GFXBench GL
[INFO ]: Synchronization path: /home/vuurdraak/.cache/Kishonti Ltd/GFXBench GL/synchronized
[INFO ]: Config path: /home/vuurdraak/Downloads/gfxbench/config
[INFO ]: Data path: /home/vuurdraak/.cache/Kishonti Ltd/GFXBench GL/synchronized/data
[INFO ]: Plugin path: /home/vuurdraak/Downloads/gfxbench/plugins
[INFO ]: Test image path: /home/vuurdraak/Downloads/gfxbench/images
[INFO ]: Asset image path: :
[INFO ]: Dispatching getTests
[INFO ]: Dispatching getConfigurations
[INFO ]: Dispatching getSessions
[INFO ]: Dispatching getBestResults
[INFO ]: Dispatching getSystemInfoItems
[clew] OpenCL loaded from: libOpenCL.so
[clew] Highest available: OpenCL 1.2
[clew] Highest available GL extensions: 1.2
[cudaw] CUDA library loaded from: libcuda.so
[cudaw] Highest available function set: 7.0
[cudaw] Highest available GL function set: 4.1
[INFO ]: GLFW init
[INFO ]: Service instance constructor
[INFO ]: Synchronizing from: http://cdn.gfxbench.com/production/gfxbench_gl-4.0.0.json.gz
[INFO ]: No configuration selected → disable all tests!!!
[INFO ]: Selecting configuration: GeForce GTX 1060 3GB
[INFO ]: Selecting configuration: 0
[INFO ]: Updating test gl_4 availability for config GeForce GTX 1060 3GB
[INFO ]: Compatible
[INFO ]: Updating test gl_4_off availability for config GeForce GTX 1060 3GB
[INFO ]: Compatible
[INFO ]: Updating test gl_manhattan311_wqhd_off availability for config GeForce GTX 1060 3GB
[INFO ]: Compatible
[INFO ]: Updating test gl_manhattan31 availability for config GeForce GTX 1060 3GB
[INFO ]: Compatible
[INFO ]: Updating test gl_manhattan31_off availability for config GeForce GTX 1060 3GB
[INFO ]: Compatible
[INFO ]: Updating test gl_manhattan availability for config GeForce GTX 1060 3GB
[INFO ]: Compatible
[INFO ]: Updating test gl_manhattan_off availability for config GeForce GTX 1060 3GB
[INFO ]: Compatible
[INFO ]: Updating test gl_trex availability for config GeForce GTX 1060 3GB
[INFO ]: Compatible
[INFO ]: Updating test gl_trex_off availability for config GeForce GTX 1060 3GB
[INFO ]: Compatible
[INFO ]: Updating test gl_tess availability for config GeForce GTX 1060 3GB
[INFO ]: Compatible
[INFO ]: Updating test gl_tess_off availability for config GeForce GTX 1060 3GB
[INFO ]: Compatible
[INFO ]: Updating test gl_alu2 availability for config GeForce GTX 1060 3GB
[INFO ]: Compatible
[INFO ]: Updating test gl_alu2_off availability for config GeForce GTX 1060 3GB
[INFO ]: Compatible
[INFO ]: Updating test gl_driver2 availability for config GeForce GTX 1060 3GB
[INFO ]: Compatible
[INFO ]: Updating test gl_driver2_off availability for config GeForce GTX 1060 3GB
[INFO ]: Compatible
[INFO ]: Updating test gl_fill2 availability for config GeForce GTX 1060 3GB
[INFO ]: Compatible
[INFO ]: Updating test gl_fill2_off availability for config GeForce GTX 1060 3GB
[INFO ]: Compatible
[INFO ]: Updating test gl_trex_qmatch availability for config GeForce GTX 1060 3GB
[INFO ]: Compatible
[INFO ]: Updating test gl_trex_qmatch_highp availability for config GeForce GTX 1060 3GB
[INFO ]: Compatible
[INFO ]: Updating test gl_manhattan31_battery availability for config GeForce GTX 1060 3GB
[INFO ]: Not compatible (missing feature)!!!
[INFO ]: Updating test gl_trex_battery availability for config GeForce GTX 1060 3GB
[INFO ]: askSync
[INFO ]: Executing getTests
[INFO ]: Executing getConfigurations
[INFO ]: Executing getSessions
[INFO ]: Executing getBestResults
[INFO ]: Executing getSystemInfoItems
[INFO ]: Dispatching acceptSynchronization
[INFO ]: Executing acceptSynchronization
[INFO ]: syncing from stream
[INFO ]: streaming: /production/gfxbench_gl-4.0.0b192.stream.gz [0-7198045]
[INFO ]: Dispatching getCompareResults
[INFO ]: Executing getCompareResults
[INFO ]: finishSynchronization
[INFO ]: Dispatching runAllTests
[INFO ]: Executing runAllTests
[WARN ]: libpng warning: iCCP: known incorrect sRGB profile
[WARN ]: QXcbIntegration: Cannot create platform OpenGL context, neither GLX nor EGL are enabled
[INFO ]: Dispatching loadTest
[INFO ]: Executing loadTest
[INFO ]: Application’s context mismatched! Test built with HAVE_GLEW. Supported context is 0
[INFO ]: ~GFXBench
[INFO ]: ~GFXBench
[INFO ]: ~GFXBench
[INFO ]: ~GFXBench
[INFO ]: ~GFXBench
[INFO ]: ~GFXBench
[INFO ]: ~GFXBench
[INFO ]: ~GFXBench
[INFO ]: ~GFXBench
[INFO ]: ~GFXBench
[INFO ]: ~GFXBench
[INFO ]: ~GFXBench
[INFO ]: ~GFXBench
[INFO ]: ~GFXBench
[INFO ]: ~GFXBench
[INFO ]: ~GFXBench
[INFO ]: ~GFXBench
[INFO ]: ~GFXBench
[INFO ]: Dispatching getResultForSession
[INFO ]: Executing getResultForSession
[INFO ]: finishSession
[INFO ]: Dispatching getResultDetails
[INFO ]: Executing getResultDetails
[INFO ]: stop
[INFO ]: Dispatching stop
[INFO ]: Executing stop
[INFO ]: ~GFXBench
