Dear,
I’m trying to access GMSL camera(s) from python.
Even some related threads as follow:
I’m not sure the issue was cleared.
Does anyone have an idea to access GMSL camera(s) with Python?
Thanks,
Dear,
Thanks,
Dear ddpx2,
Do you have any reason to use Python?
Because the souce codes for DriveWorks/NvMedia are all based on C++. Thanks.
BTW I hope this link helps for your topic. Thanks.
https://devtalk.nvidia.com/default/topic/1044512/general/opencv-unable-to-stop-the-stream-inappropriate-ioctl-for-device/?offset=2#5299842
Thanks Steve,
I’ll test it and update~
Steve,
I’ve installed OpenCV on DRIVE AGX Xavier Dev. system and tested with Python.
Then, how can I access GMSL camera here?
To capture frame at Python as follow;
import cv2
cap = cv2.VideoCapture(<b>0</b>)
while(True):
# Capture frame-by-frame
ret, frame = cap.read()
Python requires the device index or video file name.
e.g /dev/video0, /dev/video1… or 0, 1 etc
And, when multiple GMSL cameras are installed, how can I pass mask info like selector_mask.
Thanks,
Facing the same problem. Can’t get the video capture device. Anybody figured it out?
Hi @farhan3,
Please help to change your DevZone account to use corporate or university email address by following below links, and then create a new topic linked to this topic for your problem. Thanks!
https://developer.nvidia.com/user -> “Edit Profile” -> “Change email” -> “CHANGE”
Very long time ago, I posted it.
After all, I could not access GMSL cameras in the Python code.
Instead of, you could find GMSL to USB adapters on the web.
For AR0231 sensors, following would he helpful;
Thanks,
