Hello dear folks.
The GPU fails to engage when I am running applications on my system. Instead it defaults to llvmpipe.
With the (deprecated) xserver-xorg-video-nouveau driver I get better performance, but a lot less stability.
Edit: That was unclear - the open source driver works with the actual GPU, but it does crash (a lot).
What can I do?
Edit: I did read threads with similar issues, but none of the solutions I came across (yet) worked for me.
I learned a lot, but my issue remains.
System specs:
System:
Kernel: 6.8.0-49-generic arch: x86_64 bits: 64 compiler: gcc v: 13.2.0 clocksource: tsc
Desktop: Cinnamon v: 6.2.9 tk: GTK v: 3.24.41 wm: Muffin v: 6.2.0 tools: cinnamon-screensaver
vt: 7 dm: LightDM v: 1.30.0 Distro: Linux Mint 22 Wilma base: Ubuntu 24.04 noble
Machine:
Type: Desktop Mobo: MEDION model: B760H7-EM v: 2.0 serial: <superuser required>
part-nu: ML-110000 10025331 uuid: <superuser required> UEFI: American Megatrends LLC.
v: 760H7EMW0X.206 date: 10/05/2023
CPU:
Info: 20-core (8-mt/12-st) model: Intel Core i7-14700F bits: 64 type: MST AMCP smt: enabled
arch: Raptor Lake rev: 1 cache: L1: 1.8 MiB L2: 28 MiB L3: 33 MiB
Speed (MHz): avg: 912 high: 1420 min/max: 800/5300:5400:4200 cores: 1: 1400 2: 800 3: 800
4: 800 5: 1400 6: 800 7: 800 8: 800 9: 1008 10: 800 11: 1321 12: 800 13: 1397 14: 800 15: 800
16: 800 17: 800 18: 800 19: 800 20: 800 21: 800 22: 800 23: 800 24: 800 25: 1420 26: 800
27: 800 28: 800 bogomips: 118272
Flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
Graphics:
Device-1: NVIDIA AD104 [GeForce RTX 4070] vendor: ZOTAC driver: nvidia v: 550.120 arch: Lovelace
pcie: speed: 2.5 GT/s lanes: 16 ports: active: none off: HDMI-A-1 empty: DP-1,DP-2,DP-3
bus-ID: 01:00.0 chip-ID: 10de:2786 class-ID: 0300
Display: x11 server: X.Org v: 21.1.11 with: Xwayland v: 23.2.6 driver: X: loaded: nvidia
unloaded: fbdev,modesetting,nouveau,vesa gpu: nvidia,nvidia-nvswitch display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 81 s-size: 602x343mm (23.70x13.50") s-diag: 693mm (27.28")
Monitor-1: HDMI-0 res: 1920x1080 hz: 60 dpi: 82 size: 598x336mm (23.54x13.23")
diag: 686mm (27.01") modes: N/A
API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 2 drv: swrast gbm:
drv: nvidia surfaceless: drv: nvidia x11: drv: nvidia inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia v: 550.120 glx-v: 1.4 direct-render: yes
renderer: NVIDIA GeForce RTX 4070/PCIe/SSE2
API: Vulkan v: 1.3.275 layers: 6 surfaces: xcb,xlib device: 0 type: discrete-gpu driver: N/A
device-ID: 10de:2786 device: 1 type: cpu driver: N/A device-ID: 10005:0000
Audio:
Device-1: Intel Raptor Lake High Definition Audio vendor: MEDION AG driver: snd_hda_intel
v: kernel bus-ID: 00:1f.3 chip-ID: 8086:7a50 class-ID: 0403
Device-2: NVIDIA vendor: ZOTAC driver: snd_hda_intel v: kernel pcie: speed: 16 GT/s lanes: 16
bus-ID: 01:00.1 chip-ID: 10de:22bc class-ID: 0403
API: ALSA v: k6.8.0-49-generic status: kernel-api
Server-1: PipeWire v: 1.0.5 status: active with: 1: pipewire-pulse status: active
2: wireplumber status: active 3: pipewire-alsa type: plugin
Network:
Device-1: Intel Raptor Lake-S PCH CNVi WiFi driver: iwlwifi v: kernel bus-ID: 00:14.3
chip-ID: 8086:7a70 class-ID: 0280
IF: wlo1 state: down mac: <filter>
Device-2: Realtek RTL8111/8168/8211/8411 PCI Express Gigabit Ethernet vendor: MEDION AG
RTL8111/8168/8411 driver: r8169 v: kernel pcie: speed: 2.5 GT/s lanes: 1 port: 3000
bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp4s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Bluetooth:
Device-1: Intel AX201 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1
bus-ID: 1-14:6 chip-ID: 8087:0026 class-ID: e001
Report: hciconfig ID: hci0 rfk-id: 0 state: down bt-service: enabled,running rfk-block:
hardware: no software: yes address: <filter>
Drives:
Local Storage: total: 14.55 TiB used: 12.93 TiB (88.8%)
ID-1: /dev/nvme0n1 vendor: Western Digital model: WD Blue SN580 1TB size: 931.51 GiB
speed: 63.2 Gb/s lanes: 4 tech: SSD serial: <filter> fw-rev: 281010WD temp: 31.9 C scheme: GPT
ID-2: /dev/sda vendor: Western Digital model: WD10JPVX-22JC3T0 size: 931.51 GiB type: USB
rev: 2.1 spd: 480 Mb/s lanes: 1 tech: HDD rpm: 5400 serial: <filter> scheme: GPT
ID-3: /dev/sdb vendor: Seagate model: OneTouch HDD size: 4.55 TiB type: USB rev: 2.1
spd: 480 Mb/s lanes: 1 tech: N/A serial: <filter> fw-rev: 1707 scheme: GPT
ID-4: /dev/sdc vendor: Seagate model: BUP BK size: 3.64 TiB type: USB rev: 2.1 spd: 480 Mb/s
lanes: 1 tech: N/A serial: <filter> fw-rev: 0304 scheme: GPT
ID-5: /dev/sdd vendor: Western Digital model: WD50NDZW-11A8JS1 size: 4.55 TiB type: USB
rev: 2.1 spd: 480 Mb/s lanes: 1 tech: HDD rpm: 5400 serial: <filter> fw-rev: 1020 scheme: GPT
Partition:
ID-1: / size: 915.32 GiB used: 528.16 GiB (57.7%) fs: ext4 dev: /dev/nvme0n1p2
ID-2: /boot/efi size: 511 MiB used: 6.1 MiB (1.2%) fs: vfat dev: /dev/nvme0n1p1
Swap:
ID-1: swap-1 type: file size: 2 GiB used: 0 KiB (0.0%) priority: -2 file: /swapfile
USB:
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 16 rev: 2.0 speed: 480 Mb/s lanes: 1
chip-ID: 1d6b:0002 class-ID: 0900
Device-1: 1-5:2 info: Mad Catz Catz R.A.T.7 Mouse type: mouse driver: hid-generic,usbhid
interfaces: 1 rev: 2.0 speed: 12 Mb/s lanes: 1 power: 100mA chip-ID: 0738:1708 class-ID: 0301
Device-2: 1-6:3 info: Trust Keyboard type: keyboard,HID driver: hid-generic,usbhid
interfaces: 2 rev: 1.1 speed: 1.5 Mb/s lanes: 1 power: 98mA chip-ID: 145f:02c9 class-ID: 0300
Device-3: 1-9:4 info: Holtek USB-HID Device type: HID driver: hid-generic,usbhid interfaces: 3
rev: 1.1 speed: 12 Mb/s lanes: 1 power: 500mA chip-ID: 04d9:a2ec class-ID: 0300 serial: <filter>
Hub-2: 1-11:5 info: VIA Labs VL813 Hub ports: 4 rev: 2.1 speed: 480 Mb/s lanes: 1
chip-ID: 2109:2813 class-ID: 0900
Hub-3: 1-11.1:7 info: VIA Labs VL813 Hub ports: 4 rev: 2.1 speed: 480 Mb/s lanes: 1
Device-1: 1-11.1.1:8 info: ASMedia ASM1051E SATA 6Gb/s bridge ASM1053E ASM1153 3Gb/s ASM1153E
bridge type: mass storage driver: uas interfaces: 1 rev: 2.1 speed: 480 Mb/s lanes: 1
chip-ID: 174c:55aa class-ID: 0806 serial: <filter>
Device-2: 1-11.1.2:9 info: Seagate RSS LLC OneTouch HDD type: mass storage driver: uas
interfaces: 1 rev: 2.1 speed: 480 Mb/s lanes: 1 power: 500mA chip-ID: 0bc2:ab62 class-ID: 0806
serial: <filter>
Device-3: 1-11.1.3:10 info: Seagate RSS LLC Backup Plus Portable 5TB SRD00F1 type: mass storage
driver: uas interfaces: 1 rev: 2.1 speed: 480 Mb/s lanes: 1 power: 100mA chip-ID: 0bc2:ab28
Device-4: 1-11.1.4:11 info: Western Digital Elements 2620 type: mass storage
driver: usb-storage interfaces: 1 rev: 2.1 speed: 480 Mb/s lanes: 1 power: 500mA
chip-ID: 1058:2620 class-ID: 0806 serial: <filter>
Device-5: 1-14:6 info: Intel AX201 Bluetooth type: bluetooth driver: btusb interfaces: 2
rev: 2.0 speed: 12 Mb/s lanes: 1 power: 100mA chip-ID: 8087:0026 class-ID: e001
Hub-4: 2-0:1 info: super-speed hub ports: 10 rev: 3.1 speed: 20 Gb/s lanes: 2
chip-ID: 1d6b:0003 class-ID: 0900
Sensors:
System Temperatures: cpu: 27.0 C mobo: N/A gpu: nvidia temp: 31 C
Fan Speeds (rpm): N/A gpu: nvidia fan: 0%
Repos:
Packages: 5459 pm: dpkg pkgs: 2723 pm: rpm pkgs: N/A note: see --rpm pm: flatpak pkgs: 13
No active apt repos in: /etc/apt/sources.list
Active apt repos in: /etc/apt/sources.list.d/kisak-kisak-mesa-noble.list
1: deb [signed-by=/etc/apt/keyrings/kisak-kisak-mesa-noble.gpg] https: //ppa.launchpadcontent.net/kisak/kisak-mesa/ubuntu noble main
Active apt repos in: /etc/apt/sources.list.d/official-package-repositories.list
1: deb https: //mirror.init7.net/linuxmint wilma main upstream import backport
2: deb http: //ubuntu.ethz.ch/ubuntu noble main restricted universe multiverse
3: deb http: //ubuntu.ethz.ch/ubuntu noble-updates main restricted universe multiverse
4: deb http: //ubuntu.ethz.ch/ubuntu noble-backports main restricted universe multiverse
5: deb http: //security.ubuntu.com/ubuntu/ noble-security main restricted universe multiverse
No active dnf repos in: /etc/dnf/dnf.conf
Info:
Memory: total: 16 GiB available: 15.41 GiB used: 1.62 GiB (10.5%)
Processes: 493 Power: uptime: 0m states: freeze,mem,disk suspend: deep wakeups: 0
hibernate: platform Init: systemd v: 255 target: graphical (5) default: graphical
Compilers: gcc: 13.2.0 Client: Unknown python3.12 client inxi: 3.3.34
