• DeepStream Version
• TensorRT Version
docker run --gpus all -it --rm --net=host --privileged -v /tmp/.X11-unix:/tmp/.X11-unix -e DISPLAY=$DISPLAY -w /opt/nvidia/deepstream/deepstream-6.1 nvcr.io/nvidia/deepstream:6.1-devel
• Hardware Platform GPU
• DeepStream Version 6.1.0
• TensorRT Version 8.2
root@ht-2288H-V5:/opt/nvidia/deepstream/deepstream-6.1# deepstream-app --version-all
(gst-plugin-scanner:10): GStreamer-WARNING **: 08:06:03.846: Failed to load plugin ‘/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_udp.so’: librivermax.so.0: cannot open shared object file: No such file or directory
(gst-plugin-scanner:10): GStreamer-WARNING **: 08:06:03.858: Failed to load plugin ‘/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_inferserver.so’: libtritonserver.so: cannot open shared object file: No such file or directory
deepstream-app version 6.1.0
DeepStreamSDK 6.1.0
CUDA Driver Version: 11.6
CUDA Runtime Version: 11.6
TensorRT Version: 8.2
cuDNN Version: 8.4
libNVWarp360 Version: 2.0.1d3
root@ht-2288H-V5:/opt/nvidia/deepstream/deepstream-5.0#
root@ht-2288H-V5:/opt/nvidia/deepstream/deepstream-6.1# nvidia-smi
Thu May 26 08:08:20 2022
| NVIDIA-SMI 450.156.00 Driver Version: 450.156.00 CUDA Version: 11.6 |
Tesla T4 A piece of T4 GPU
gst-launch-1.0 souphttpsrc location=http://devimages.apple.com/iphone/samples/bipbop/gear4/prog_index.m3u8 ! hlsdemux ! decodebin ! videoconvert ! videoscale ! autovideosink
Setting pipeline to PAUSED …
error: XDG_RUNTIME_DIR not set in the environment.
Pipeline is PREROLLING …
WARNING: from element /GstPipeline:pipeline0/GstAutoVideoSink:autovideosink0: Could not initialise Xv output
Additional debug info:
xvimagesink.c(1773): gst_xv_image_sink_open (): /GstXvImageSink:autovideosink0-actual-sink-xvimage:
Could not open display (null)
Got context from element ‘souphttpsrc0’: gst.soup.session=context, session=(SoupSession)NULL, force=(boolean)false;
Pipeline is PREROLLED …
Setting pipeline to PLAYING …
New clock: GstSystemClock
^Chandling interrupt.
Interrupt: Stopping pipeline …
Execution ended after 0:00:15.506788012
Setting pipeline to READY …
Setting pipeline to NULL …
Freeing pipeline …
gst-launch-1.0 --gst-debug-level=5 souphttpsrc location=http://devimages.apple.com/iphone/samples/bipbop/gear4/prog_index.m3u8 ! hlsdemux ! decodebin ! videoconvert ! videoscale ! autovideosink >log_new.txt 2>&1
log_new.txt (42.9 MB)
When running this command, the GPU memory usage is 103M, but the GPU usage is 0%
