Yes,I do.But the IMX390 is still not loaded.
Could you help have a look on configuration?
tca9546@70 {
compatible = "nxp,pca9546";
reg = <0x00000070>;
#address-cells = <0x00000001>;
#size-cells = <0x00000000>;
vcc-supply = <0x0000003d>;
vcc-pullup-supply = <0x0000002e>;
skip_mux_detect = "yes";
force_bus_start = <0x0000001e>;
vif-supply = <0x0000003d>;
status = "okay";
phandle = <0x00000315>;
i2c@2 {
reg = <0x00000002>;
i2c-mux,deselect-on-exit;
imx390_a@1b {
compatible = "sony,imx390";
reg = <0x0000001b>;
physical_w = "15.0";
physical_h = "12.5";
sensor_model = "imx390";
post_crop_frame_drop = "0";
use_decibel_gain = "true";
use_sensor_mode_id = "true";
def-addr = <0x0000001a>;
clocks = <0x00000004 0x00000024 0x00000004 0x00000024>;
clock-names = "extperiph1", "pllp_grtba";
mclk = "extperiph1";
nvidia,gmsl-ser-device = <0x00000041>;
nvidia,gmsl-dser-device = <0x00000042>;
status = "okay";
phandle = <0x0000031b>;
mode0 {
mclk_khz = "24000";
num_lanes = [34 00];
tegra_sinterface = "serial_c";
vc_id = "0";
discontinuous_clk = "no";
dpcm_enable = "false";
cil_settletime = "0";
dynamic_pixel_bit_depth = "12";
csi_pixel_bit_depth = "12";
mode_type = "bayer";
pixel_phase = "rggb";
active_w = "1920";
active_h = "1080";
readout_orientation = "0";
line_length = "2200";
inherent_gain = "1";
pix_clk_hz = "74250000";
serdes_pix_clk_hz = "200000000";
gain_factor = "10";
min_gain_val = "0";
max_gain_val = "300";
step_gain_val = "3";
default_gain = "0";
min_hdr_ratio = "1";
max_hdr_ratio = "1";
framerate_factor = "1000000";
min_framerate = "30000000";
max_framerate = "30000000";
step_framerate = "1";
default_framerate = "30000000";
exposure_factor = "1000000";
min_exp_time = "59";
max_exp_time = "33333";
step_exp_time = "1";
default_exp_time = "33333";
embedded_metadata_height = "0";
ports {
port@0 {
reg = <0x00000000>;
endpoint {
vc-id = <0x00000000>;
port-index = <0x00000004>;
bus-width = <0x00000004>;
remote-endpoint = <0x00000040>;
phandle = <0x0000031c>;
gmsl-link {
src-csi-port = "a";
dst-csi-port = "c";
serdes-csi-link = "a";
csi-mode = "1x4";
st-vc = <0x00000000>;
num-lanes = <0x00000004>;
streams = "ued-u1", "raw12";
imx390_b@1c {
reg = <0x0000001c>;
nvidia,gmsl-ser-device = <0x00000043>;
status = "okay";
phandle = <0x0000031d>;
mode0 {
mclk_khz = "24000";
vc_id = "1";
active_w = "1920";
active_h = "1080";
gain_factor = "10";
min_gain_val = "0";
default_gain = "0";
ports {
port@0 {
reg = <0x00000000>;
endpoint {
vc-id = <0x00000001>;
remote-endpoint = <0x00000044>;
phandle = <0x0000031e>;
gmsl-link {
src-csi-port = "a";
dst-csi-port = "c";
serdes-csi-link = "b";
csi-mode = "1x4";
max9296@48 {
compatible = "maxim,max9296";
reg = <0x00000048>;
csi-mode = "2x4";
max-src = <0x00000002>;
reset-gpios = <0x00000014 0x0000003b 0x00000000>;
status = "okay";
phandle = <0x00000042>;
max9295_prim@62 {
compatible = "maxim,max9295";
reg = <0x00000062>;
is-prim-ser;
status = "okay";
phandle = <0x0000031f>;
max9295_a@40 {
reg = <0x00000040>;
status = "okay";
phandle = <0x00000041>;
max9295_b@60 {
reg = <0x00000060>;
status = "okay";
phandle = <0x00000043>;
Module Device Tree - VI
tegra-capture-vi {
compatible = "nvidia,tegra-camrtc-capture-vi";
nvidia,vi-devices = <0x00000248 0x0000024a>;
nvidia,vi-mapping-size = <0x00000006>;
nvidia,vi-mapping = <0x00000000 0x00000000 0x00000001 0x00000000 0x00000002 0x00000001 0x00000003 0x00000001 0x00000004 0x00000000 0x00000005 0x00000001>;
nvidia,vi-mapping-names = "csi-stream-id", "vi-unit-id";
nvidia,vi-max-channels = <0x00000048>;
num-channels = <0x00000006>;
phandle = <0x0000043b>;
ports {
port@0 {
reg = <0x00000000>;
status = "okay";
phandle = <0x0000043c>;
endpoint {
port-index = <0x00000000>;
remote-endpoint = <0x0000024b>;
status = "okay";
phandle = <0x00000286>;
port@1 {
reg = <0x00000001>;
status = "okay";
phandle = <0x0000043d>;
endpoint {
remote-endpoint = <0x0000024c>;
status = "okay";
phandle = <0x00000288>;
port@2 {
reg = <0x00000002>;
status = "okay";
phandle = <0x0000043e>;
endpoint {
port-index = <0x00000002>;
remote-endpoint = <0x0000024d>;
status = "okay";
phandle = <0x0000028a>;
port@3 {
reg = <0x00000003>;
status = "okay";
phandle = <0x0000043f>;
endpoint {
remote-endpoint = <0x0000024e>;
status = "okay";
phandle = <0x0000028c>;
port@4 {
reg = <0x00000004>;
status = "okay";
phandle = <0x00000440>;
endpoint {
remote-endpoint = <0x0000024f>;
status = "okay";
phandle = <0x0000028e>;
port@5 {
reg = <0x00000005>;
status = "okay";
phandle = <0x00000441>;
endpoint {
remote-endpoint = <0x00000250>;
status = "okay";
phandle = <0x00000290>;
Module Device Tree - NVCSI
nvcsi@15a00000 {
compatible = "nvidia,tegra194-nvcsi";
clocks = <0x00000004 0x00000051>;
clock-names = "nvcsi";
status = "okay";
num-tpg-channels = <0x00000024>;
phandle = <0x00000462>;
channel@0 {
reg = <0x00000000>;
status = "okay";
phandle = <0x00000463>;
ports {
port@0 {
reg = <0x00000000>;
status = "okay";
phandle = <0x00000464>;
endpoint@0 {
remote-endpoint = <0x00000285>;
status = "okay";
phandle = <0x00000040>;
port@1 {
reg = <0x00000001>;
status = "okay";
phandle = <0x00000465>;
endpoint@1 {
remote-endpoint = <0x00000286>;
status = "okay";
phandle = <0x0000024b>;
channel@1 {
reg = <0x00000001>;
status = "okay";
phandle = <0x00000466>;
ports {
port@0 {
reg = <0x00000000>;
status = "okay";
phandle = <0x00000467>;
endpoint@2 {
remote-endpoint = <0x00000287>;
status = "okay";
phandle = <0x00000044>;
port@1 {
reg = <0x00000001>;
status = "okay";
phandle = <0x00000468>;
endpoint@3 {
remote-endpoint = <0x00000288>;
status = "okay";
phandle = <0x0000024c>;
channel@2 {
reg = <0x00000002>;
status = "okay";
phandle = <0x00000469>;
ports {
port@0 {
reg = <0x00000000>;
status = "okay";
phandle = <0x0000046a>;
endpoint@4 {
remote-endpoint = <0x00000289>;
status = "okay";
phandle = <0x00000046>;
port@1 {
reg = <0x00000001>;
status = "okay";
phandle = <0x0000046b>;
endpoint@5 {
remote-endpoint = <0x0000028a>;
status = "okay";
phandle = <0x0000024d>;
channel@3 {
reg = <0x00000003>;
status = "okay";
phandle = <0x0000046c>;
ports {
port@0 {
reg = <0x00000000>;
status = "okay";
phandle = <0x0000046d>;
endpoint@6 {
remote-endpoint = <0x0000028b>;
status = "okay";
phandle = <0x00000047>;
port@1 {
reg = <0x00000001>;
status = "okay";
phandle = <0x0000046e>;
endpoint@7 {
remote-endpoint = <0x0000028c>;
status = "okay";
phandle = <0x0000024e>;
channel@4 {
reg = <0x00000004>;
status = "okay";
phandle = <0x0000046f>;
ports {
port@0 {
reg = <0x00000000>;
status = "okay";
phandle = <0x00000470>;
endpoint@8 {
remote-endpoint = <0x0000028d>;
status = "okay";
phandle = <0x00000048>;
port@1 {
reg = <0x00000001>;
status = "okay";
phandle = <0x00000471>;
endpoint@9 {
remote-endpoint = <0x0000028e>;
status = "okay";
phandle = <0x0000024f>;
channel@5 {
reg = <0x00000005>;
status = "okay";
phandle = <0x00000472>;
ports {
port@0 {
reg = <0x00000000>;
status = "okay";
phandle = <0x00000473>;
endpoint@10 {
remote-endpoint = <0x0000028f>;
status = "okay";
phandle = <0x00000049>;
port@1 {
reg = <0x00000001>;
status = "okay";
phandle = <0x00000474>;
endpoint@11 {
remote-endpoint = <0x00000290>;
status = "okay";
phandle = <0x00000250>;
tegra-camera-platform node
tegra-camera-platform {
compatible = "nvidia, tegra-camera-platform";
num_csi_lanes = <0x00000010>;
max_lane_speed = <0x0016e360>;
min_bits_per_pixel = <0x0000000a>;
vi_peak_byte_per_pixel = <0x00000002>;
vi_bw_margin_pct = <0x00000019>;
max_pixel_rate = <0x000b71b0>;
isp_peak_byte_per_pixel = <0x00000005>;
isp_bw_margin_pct = <0x00000019>;
tpg_max_iso = <0x003bc400>;
phandle = <0x000004c5>;
modules {
module0 {
badge = "imx390_rear";
position = "rear";
orientation = "1";
status = "okay";
phandle = <0x000004c6>;
drivernode0 {
pcl_id = "v4l2_sensor";
devname = "imx390 30-001b";
proc-device-tree = "/proc/device-tree/i2c@3180000/tca9546@70/i2c@0/imx390_a@1b";
status = "okay";
phandle = <0x000004c7>;
drivernode1 {
pcl_id = "v4l2_lens";
proc-device-tree = "/proc/device-tree/lens_imx274@A6V26/";
status = "disabled";
phandle = <0x000004c8>;
module1 {
badge = "imx390_front";
position = "front";
orientation = "1";
status = "okay";
phandle = <0x000004c9>;
drivernode0 {
devname = "imx390 30-001c";
proc-device-tree = "/proc/device-tree/i2c@3180000/tca9546@70/i2c@0/imx390_b@1c";
status = "okay";
phandle = <0x000004ca>;
drivernode1 {
phandle = <0x000004cb>;
module2 {
position = "rear";
orientation = "1";
status = "okay";
phandle = <0x000004cc>;
drivernode0 {
devname = "imx390 32-001b";
proc-device-tree = "/proc/device-tree/i2c@3180000/tca9546@70/i2c@1/imx390_a@1b";
status = "okay";
phandle = <0x000004cd>;
drivernode1 {
proc-device-tree = "/proc/device-tree/e3333_lens_ov5693@P5V27C/";
phandle = <0x000004ce>;
module3 {
position = "front";
orientation = "1";
status = "okay";
phandle = <0x000004cf>;
drivernode0 {
devname = "imx390 33-001c";
proc-device-tree = "/proc/device-tree/i2c@3180000/tca9546@70/i2c@1/imx390_b@1c";
status = "okay";
phandle = <0x000004d0>;
drivernode1 {
phandle = <0x000004d1>;
module4 {
position = "rear";
orientation = "1";
status = "okay";
phandle = <0x000004d2>;
drivernode0 {
devname = "imx390 34-001b";
proc-device-tree = "/proc/device-tree/i2c@3180000/tca9546@70/i2c@2/imx390_a@1b";
status = "okay";
phandle = <0x000004d3>;
drivernode1 {
phandle = <0x000004d4>;
module5 {
position = "front";
orientation = "1";
status = "okay";
phandle = <0x000004d5>;
drivernode0 {
devname = "imx390 35-001c";
proc-device-tree = "/proc/device-tree/i2c@3180000/tca9546@70/i2c@2/imx390_b@1c";
status = "okay";
phandle = <0x000004d6>;
drivernode1 {
phandle = <0x000004d7>;
