GPIO with python library does not work
I am using the python jetson-gpio library on a jetson xavier nx. Launching any of the files inside the samples folder, I got the fallowing error message
amr@moto:~/Downloads/jetson-gpio/samples$ sudo python3 test_all_pins.py
Testing pin 7 as OUTPUT; CTRL-C to test next pin
File “test_all_pins.py”, line 89, in
GPIO.setup(pin, GPIO.OUT)
File “/usr/local/lib/python3.7/dist-packages/Jetson.GPIO-2.1.3-py3.7.egg/Jetson/GPIO/gpio.py”, line 360, in setup
File “/usr/local/lib/python3.7/dist-packages/Jetson.GPIO-2.1.3-py3.7.egg/Jetson/GPIO/gpio.py”, line 155, in _do_one_channel
File “/usr/local/lib/python3.7/dist-packages/Jetson.GPIO-2.1.3-py3.7.egg/Jetson/GPIO/gpio_cdev.py”, line 189, in chip_open_by_label
Exception: tegra194-gpio: No such gpio device registered
Any suggestion to solve the issue is appreciated
Salvatore
Moved to the Jetson Xavier NX forum.
Sorry for the late response.
Are you uisng the devkit or custom board for Xavier NX?
Are you trying to configure PIN7?
